[petsc-users] funny link error
Mark Adams mfadams at lbl.gov
Mon Mar 22 10:03:39 CDT 2021
Thanks Scott,
Can you please tell us where this pkg-config file is?
Thank again,
On Mon, Mar 22, 2021 at 10:45 AM Scott Kruger <kruger at txcorp.com> wrote:
> From you make.log, it looks like petsc found it  here:
> /opt/cray/wlm_detect/1.3.3-7.0.1.1_4.19__g7109084.ari/lib64
> PETSc has it and found it because BuildSystem did the query of what
> it takes to get C/C++/Fortran to work together.  Why is it needed?
> That's up to Cray.
> But the question is:
> How is your CMake build getting PETSc info?
> If
> a) it using pkg-config and CMake's ability to parse it, then it looks like
> our pkg-config export might need work.
> We'd need to see the pkg-config file to be sure though.
> and if
> b) it is not using pkg-config, then the answer is it should.
> Scott
> On 2021-03-21 08:25, Mark Adams did write:
> > We are having problems with linking and use static linking.
> > We get this error and have seen others like it (eg, lpetsc_lib_gcc_s)
> > /usr/bin/ld: cannot find -lpetsc_lib_wlm_detect-NOTFOUND
> > wlm_detect is some sort of system library, but I have no idea where this
> > petsc string comes from.
> > This is on Cori and the application uses cmake.
> > I can run PETSc tests fine.
> > Any ideas?
> > Thanks,
> > Mark
> Scott Kruger
> Tech-X Corporation               kruger at txcorp.com
> 5621 Arapahoe Ave, Suite A       Phone: (720) 466-3196
> Boulder, CO 80303                Fax:   (303) 448-7756
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210322/c2da55ca/attachment.html>
