[petsc-users] Re-ordering in DMPlexCreateFromCellListParallelPetsc
Nicolas Barral nicolas.barral at math.u-bordeaux.fr
Mon Mar 22 05:22:55 CDT 2021
On 21/03/2021 21:29, Matthew Knepley wrote:
> On Sat, Mar 20, 2021 at 10:07 AM Nicolas Barral
> <nicolas.barral at math.u-bordeaux.fr
> <mailto:nicolas.barral at math.u-bordeaux.fr>> wrote:
>     Hi all,
>     I'm building a plex from elements arrays using
>     DMPlexCreateFromCellListParallelPetsc. Once the plex is built, I
>     need to
>     set up boundary labels. I have an array of faces containing a series of
>     3 vertex local indices. To rebuild boundary labels, I need to loop over
>     the array and get the join of 3 consecutive points to find the
>     corresponding face point in the DAG.
> This is very common. We should have a built-in thing that does this.
Ordering apart, it's not very complicated once you figure out "join" is
the right operation to use. We need more doc on graph layout and
operations in DMPlex, I think I'm going to make pictures when I'm done
with that code because I waste too much time every time. Is there a
starting point you like ?
>     Problem, vertices get reordered by
>     so that locally owned vertices are before remote ones, so local indices
>     are changed and the indices in the face array are not good anymore.
> This is not exactly what happens. I will talk through the algorithm so
> that maybe we can find a good
> interface. I can probably write the code quickly:
> 1) We take in cells[numCells, numCorners], which is a list of all the
> vertices in each cell
>       The vertex numbers do not have to be a contiguous set. You can
> have any integers you want.
> 2) We create a sorted list of the unique vertex numbers on each process.
> The new local vertex numbers
>       are the locations in this list.
Ok It took me re-writing this email a couple times but I think I
understand. I was too focused on local/global indices. But if I get this
right, you still make an assumption: that the numVertices*dim
coordinates passed in vertexCoords are the coordinates of the
numvertices first vertices in the sorted list. Is that true ?
> Here is my proposed interface. We preserve this list of unique vertices,
> just as we preserve the vertexSF.
> Then after DMPlexCreateFromCellListParallelPetsc(), can
> DMPlexInterpolate(), you could call
>    DMPlexBuildFaceLabelsFromCellList(dm, numFaces, faces, labelName,
> labelValues)
> Would that work for you? I think I could do that in a couple of hours.
So that function would be very helpful. But is it as simple as you're
thinking ? The sorted list gives local index -> unique identifier, but
what we need is the other way round, isn't it ?
Once I understand better, I can have a first draft in my plexadapt code
and we pull it out later.
Thanks
Nicolas
>    Thanks,
>       Matt
>     Is there a way to track this renumbering ? For owned vertices, I can
>     find the local index from the global one (so do old local index ->
>     global index -> new local index). For the remote ones, I'm not sure. I
>     can hash global indices, but is there a more idiomatic way ?
>     Thanks,
>     Nicolas
> experiments is infinitely more interesting than any results to which
> their experiments lead.
> -- Norbert Wiener
> https://www.cse.buffalo.edu/~knepley/ <http://www.cse.buffalo.edu/~knepley/>
