[petsc-users] using preconditioner with SLEPc
Florian Bruckner e0425375 at gmail.com
Tue Mar 9 06:07:29 CST 2021
Dear Jose,
I appended the output of eps-view for the original method and for the
method you proposed.
Unfortunately the new method does not converge. This I what i did:
es = SLEPc.EPS().create(comm=fd.COMM_WORLD)
es.setDimensions(k)
es.setType(SLEPc.EPS.Type.KRYLOVSCHUR)
es.setProblemType(SLEPc.EPS.ProblemType.PGNHEP) # Generalized Non-Hermitian
eigenproblem with positive definite B
es.setTarget(0.0)
es.setWhichEigenpairs(SLEPc.EPS.Which.TARGET_MAGNITUDE)
es.setTolerances(1e-10)
es.setOperators(self.B0, self.A0)
es.setFromOptions()
st = es.getST()
st.setPreconditionerMat(self.P0)
Is TARGET_MAGNITUDE correct? If I change it back to LARGEST_MAGNITUDE i can
reproduce the (wrong) results from before.
Why do I need the shift-invert mode at all? I thought this is only
necessary if I would like to solve for the smallest eigenmodes?
Without st.setPreconditionerMat(self.P0) the code does not work, because A0
is a matshell and the preconditioner cannot be set up.
If I use pc_type = None the method converges, but results are totally wrong
(1e-12 GHz instead of 7GHz).
What confuses me most, is that the slepc results (without target=0 and with
the precond matrix) produces nearly correct results,
which perfectly fit the results from scipy when using P0 instead of A0.
This is a strange coincidence, and looks like P0 is used somewhere instead
of A0.
thanks for your help
Florian
On Tue, Mar 9, 2021 at 10:48 AM Jose E. Roman <jroman at dsic.upv.es> wrote:
> The reason may be that it is using a direct solver instead of an iterative
> solver. What do you get for -eps_view ?
> Does the code work correctly if you comment out
> st.setPreconditionerMat(self.P0) ?
> Your approach should work, but I would first try as is done in the example
> https://slepc.upv.es/slepc-main/src/eps/tutorials/ex46.c.html
> that is, shift-and-invert with target=0 and target_magnitude.
> Jose
> > El 9 mar 2021, a las 9:07, Florian Bruckner <e0425375 at gmail.com>
> escribió:
> > Dear Jose,
> > I asked Lawrence Mitchell from the firedrake people to help me with the
> slepc update (I think they are applying some modifications for petsc, which
> is why simply updating petsc within my docker container did not work).
> > Now the latest slepc version runs and I already get some results of the
> eigenmode solver. The good thing is that the solver runs significantly
> faster. The bad thing is that the results are still wrong :-)
> > Could you have a short look at the code:
> >         es.setDimensions(k)
> Non-Hermitian eigenproblem with positive definite B
> >         es.setWhichEigenpairs(SLEPc.EPS.Which.LARGEST_MAGNITUDE)
> >         #es.setTrueResidual(True)
> >         es.setFromOptions()
> >         st = es.getST()
> > You wrote that when using shift-and-invert with target=0 the solver
> internally uses A0^{-1}*B0.
> > Nevertheless I think the precond P0 mat should be an approximation of
> A0, right?
> > This is because the solver uses the B0-inner product to preserve
> symmetry.
> > Or is the B0 missing in my code?
> > As I mentioned before, convergence of the method is extremely fast. I
> thought that maybe the tolerance is set too low, but increasing it did not
> change the situation.
> > With using setTrueResidual, there is no convergence at all.
> > Figures show the different results for the original scipy method (which
> has been compared to published results) as well as the new slepc method.
> > For some strange reason I get nearly the same (wrong) results if i
> replace A0 with P0 in the original scipy code.
> > In my case A0 is a non-local field operator and P0 only contains local
> and next-neighbour interaction.
> > Is it possible that the wrong operator (P0 instead of A0) is used
> internally?
> > best wishes
> > Florian
> > On Thu, Feb 18, 2021 at 1:00 PM Florian Bruckner <e0425375 at gmail.com>
> wrote:
> > Dear Jose,
> > thanks for your work. I just looked over the code, but I didn't have
> time to implement our solver, yet.
