[petsc-users] Exhausted all shared linker guesses. Could not determine how to create a shared library!
Fande Kong fdkong.jd at gmail.com
Mon Mar 8 19:23:22 CST 2021
Thanks Matthew,
Hmm, we still have the same issue after shutting off all unknown flags.
Fande
On Mon, Mar 8, 2021 at 6:07 PM Matthew Knepley <knepley at gmail.com> wrote:
> On Mon, Mar 8, 2021 at 7:55 PM Fande Kong <fdkong.jd at gmail.com> wrote:
>> Hi All,
>> mpicc rejected "-fPIC". Anyone has a clue how to work around this issue?
> The failure is at the last step
> Executing: mpicc  -o
> /var/folders/tv/ljnkj46x3nq45cp9tbkc000c0000gn/T/petsc-6v1w4q4u/config.setCompilers/conftest
>   -fPIC
> /var/folders/tv/ljnkj46x3nq45cp9tbkc000c0000gn/T/petsc-6v1w4q4u/config.setCompilers/conftest.o
> -L/var/folders/tv/ljnkj46x3nq45cp9tbkc000c0000gn/T/petsc-6v1w4q4u/config.setCompilers
> -lconftest
> Possible ERROR while running linker: exit code 1
> stderr:
> ld: can't link with a main executable file
> '/var/folders/tv/ljnkj46x3nq45cp9tbkc000c0000gn/T/petsc-6v1w4q4u/config.setCompilers/libconftest.dylib'
> for architecture x86_64
> clang-11: error: linker command failed with exit code 1 (use -v to see
> invocation)
> but you have some flags stuck in which may or may not affect this. I would
> try shutting them off:
> LDFLAGS_LD=-pie -headerpad_max_install_names -dead_strip_dylibs -rpath
> /Users/kongf/miniconda3/envs/moose/lib
> -L/Users/kongf/miniconda3/envs/moose/lib
> I cannot tell exactly why clang is failing because it does not report a
> specific error.
>   Thanks,
>      Matt
> The log was attached.
>> Thanks so much,
>> Fande
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210308/ba7a3229/attachment-0001.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210308/ba7a3229/attachment-0001.obj>
