[petsc-users] Loading external array data into PETSc
    Matthew Knepley
    knepley at gmail.com
    Wed Mar  3 16:01:57 CST 2021
On Wed, Mar 3, 2021 at 4:23 PM Smit Thijs <thijs.smit at hest.ethz.ch> wrote:
> Hi All,
> I would like to readin a fairly large external vector into PETSc to be
> used further. My idea was to write a hdf5 file using Python with the vector
> data. Then read that hdf5 file into PETSc using PetscViewerHDF5Open and
> VecLoad. Is this the advised way or is there a better alternative to
> achieve the same (getting this external array data into PETSc)?
I think there are at least two nice ways to do this:
1) Use HDF5. Here you have to name your vector to match the HDF5 object
2) Use raw binary. This is a specific PETSc format, but it is fast and
simple.
    Matt
> Best regards,
> Thijs Smit
> PhD Candidate
> ETH Zurich
> Institute for Biomechanics
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210303/0927a8db/attachment.html>
