[petsc-users] Exhausted all shared linker guesses. Could not determine how to create a shared library!
Matthew Knepley
knepley at gmail.com
Mon Mar 8 19:31:42 CST 2021
On Mon, Mar 8, 2021 at 8:23 PM Fande Kong <fdkong.jd at gmail.com> wrote:
> Thanks Matthew,
> Hmm, we still have the same issue after shutting off all unknown flags.
Oh, I was misinterpreting the error message:
ld: can't link with a main executable file
'/var/folders/tv/ljnkj46x3nq45cp9tbkc000c0000gn/T/petsc-6v1w4q4u/config.setCompilers/libconftest.dylib'
So clang did not _actually_ make a shared library, it made an executable.
Did clang-11 change the options it uses to build a shared library?
Satish, do we test with clang-11?
Matt
> Fande
> On Mon, Mar 8, 2021 at 6:07 PM Matthew Knepley <knepley at gmail.com> wrote:
>> On Mon, Mar 8, 2021 at 7:55 PM Fande Kong <fdkong.jd at gmail.com> wrote:
>>> Hi All,
>>> mpicc rejected "-fPIC". Anyone has a clue how to work around this issue?
>> The failure is at the last step
>> Executing: mpicc -o
>> /var/folders/tv/ljnkj46x3nq45cp9tbkc000c0000gn/T/petsc-6v1w4q4u/config.setCompilers/conftest
>> -fPIC
>> /var/folders/tv/ljnkj46x3nq45cp9tbkc000c0000gn/T/petsc-6v1w4q4u/config.setCompilers/conftest.o
>> -L/var/folders/tv/ljnkj46x3nq45cp9tbkc000c0000gn/T/petsc-6v1w4q4u/config.setCompilers
>> -lconftest
>> Possible ERROR while running linker: exit code 1
>> stderr:
>> for architecture x86_64
>> clang-11: error: linker command failed with exit code 1 (use -v to see
>> invocation)
>> but you have some flags stuck in which may or may not affect this. I
>> would try shutting them off:
>> LDFLAGS_LD=-pie -headerpad_max_install_names -dead_strip_dylibs -rpath
>> /Users/kongf/miniconda3/envs/moose/lib
>> -L/Users/kongf/miniconda3/envs/moose/lib
>> I cannot tell exactly why clang is failing because it does not report a
>> specific error.
>> Thanks,
>> Matt
>> The log was attached.
>>> Thanks so much,
>>> Fande
>> experiments lead.
>> -- Norbert Wiener
>> https://www.cse.buffalo.edu/~knepley/
>> <http://www.cse.buffalo.edu/~knepley/>
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210308/7e26be4a/attachment.html>