> > If I understand the code correctly, it allows to set a precond-matrix
> which should approximate A-sigma*B.
> > I will try to get our code running in the next few weeks. From user
> perspective it would maybe simplify things if approximations for A as well
> as B are given, since this would hide the internal ST transformations.
> > best wishes
> > Florian
> > On Tue, Feb 16, 2021 at 8:54 PM Jose E. Roman <jroman at dsic.upv.es>
> wrote:
> > Florian: I have created a MR
> https://gitlab.com/slepc/slepc/-/merge_requests/149
> > Let me know if it fits your needs.
> > Jose
> > > El 15 feb 2021, a las 18:44, Jose E. Roman <jroman at dsic.upv.es>
> escribió:
> > >> El 15 feb 2021, a las 14:53, Matthew Knepley <knepley at gmail.com>
> escribió:
> > >> On Mon, Feb 15, 2021 at 7:27 AM Jose E. Roman <jroman at dsic.upv.es>
> wrote:
> > >> I will think about the viability of adding an interface function to
> pass the preconditioner matrix.
> > >> Regarding the question about the B-orthogonality of computed vectors,
> in the symmetric solver the B-orthogonality is enforced during the
> computation, so you have guarantee that the computed vectors satisfy it.
> But if solved as non-symetric, the computed vectors may depart from
> B-orthogonality, unless the tolerance is very small.
> > >> Yes, the vectors I generate are not B-orthogonal.
> > >> Jose, do you think there is a way to reformulate what I am doing to
> use the symmetric solver, even if we only have the action of B?
> > > Yes, you can do the following:
> > >  ierr = EPSSetOperators(eps,S,NULL);CHKERRQ(ierr);   // S is your
> shell matrix A^{-1}*B
> > >  ierr = EPSSetProblemType(eps,EPS_HEP);CHKERRQ(ierr);  // symmetric
> problem though S is not symmetric
> > >  ierr = EPSSetFromOptions(eps);CHKERRQ(ierr);
> > >  ierr = EPSSetUp(eps);CHKERRQ(ierr);   // note explicitly calling
> setup here
> > >  ierr = EPSGetBV(eps,&bv);CHKERRQ(ierr);
> > >  ierr = BVSetMatrix(bv,B,PETSC_FALSE);CHKERRQ(ierr);    // replace
> solver's inner product
> > >  ierr = EPSSolve(eps);CHKERRQ(ierr);
> > > I have tried this with test1.c and it works. The computed eigenvectors
> should be B-orthogonal in this case.
> > > Jose
> > >>  Thanks,
> > >>     Matt
> > >> Jose
> > >>> El 14 feb 2021, a las 21:41, Barry Smith <bsmith at petsc.dev>
> escribió:
> > >>>  Florian,
> > >>>   I'm sorry I don't know the answers; I can only speculate. There is
> a STGetShift().
> > >>>   All I was saying is theoretically there could/should be such
> support in SLEPc.
> > >>>  Barry
> > >>>> On Feb 13, 2021, at 6:43 PM, Florian Bruckner <e0425375 at gmail.com>
> wrote:
> > >>>> Dear Barry,
> > >>>> thank you for your clarification. What I wanted to say is that even
> if I could reset the KSP operators directly I would require to know which
> transformation ST applies in order to provide the preconditioning matrix
> for the correct operator.
> > >>>> The more general solution would be that SLEPc provides the
> interface to pass the preconditioning matrix for A0 and ST applies the same
> transformations as for the operator.
> > >>>> If you write "SLEPc could provide an interface", do you mean
> someone should implement it, or should it already be possible and I am not
> using it correctly?
> > >>>> I wrote a small standalone example based on ex9.py from slepc4py,
> where i tried to use an operator.
> > >>>> best wishes
> > >>>> Florian
> > >>>> On Sat, Feb 13, 2021 at 7:15 PM Barry Smith <bsmith at petsc.dev>
> wrote:
> > >>>>> On Feb 13, 2021, at 2:47 AM, Pierre Jolivet <pierre at joliv.et>
> wrote:
> > >>>>>> On 13 Feb 2021, at 7:25 AM, Florian Bruckner <e0425375 at gmail.com>
> wrote:
> > >>>>>> Dear Jose, Dear Barry,
> > >>>>>> thanks again for your reply. One final question about the B0
> orthogonality. Do you mean that eigenvectors are not B0 orthogonal, but
> they are i*B0 orthogonal? or is there an issue with Matt's approach?
