[petsc-users] Re-ordering in DMPlexCreateFromCellListParallelPetsc
Matthew Knepley
knepley at gmail.com
Mon Mar 22 07:45:37 CDT 2021
On Mon, Mar 22, 2021 at 6:22 AM Nicolas Barral <
nicolas.barral at math.u-bordeaux.fr> wrote:
> On 21/03/2021 21:29, Matthew Knepley wrote:
> > On Sat, Mar 20, 2021 at 10:07 AM Nicolas Barral
> > <nicolas.barral at math.u-bordeaux.fr
> > <mailto:nicolas.barral at math.u-bordeaux.fr>> wrote:
> > Hi all,
> > I'm building a plex from elements arrays using
> > DMPlexCreateFromCellListParallelPetsc. Once the plex is built, I
> > need to
> > set up boundary labels. I have an array of faces containing a series
> of
> > 3 vertex local indices. To rebuild boundary labels, I need to loop
> over
> > the array and get the join of 3 consecutive points to find the
> > corresponding face point in the DAG.
> > This is very common. We should have a built-in thing that does this.
> Ordering apart, it's not very complicated once you figure out "join" is
> the right operation to use. We need more doc on graph layout and
> operations in DMPlex, I think I'm going to make pictures when I'm done
> with that code because I waste too much time every time. Is there a
> starting point you like ?
I think the discussion in
@article{LangeMitchellKnepleyGorman2015,
title = {Efficient mesh management in {Firedrake} using
{PETSc-DMPlex}},
author = {Michael Lange and Lawrence Mitchell and Matthew G. Knepley
and Gerard J. Gorman},
journal = {SIAM Journal on Scientific Computing},
volume = {38},
number = {5},
pages = {S143--S155},
eprint = {http://arxiv.org/abs/1506.07749},
doi = {10.1137/15M1026092},
year = {2016}
is pretty good.
> > Problem, vertices get reordered by
> > so that locally owned vertices are before remote ones, so local
> indices
> > are changed and the indices in the face array are not good anymore.
> > This is not exactly what happens. I will talk through the algorithm so
> > that maybe we can find a good
> > interface. I can probably write the code quickly:
> > 1) We take in cells[numCells, numCorners], which is a list of all the
> > vertices in each cell
> > The vertex numbers do not have to be a contiguous set. You can
> > have any integers you want.
> > 2) We create a sorted list of the unique vertex numbers on each process.
> > The new local vertex numbers
> > are the locations in this list.
> Ok It took me re-writing this email a couple times but I think I
> understand. I was too focused on local/global indices. But if I get this
> right, you still make an assumption: that the numVertices*dim
> coordinates passed in vertexCoords are the coordinates of the
> numvertices first vertices in the sorted list. Is that true ?
No. It can be arbitrary. That is why we make the vertexSF, so we can map
those coordinates back to the right processes.
> > Here is my proposed interface. We preserve this list of unique vertices,
> > just as we preserve the vertexSF.
> > Then after DMPlexCreateFromCellListParallelPetsc(), can
> > DMPlexInterpolate(), you could call
> > DMPlexBuildFaceLabelsFromCellList(dm, numFaces, faces, labelName,
> > labelValues)
> > Would that work for you? I think I could do that in a couple of hours.
> So that function would be very helpful. But is it as simple as you're
> thinking ? The sorted list gives local index -> unique identifier, but
what we need is the other way round, isn't it ?
You get the other way using search.
Matt
> Once I understand better, I can have a first draft in my plexadapt code
> and we pull it out later.
> Thanks
> Nicolas
> > Thanks,
> > Matt
> > Is there a way to track this renumbering ? For owned vertices, I can
> > find the local index from the global one (so do old local index ->
> > global index -> new local index). For the remote ones, I'm not sure.
> I
> > can hash global indices, but is there a more idiomatic way ?
> > Thanks,
> > Nicolas
> > What most experimenters take for granted before they begin their
> > experiments is infinitely more interesting than any results to which
> > their experiments lead.
> > -- Norbert Wiener
> > https://www.cse.buffalo.edu/~knepley/ <
> http://www.cse.buffalo.edu/~knepley/>
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210322/b48effba/attachment.html>
