[petsc-users] PF+Navier stokes
Sepideh Kavousi
skavou1 at lsu.edu
Mon Mar 22 09:04:30 CDT 2021
Hello,
I want to solve PF solidification+Navier stokes using Finite different method, and I have a strange problem. My code runs fine for some system sizes and fails for some of the system sizes. When I run with the following options:
mpirun -np 2 ./one.out -ts_monitor -snes_fd_color -ts_max_snes_failures -1 -ts_type bdf -ts_bdf_adapt -pc_type bjacobi -snes_linesearch_type l2 -snes_type ksponly -ksp_type gmres -ksp_gmres_restart 1001 -sub_pc_type ilu -sub_ksp_type preonly -snes_monitor -ksp_monitor -snes_linesearch_monitor -ksp_monitor_true_residual -ksp_converged_reason -log_view
0 SNES Function norm 1.465357113711e+01
Linear solve did not converge due to DIVERGED_PC_FAILED iterations 0
PC_FAILED due to SUBPC_ERROR
^C Linear solve did not converge due to DIVERGED_PC_FAILED iterations 0
Even setting pc_type to LU does not solve the problem.
0 TS dt 0.0001 time 0.
copy!
copy!
Write output at step= 0!
PC_FAILED due to FACTOR_NUMERIC_ZEROPIVOT
I guess the problem is that in mass conservation I used forward discretization for u (velocity in x) and for the moment in x , I used forward discretization for p (pressure) to ensure non-zero terms on the diagonal of matrix. I tried to run it with valgrind but it did not output anything.
Does anyone have suggestions on how to solve this issue?
Best,
Sepideh
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210322/dd189a6a/attachment-0001.html>