> > >>>>>> For my problem I can show that eigenvalues fulfill an
> orthogonality relation (phi_i, A0 phi_j ) = omega_i (phi_i, B0 phi_j) =
> delta_ij. This should be independent of the solving method, right?
> > >>>>>> Regarding Barry's advice this is what I first tried:
> > >>>>>> st = es.getST()
> > >>>>>> ksp = st.getKSP()
> > >>>>>> ksp.setOperators(self.A0, self.P0)
> > >>>>>> But it seems that the provided P0 is not used. Furthermore the
> interface is maybe a bit confusing if ST performs some transformation. In
> this case P0 needs to approximate A0^{-1}*B0 and not A0, right?
> > >>>>> No, you need to approximate (A0-sigma B0)^-1. If you have a null
> shift, which looks like it is the case, you end up with A0^-1.
> > >>>>  Just trying to provide more clarity with the terms.
> > >>>> If ST transforms the operator in the KSP to (A0-sigma B0) and you
> are providing the "sparse matrix from which the preconditioner is to be
> built" then you need to provide something that approximates (A0-sigma B0).
> Since the PC will use your matrix to construct a preconditioner that
> approximates the inverse of  (A0-sigma B0), you don't need to directly
> provide something that approximates (A0-sigma B0)^-1
> > >>>> Yes, I would think SLEPc could provide an interface where it
> manages "the matrix from which to construct the preconditioner" and
> transforms that matrix just like the true matrix. To do it by hand you
> simply need to know what A0 and B0 are and which sigma ST has selected and
> then you can construct your modA0 - sigma modB0 and pass it to the KSP.
> Where modA0 and modB0 are your "sparser approximations".
> > >>>>  Barry
> > >>>>>> Nevertheless I think it would be the best solution if one could
> provide P0 (approx A0) and SLEPc derives the preconditioner from this.
> Would this be hard to implement?
> > >>>>> This is what Barry’s suggestion is implementing. Don’t know why it
> doesn’t work with your Python operator though.
> > >>>>> Thanks,
> > >>>>> Pierre
> > >>>>>> best wishes
> > >>>>>> Florian
> > >>>>>> On Sat, Feb 13, 2021 at 4:19 AM Barry Smith <bsmith at petsc.dev>
> wrote:
> > >>>>>>> On Feb 12, 2021, at 2:32 AM, Florian Bruckner <
> e0425375 at gmail.com> wrote:
> > >>>>>>> Dear Jose, Dear Matt,
> > >>>>>>> I needed some time to think about your answers.
> > >>>>>>> If I understand correctly, the eigenmode solver internally uses
> A0^{-1}*B0, which is normally handled by the ST object, which creates a KSP
> solver and a corresponding preconditioner.
> > >>>>>>> What I would need is an interface to provide not only the system
> Matrix A0 (which is an operator), but also a preconditioning matrix (sparse
> approximation of the operator).
> > >>>>>>> Unfortunately this interface is not available, right?
> > >>>>>>   If SLEPc does not provide this directly it is still intended to
> be trivial to provide the "preconditioner matrix" (that is matrix from
> which the preconditioner is built). Just get the KSP from the ST object and
> use KSPSetOperators() to provide the "preconditioner matrix" .
> > >>>>>>  Barry
> > >>>>>>> Matt directly creates A0^{-1}*B0 as a matshell operator. The
> operator uses a KSP with a proper PC internally. SLEPc would directly get
> A0^{-1}*B0 and solve a standard eigenvalue problem with this modified
> operator. Did I understand this correctly?
> > >>>>>>> I have two further points, which I did not mention yet: the
> matrix B0 is Hermitian, but it is (purely) imaginary (B0.real=0). Right
> now, I am using Firedrake to set up the PETSc system matrices A0, i*B0
> (which is real). Then I convert them into ScipyLinearOperators and use
> scipy.sparse.eigsh(B0, b=A0, Minv=Minv) to calculate the eigenvalues.
