[petsc-users] DMPlex tetrahedra facets orientation
Matthew Knepley
knepley at gmail.com
Sun Mar 7 15:30:41 CST 2021
On Sun, Mar 7, 2021 at 4:13 PM Nicolas Barral <
nicolas.barral at math.u-bordeaux.fr> wrote:
> On 07/03/2021 16:54, Matthew Knepley wrote:
> > On Sun, Mar 7, 2021 at 8:52 AM Nicolas Barral
> > <nicolas.barral at math.u-bordeaux.fr
> > <mailto:nicolas.barral at math.u-bordeaux.fr>> wrote:
> > Matt,
> > Thanks for your answer.
> > However, DMPlexComputeCellGeometryFVM does not compute what I need
> > (normals of height 1 entities). I can't find any function doing
> > that, is
> > there one ?
> > The normal[] in DMPlexComputeCellGeometryFVM() is exactly what you want.
> > What does not look right to you?
> So it turns out it's not what I want because I need non-normalized
> normals. It doesn't seem like I can easily retrieve the norm, can I?
You just want area-weighted normals I think, which means that you just
multiply by the area,
which comes back in the same function.
Matt
> If not, I'll fallback to computing them by hand for now. Is the
> following assumption safe or do I have to use DMPlexGetOrientedFace?
> > if I call P0P1P2P3 a tet and note x the cross product,
> > P3P2xP3P1 is the outward normal to face P1P2P3
> > P0P2xP0P3 " P0P2P3
> > P3P1xP3P0 " P0P1P3
> > P0P1xP0P2 " P0P1P2
> Thanks
> Nicolas
> > Thanks,
> > Matt
> > So far I've been doing it by hand, and after a lot of experimenting
> the
> > past weeks, it seems that if I call P0P1P2P3 a tetrahedron and note x
> > the cross product,
> > P0P2xP0P3 " P0P2P3
> > P3P1xP3P0 " P0P1P3
> > P0P1xP0P2 " P0P1P2
> > Have I been lucky but can't expect it to be true ?
> > (Alternatively, there is a link between the normals and the element
> > Jacobian, but I don't know the formula and can find them)
> > Thanks,
> > Nicolas
> > On 08/02/2021 15:19, Matthew Knepley wrote:
> > > On Mon, Feb 8, 2021 at 6:01 AM Nicolas Barral
> > <mailto:nicolas.barral at math.u-bordeaux.fr>>> wrote:
> > > Hi all,
> > > Can I make any assumption on the orientation of triangular
> > facets in a
> > > tetrahedral plex ? I need the inward facet normals. Do I need
> > to use
> > > DMPlexGetOrientedFace or can I rely on either the tet vertices
> > > ordering,
> > > or the faces ordering ? Could DMPlexGetRawFaces_Internal be
> > enough ?
> > > You can do it by hand, but you have to account for the face
> > orientation
> > > relative to the cell. That is what
> > > DMPlexGetOrientedFace() does. I think it would be easier to use
> the
> > > function below.
> > > Alternatively, is there a function that computes the normals
> > - without
> > > bringing out the big guns ?
> > > This will compute the normals
> https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/DMPLEX/DMPlexComputeCellGeometryFVM.html
> > > Should not be too heavy weight.
> > > THanks,
> > > Matt
> > > Thanks
> > > Nicolas
> > > What most experimenters take for granted before they begin their
> > > experiments is infinitely more interesting than any results to
> which
> > > their experiments lead.
> > > -- Norbert Wiener
> > > https://www.cse.buffalo.edu/~knepley/
> > <http://www.cse.buffalo.edu/~knepley/>
> > experiments is infinitely more interesting than any results to which
> > -- Norbert Wiener
> > https://www.cse.buffalo.edu/~knepley/ <
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210307/6235235b/attachment.html>
