[petsc-users] creation of parallel dmplex from a partitioned mesh
Mon Mar 1 19:11:53 CST 2021
On Mon, Mar 1, 2021 at 4:41 PM Cameron Smith <smithc11 at rpi.edu> wrote:
> Thank you.  That makes sense.
> Using DMPlexPointLocalRef from petsc master worked for me; time to debug.
Let me know if it turns out that Plex is making an assumption that is
non-intuitive, or if you need something
that would make conversion easier.
     Matt
> https://www.mcs.anl.gov/petsc/petsc-master/docs/manualpages/DMPLEX/DMPlexPointLocalRef.html
> -Cameron
> On 2/26/21 8:32 AM, Matthew Knepley wrote:
> > On Thu, Feb 25, 2021 at 4:57 PM Cameron Smith <smithc11 at rpi.edu
> > <mailto:smithc11 at rpi.edu>> wrote:
> >     Hello,
> >     Bringing this thread back from the dead...
> >     We made progress with creation of a distributed dmplex that matches
> our
> >     source mesh partition and are in need of help writing values into a
> >     vector created from the dmplex object.
> >     As discussed previously, we have created a DMPlex instance using:
> >     DMPlexCreateFromCellListPetsc(...)
> >     DMGetPointSF(...)
> >     PetscSFSetGraph(...)
> >     which gives us a distribution of mesh vertices and elements in the DM
> >     object that matches the element-based partition of our unstructured
> >     mesh.
> >     We then mark mesh vertices on the geometric model boundary using
> >     DMSetLabelValue(...) and a map from our mesh vertices to dmplex
> points
> >     (created during dmplex definition of vtx coordinates).
> >     Following this, we create a section for vertices:
> >      >     DMPlexGetDepthStratum(dm, 0, &vStart, &vEnd);
> >      >     PetscSectionCreate(PetscObjectComm((PetscObject) dm), &s);
> >      >     PetscSectionSetNumFields(s, 1);
> >      >     PetscSectionSetFieldComponents(s, 0, 1);
> >      >     PetscSectionSetChart(s, vStart, vEnd);
> >      >     for(PetscInt v = vStart; v < vEnd; ++v) {
> >      >         PetscSectionSetDof(s, v, 1);
> >      >         PetscSectionSetFieldDof(s, v, 0, 1);
> >      >     PetscSectionSetUp(s);
> >      >     DMSetLocalSection(dm, s);
> >      >     PetscSectionDestroy(&s);
> >      >     DMGetGlobalSection(dm,&s); //update the global section
> >     We then try to write values into a local Vec for the on-process
> >     vertices
> >     (roots and leaves in sf terms) and hit an ordering problem.
> >     Specifically, we make the following sequence of calls:
> >     DMGetLocalVector(dm,&bloc);
> >     VecGetArrayWrite(bloc, &bwrite);
> >     //for loop to write values to bwrite
> >     VecRestoreArrayWrite(bloc, &bwrite);
> >     DMLocalToGlobal(dm,bloc,INSERT_VALUES,b);
> >     DMRestoreLocalVector(dm,&bloc);
> > There is an easy way to get diagnostics here. For the local vector
> >    DMGetLocalSection(dm, &s);
> >    PetscSectionGetOffset(s, v, &off);
> > will give you the offset into the array you got from VecGetArrayWrite()
> > for that vertex. You can get this wrapped up using
> DMPlexPointLocalWrite()
> > which is what I tend to use for this type of stuff.
> > For the global vector
> >    DMGetGlobalSection(dm, &gs);
> >    PetscSectionGetOffset(gs, v, &off);
> > will give you the offset into the portion of the global array that is
> > stored in this process.
> > If you do not own the values for this vertex, the number is negative,
> > and it is actually
> > -(i+1) if the index i is the valid one on the owning process.
> >     Visualizing Vec 'b' in paraview, and the
> >     original mesh, tells us that the dmplex topology and geometry (the
> >     vertex coordinates) are correct but that the order we write values is
> >     wrong (not total garbage... but clearly shifted).