> Minv=A0^-1 is also solving within scipy using a preconditioned gmres.
> Advantage of this setup is that the imaginary B0 can be handled efficiently
> and also the post-processing of the eigenvectors (which requires complex
> arithmetics) is simplified.
> > >>>>>>> Nevertheless I think that the mixing of PETSc and Scipy looks
> too complicated and is not very flexible.
> > >>>>>>> If I would use Matt's approach, could I then simply switch
> between multiple standard eigenvalue methods (e.g. LOBPCG)? or is it
> limited due to the use of matshell?
> > >>>>>>> Is there a solution for the imaginary B0, or do I have to use
> the non-hermitian methods? Is this a large performance drawback?
> > >>>>>>> thanks again,
> > >>>>>>> and best wishes
> > >>>>>>> Florian
> > >>>>>>> On Mon, Feb 8, 2021 at 3:37 PM Jose E. Roman <jroman at dsic.upv.es>
> wrote:
> > >>>>>>> The problem can be written as A0*v=omega*B0*v and you want the
> eigenvalues omega closest to zero. If the matrices were explicitly
> available, you would do shift-and-invert with target=0, that is
> > >>>>>>>  (A0-sigma*B0)^{-1}*B0*v=theta*v    for sigma=0, that is
> > >>>>>>>  A0^{-1}*B0*v=theta*v
> > >>>>>>> and you compute EPS_LARGEST_MAGNITUDE eigenvalues theta=1/omega.
> > >>>>>>> Matt: I guess you should have EPS_LARGEST_MAGNITUDE instead of
> EPS_SMALLEST_REAL in your code. Are you getting the eigenvalues you need?
> EPS_SMALLEST_REAL will give slow convergence.
> > >>>>>>> Florian: I would not recommend setting the KSP matrices
> directly, it may produce strange side-effects. We should have an interface
> function to pass this matrix. Currently there is STPrecondSetMatForPC() but
> it has two problems: (1) it is intended for STPRECOND, so cannot be used
> with Krylov-Schur, and (2) it is not currently available in the python
> interface.
> > >>>>>>> The approach used by Matt is a workaround that does not use ST,
> so you can handle linear solves with a KSP of your own.
> > >>>>>>> As an alternative, since your problem is symmetric, you could
> try LOBPCG, assuming that the leftmost eigenvalues are those that you want
> (e.g. if all eigenvalues are non-negative). In that case you could use
> STPrecondSetMatForPC(), but the remaining issue is calling it from python.
> > >>>>>>> If you are using the git repo, I could add the relevant code.
> > >>>>>>> Jose
> > >>>>>>>> El 8 feb 2021, a las 14:22, Matthew Knepley <knepley at gmail.com>
> escribió:
> > >>>>>>>> On Mon, Feb 8, 2021 at 7:04 AM Florian Bruckner <
> > >>>>>>>> Dear PETSc / SLEPc Users,
> > >>>>>>>> my question is very similar to the one posted here:
> https://lists.mcs.anl.gov/pipermail/petsc-users/2018-August/035878.html
> > >>>>>>>> The eigensystem I would like to solve looks like:
> > >>>>>>>> B0 v = 1/omega A0 v
> > >>>>>>>> B0 and A0 are both hermitian, A0 is positive definite, but only
> given as a linear operator (matshell). I am looking for the largest
> eigenvalues (=smallest omega).
> > >>>>>>>> I also have a sparse approximation P0 of the A0 operator, which
> i would like to use as precondtioner, using something like this:
> > >>>>>>>>        st = es.getST()
> > >>>>>>>>        ksp = st.getKSP()
> > >>>>>>>> Unfortunately PETSc still complains that it cannot create a
> preconditioner for a type 'python' matrix although P0.type == 'seqaij' (but
> A0.type == 'python').
> > >>>>>>>> By the way, should P0 be an approximation of A0 or does it have
> to include B0?
> > >>>>>>>> Right now I am using the krylov-schur method. Are there any
> alternatives if A0 is only given as an operator?
> > >>>>>>>> Jose can correct me if I say something wrong.
