[petsc-users] Petsc on AMD EPYC
Blaise A Bourdin bourdin at lsu.edu
Fri Mar 19 11:19:47 CDT 2021
That would be great.
What would be even greater would be if I could run the same test on LSU machines (Xeon 8260).
Blaise
On Mar 19, 2021, at 10:27 AM, Jed Brown <jed at jedbrown.org<mailto:jed at jedbrown.org>> wrote:
Blaise A Bourdin <bourdin at lsu.edu<mailto:bourdin at lsu.edu>> writes:
I am pricing out a new small cluster for my group and have been out of the HW loop for a while.
Does anybody on the list have experience running petsc on recent generation AMD EPYC?
I assume that the intel will not generate optimized code for non-intel COU. How about gcc / clang?
My metric is not pure performance but rather performance over price.
I have a 2-socket 7452, which is a great price point for our sort of work. If you're purely memory bandwidth-limited, you can get fewer cores, but that doesn't save a lot of money. You'd probably want to compare pricing with the new Zen 3 chips too. I'll forward you a log file from a multigrid solver with some analysis. Suffice it to say, it matches to significantly outperforms (depending on the operation) a 2-socket Xeon 8280.
I do mostly implicit finite element codes and 90% of my walltime is KSP / SNES solves
Blaise
A.K. & Shirley Barton Professor of  Mathematics
Adjunct Professor of Mechanical Engineering
Adjunct of the Center for Computation & Technology
Louisiana State University, Lockett Hall Room 344, Baton Rouge, LA 70803, USA
Tel. +1 (225) 578 1612, Fax  +1 (225) 578 4276 Web http://www.math.lsu.edu/~bourdin
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210319/82745775/attachment.html>