> > We do not make any guarantees that global orders match local orders.
> > However, by default
> > we number up global unknowns in rank order, leaving out the dofs that we
> > not owned.
> > Does this make sense?
> >    Thanks,
> >       Matt
> >     Is there anything obviously wrong in our described approach?  I
> suspect
> >     the section creation is wrong and/or we don't understand the order of
> >     entries in the array returned by VecGetArrayWrite.
> >     Please let us know if other info is needed.  We are happy to share
> the
> >     relevant source code.
> >     Thank-you,
> >     Cameron
> >     On 8/25/20 8:34 AM, Cameron Smith wrote:
> >      > On 8/24/20 4:57 PM, Matthew Knepley wrote:
> >      >> On Mon, Aug 24, 2020 at 4:27 PM Jed Brown <jed at jedbrown.org
> >     <mailto:jed at jedbrown.org>
> >      >> <mailto:jed at jedbrown.org <mailto:jed at jedbrown.org>>> wrote:
> >      >>     Cameron Smith <smithc11 at rpi.edu <mailto:smithc11 at rpi.edu>
> >     <mailto:smithc11 at rpi.edu <mailto:smithc11 at rpi.edu>>> writes:
> >      >>      > We made some progress with star forest creation but still
> >     have
> >      >>     work to do.
> >      >>      > We revisited DMPlexCreateFromCellListParallelPetsc(...)
> >     and got it
> >      >>      > working by sequentially partitioning the vertex
> >     coordinates across
> >      >>      > processes to satisfy the 'vertexCoords' argument.
> >     Specifically,
> >      >>     rank 0
> >      >>      > has the coordinates for vertices with global id 0:N/P-1,
> >     rank 1
> >      >> has
> >      >>      > N/P:2*(N/P)-1, and so on (N is the total number of global
> >      >>     vertices and P
> >      >>      > is the number of processes).
> >      >>      > The consequences of the sequential partition of vertex
> >      >>     coordinates in
> >      >>      > subsequent solver operations is not clear.  Does it make
> >     process i
> >      >>      > responsible for computations and communications
> >     associated with
> >      >>     global
> >      >>      > vertices i*(N/P):(i+1)*(N/P)-1 ?  We assumed it does and
> >     wanted
> >      >>     to confirm.
> >      >>     Yeah, in the sense that the corners would be owned by the
> >     rank you
> >      >>     place them on.
> >      >>     But many methods, especially high-order, perform assembly via
> >      >>     non-overlapping partition of elements, in which case the
> >      >>     "computations" happen where the elements are (with any
> required
> >      >>     vertex data for the closure of those elements being sent to
> >     the rank
> >      >>     handling the element).
> >      >>     Note that a typical pattern would be to create a parallel
> DMPlex
> >      >>     with a naive distribution, then repartition/distribute it.
> >      >> As Jed says, CreateParallel() just makes the most naive
> >     partition of
> >      >> vertices because we have no other information. Once
> >      >> the mesh is made, you call DMPlexDistribute() again to reduce
> >     the edge
> >      >> cut.
> >      >>    Thanks,
> >      >>       Matt
> >      > Thank you.
> >      > This is being used for PIC code with low order 2d elements whose
> >     mesh is
> >      > partitioned to minimize communications during particle
> >     operations.  This
> >      > partition will not be ideal for the field solve using petsc so
> we're
> >      > exploring alternatives that will require minimal data movement
> >     between
> >      > the two partitions.  Towards that, we'll keep pursuing the SF
> >     creation.
> >      > -Cameron
> > What most experimenters take for granted before they begin their
> > experiments is infinitely more interesting than any results to which
> > their experiments lead.
> > -- Norbert Wiener
> > https://www.cse.buffalo.edu/~knepley/ <
> http://www.cse.buffalo.edu/~knepley/>
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210301/2fc69dcd/attachment-0001.html>