> > >>>>>>>> When I did this, I made a shell operator for the action of
> A0^{-1} B0 which has a KSPSolve() in it, so you can use your P0
> preconditioning matrix, and
> > >>>>>>>> then handed that to EPS. You can see me do it here:
> https://gitlab.com/knepley/bamg/-/blob/master/src/coarse/bamgCoarseSpace.c#L123
> > >>>>>>>> I had a hard time getting the embedded solver to work the way I
> wanted, but maybe that is the better way.
> > >>>>>>>>  Thanks,
> > >>>>>>>>     Matt
> > >>>>>>>> thanks for any advice
> > >>>>>>>> best wishes
> > >>>>>>>> Florian
> > >>>>>>>> What most experimenters take for granted before they begin
> their experiments is infinitely more interesting than any results to which
> their experiments lead.
> > >>>>>>>> -- Norbert Wiener
> > >>>>>>>> https://www.cse.buffalo.edu/~knepley/
> > >>>> <test.py>
> > >> What most experimenters take for granted before they begin their
> experiments lead.
> > >> -- Norbert Wiener
> <frequencies_scipy_P0_instead_A0.png><frequencies_slepc.png><frequencies_scipy.png>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210309/51689686/attachment-0001.html>
EPS Object: 1 MPI processes
  type: krylovschur
    50% of basis vectors kept after restart
    using the locking variant
  problem type: generalized non-symmetric eigenvalue problem with symmetric positive definite B
  selected portion of the spectrum: largest eigenvalues in magnitude
  postprocessing eigenvectors with purification
  number of eigenvalues (nev): 50
  number of column vectors (ncv): 100
  maximum dimension of projected problem (mpd): 100
  maximum number of iterations: 100
  tolerance: 1e-10
  convergence test: relative to the eigenvalue
BV Object: 1 MPI processes
  type: svec
  101 columns of global length 3076
  vector orthogonalization method: classical Gram-Schmidt
  orthogonalization refinement: if needed (eta: 0.7071)
  block orthogonalization method: GS
  non-standard inner product
  tolerance for definite inner product: 2.22045e-15
  inner product matrix:
  Mat Object: 1 MPI processes
    type: python
    rows=3076, cols=3076, bs=3076
        Python: magnumpi.field_terms.field_term.A0Operator
  doing matmult as a single matrix-matrix product
DS Object: 1 MPI processes
  type: nhep
ST Object: 1 MPI processes
  type: shift
  shift: 0.
  number of matrices: 2
  all matrices have unknown nonzero pattern
  KSP Object: (st_) 1 MPI processes
    type: preonly
    maximum iterations=10000, initial guess is zero
    tolerances:  relative=1e-08, absolute=1e-50, divergence=10000.
    left preconditioning
    using NONE norm type for convergence test
  PC Object: (st_) 1 MPI processes
    type: lu
      out-of-place factorization
      tolerance for zero pivot 2.22045e-14
      matrix ordering: nd
      factor fill ratio given 5., needed 4.36739
        Factored matrix follows:
            type: seqaij
            rows=3076, cols=3076, bs=2
            package used to perform factorization: petsc
            total: nonzeros=1905232, allocated nonzeros=1905232
              using I-node routines: found 963 nodes, limit used is 5
    linear system matrix followed by preconditioner matrix:
      type: python
    Mat Object: (st_) 1 MPI processes
      type: seqaij
      total: nonzeros=436240, allocated nonzeros=436240
      total number of mallocs used during MatSetValues calls=0
        using I-node routines: found 1417 nodes, limit used is 5
  type: krylovschur
  tolerance: 1e-10
  type: svec
    type: python
  type: nhep
  type: shift
  shift: 0.
    type: preonly
    type: lu
      matrix ordering: nd
            type: seqaij
      type: python
      type: seqaij
nconv: 58
  type: krylovschur
  selected portion of the spectrum: closest to target: 0. (in magnitude)
  tolerance: 1e-10
  type: svec
    type: python
  type: nhep
  type: shift
  shift: 0.
    type: preonly
    type: lu
      matrix ordering: nd
            type: seqaij
      type: python
      type: seqaij
  type: krylovschur
  tolerance: 1e-10
  type: svec
    type: python
  type: nhep
  type: shift
  shift: 0.
    type: preonly
    type: lu
      matrix ordering: nd
            type: seqaij
      type: python
      type: seqaij
nconv: 0
