[petsc-users] DMPlex read partitionned Gmsh
Thibault Bridel-Bertomeu thibault.bridelbertomeu at gmail.com
Tue Mar 2 07:15:31 CST 2021
Dear Matthew,
Sorry it took me so long to answer.
Thank you for the details on the HDF5 reader, I think I can work with that
indeed. Gotta find a way to write the *.msh in the custom HDF5 format first
but as you say I might just go with a snippet based on PETSc, this way I'm
sure it will be consistent.
Cheers,
Thibault
Le mar. 23 févr. 2021 à 11:50, Matthew Knepley <knepley at gmail.com> a écrit :
> On Tue, Feb 23, 2021 at 2:37 AM Thibault Bridel-Bertomeu <
> thibault.bridelbertomeu at gmail.com> wrote:
>> Dear all,
>> I was wondering if there was a plan in motion to implement yet another
>> possibility for DMPlexCreateGmshFromFile: read a group of foo_*.msh
>> generated from a partition done directly in Gmsh ?
> What we have implemented now is a system that reads a mesh in parallel
> from disk into a naive partition, then repartitions and redistributes.
> We have a paper about this strategy: https://arxiv.org/abs/2004.08729 .
> Right now it is only implemented in HDF5. This is mainly because:
> 1) Parallel block reads are easy in HDF5.
> 2) We use it for checkpointing as well as load, and it is flexible enough
> for this
> 3) Label information can be stored in a scalable way
> It is easy to convert from GMsh to HDF5 (it's a few lines of PETSc). The
> GMsh format is not ideal for parallelism, and in fact the GMsh reader
> was also using MED, which is an HDF5 format. We originally wrote an MED
> reader, but the documentation and support for the library were
> not up to snuff, so we went with a custom HDF5 format.
>   Is this helpful?
>      Matt
>> Have a great day,
>> Thibault B.-B.
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210302/ea899db3/attachment.html>
