[petsc-users] DMPlex tetrahedra facets orientation
Nicolas Barral
nicolas.barral at math.u-bordeaux.fr
Sun Mar 7 15:13:38 CST 2021
On 07/03/2021 16:54, Matthew Knepley wrote:
> On Sun, Mar 7, 2021 at 8:52 AM Nicolas Barral
> <nicolas.barral at math.u-bordeaux.fr
> <mailto:nicolas.barral at math.u-bordeaux.fr>> wrote:
> Matt,
> Thanks for your answer.
> However, DMPlexComputeCellGeometryFVM does not compute what I need
> (normals of height 1 entities). I can't find any function doing
> that, is
> there one ?
> The normal[] in DMPlexComputeCellGeometryFVM() is exactly what you want.
> What does not look right to you?
So it turns out it's not what I want because I need non-normalized
normals. It doesn't seem like I can easily retrieve the norm, can I?
If not, I'll fallback to computing them by hand for now. Is the
following assumption safe or do I have to use DMPlexGetOrientedFace?
> if I call P0P1P2P3 a tet and note x the cross product,
> P3P2xP3P1 is the outward normal to face P1P2P3
> P0P2xP0P3 " P0P2P3
> P3P1xP3P0 " P0P1P3
> P0P1xP0P2 " P0P1P2
Thanks
Nicolas
> Thanks,
> Matt
> So far I've been doing it by hand, and after a lot of experimenting the
> past weeks, it seems that if I call P0P1P2P3 a tetrahedron and note x
> the cross product,
> P0P2xP0P3 " P0P2P3
> P3P1xP3P0 " P0P1P3
> P0P1xP0P2 " P0P1P2
> Have I been lucky but can't expect it to be true ?
> (Alternatively, there is a link between the normals and the element
> Jacobian, but I don't know the formula and can find them)
> Thanks,
> Nicolas
> On 08/02/2021 15:19, Matthew Knepley wrote:
> > On Mon, Feb 8, 2021 at 6:01 AM Nicolas Barral
> <mailto:nicolas.barral at math.u-bordeaux.fr>>> wrote:
> > Hi all,
> > Can I make any assumption on the orientation of triangular
> facets in a
> > tetrahedral plex ? I need the inward facet normals. Do I need
> to use
> > DMPlexGetOrientedFace or can I rely on either the tet vertices
> > ordering,
> > or the faces ordering ? Could DMPlexGetRawFaces_Internal be
> enough ?
> > You can do it by hand, but you have to account for the face
> orientation
> > relative to the cell. That is what
> > DMPlexGetOrientedFace() does. I think it would be easier to use the
> > function below.
> > Alternatively, is there a function that computes the normals
> - without
> > bringing out the big guns ?
> > This will compute the normals
> https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/DMPLEX/DMPlexComputeCellGeometryFVM.html
> > Should not be too heavy weight.
> > THanks,
> > Matt
> > Thanks
> > Nicolas
> > What most experimenters take for granted before they begin their
> > experiments is infinitely more interesting than any results to which
> > their experiments lead.
> > -- Norbert Wiener
> > https://www.cse.buffalo.edu/~knepley/
> <http://www.cse.buffalo.edu/~knepley/>
> -- Norbert Wiener
> https://www.cse.buffalo.edu/~knepley/ <http://www.cse.buffalo.edu/~knepley/>
