[petsc-users] MUMPS failure
    Sanjay Govindjee
    s_g at berkeley.edu
    Tue Mar 23 00:07:15 CDT 2021
Barry,
I am curious about your statement "does not work generically".  If I
compile with -fdefault-integer-8,
I would assume that this produces objects/libraries that will use 64bit
integers.  As long as I have not declared
explicit kind=4 integers, what else could go wrong.
-sanjay
PS: I am not advocating this as a great idea, but I am curious if there
or other obscure compiler level things that could go wrong.
On 3/22/21 8:53 PM, Barry Smith wrote:
>> On Mar 22, 2021, at 3:24 PM, Junchao Zhang <junchao.zhang at gmail.com
>> <mailto:junchao.zhang at gmail.com>> wrote:
>> On Mon, Mar 22, 2021 at 1:39 PM Barry Smith <bsmith at petsc.dev
>> <mailto:bsmith at petsc.dev>> wrote:
>>        Version of PETSc and MUMPS? We fixed a bug in MUMPs a couple
>>     years ago that produced error messages as below. Please confirm
>>     you are using the latest PETSc and MUMPS.
>>        You can run your production version with the option
>>     -malloc_debug ; this will slow it down a bit but if there is
>>     memory corruption it may detect it and indicate the problematic
>>     error.
>>         One also has to be careful about the size of the problem
>>     passed to MUMPs since PETSc/MUMPs does not fully support using
>>     all 64 bit integers. Is it only crashing for problems near 2
>>     billion entries in the sparse matrix?
>>  "problems near 2 billion entries"?  I don't understand. Should not
>> be an issue if building petsc with 64-bit indices.
>   MUMPS does not have proper support for 64 bit indices. It relies on
> add-hoc Fortran compiler command line options to support to converting
> integer to 64 bit integers and does not work generically. Yes, Fortran
> lovers have been doing this for 30 years inside their applications but
> it does not really work in a library environment. But then a big
> feature of Fortran is "who needs libraries, we just write all the code
> we need" (except Eispack,Linpack,LAPACK :=-).
>>          valgrind is the gold standard for detecting memory corruption.
>>     Barry
>>>     On Mar 22, 2021, at 12:56 PM, Chris Hewson <chris at resfrac.com
>>>     <mailto:chris at resfrac.com>> wrote:
>>>     Hi All,
>>>     I have been having a problem with MUMPS randomly crashing in our
>>>     program and causing the entire program to crash. I am compiling
>>>     in -O2 optimization mode and using --download-mumps etc. to
>>>     compile PETSc. If I rerun the program, 95%+ of the time I can't
>>>     reproduce the error. It seems to be a similar issue to this thread:
>>>     https://lists.mcs.anl.gov/pipermail/petsc-users/2018-October/036372.html
>>>     <https://lists.mcs.anl.gov/pipermail/petsc-users/2018-October/036372.html>
>>>     Similar to the resolution there I am going to try and increase
>>>     icntl_14 and see if that resolves the issue. Any other thoughts
>>>     on this?
>>>     Thanks,
>>>     *Chris Hewson*
>>>     Senior Reservoir Simulation Engineer
>>>     ResFrac
>>>     +1.587.575.9792
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210322/394c5a77/attachment.html>
