[petsc-users] funny link error
Mon Mar 22 11:11:12 CDT 2021
On Mon, Mar 22, 2021 at 11:04 AM Mark Adams <mfadams at lbl.gov> wrote:
> Thanks Scott,
> Can you please tell us where this pkg-config file is?
Looks like ${PETSC_ARCH}/lib/pkgconfig
   Matt
> Thank again,
> Mark
> On Mon, Mar 22, 2021 at 10:45 AM Scott Kruger <kruger at txcorp.com> wrote:
>> From you make.log, it looks like petsc found it  here:
>> /opt/cray/wlm_detect/1.3.3-7.0.1.1_4.19__g7109084.ari/lib64
>> PETSc has it and found it because BuildSystem did the query of what
>> it takes to get C/C++/Fortran to work together.  Why is it needed?
>> That's up to Cray.
>> But the question is:
>> How is your CMake build getting PETSc info?
>> If
>> a) it using pkg-config and CMake's ability to parse it, then it looks
>> like our pkg-config export might need work.
>> We'd need to see the pkg-config file to be sure though.
>> and if
>> b) it is not using pkg-config, then the answer is it should.
>> Scott
>> On 2021-03-21 08:25, Mark Adams did write:
>> > We are having problems with linking and use static linking.
>> > We get this error and have seen others like it (eg, lpetsc_lib_gcc_s)
>> > /usr/bin/ld: cannot find -lpetsc_lib_wlm_detect-NOTFOUND
>> > wlm_detect is some sort of system library, but I have no idea where this
>> > petsc string comes from.
>> > This is on Cori and the application uses cmake.
>> > I can run PETSc tests fine.
>> > Any ideas?
>> > Thanks,
>> > Mark
>> Scott Kruger
>> Tech-X Corporation               kruger at txcorp.com
>> 5621 Arapahoe Ave, Suite A       Phone: (720) 466-3196
>> Boulder, CO 80303                Fax:   (303) 448-7756
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210322/e2ba6067/attachment-0001.html>
