[petsc-users] creation of parallel dmplex from a partitioned mesh
Cameron Smith smithc11 at rpi.edu
Mon Mar 1 15:42:49 CST 2021
Thank you.  That makes sense.
Using DMPlexPointLocalRef from petsc master worked for me; time to debug.
https://www.mcs.anl.gov/petsc/petsc-master/docs/manualpages/DMPLEX/DMPlexPointLocalRef.html
-Cameron
On 2/26/21 8:32 AM, Matthew Knepley wrote:
> On Thu, Feb 25, 2021 at 4:57 PM Cameron Smith <smithc11 at rpi.edu
> <mailto:smithc11 at rpi.edu>> wrote:
>     Hello,
>     Bringing this thread back from the dead...
>     We made progress with creation of a distributed dmplex that matches our
>     source mesh partition and are in need of help writing values into a
>     vector created from the dmplex object.
>     As discussed previously, we have created a DMPlex instance using:
>     DMPlexCreateFromCellListPetsc(...)
>     DMGetPointSF(...)
>     PetscSFSetGraph(...)
>     which gives us a distribution of mesh vertices and elements in the DM
>     object that matches the element-based partition of our unstructured
>     mesh.
>     We then mark mesh vertices on the geometric model boundary using
>     DMSetLabelValue(...) and a map from our mesh vertices to dmplex points
>     (created during dmplex definition of vtx coordinates).
>     Following this, we create a section for vertices:
>      >     DMPlexGetDepthStratum(dm, 0, &vStart, &vEnd);
>      >     PetscSectionCreate(PetscObjectComm((PetscObject) dm), &s);
>      >     PetscSectionSetNumFields(s, 1);
>      >     PetscSectionSetFieldComponents(s, 0, 1);
>      >     PetscSectionSetChart(s, vStart, vEnd);
>      >     for(PetscInt v = vStart; v < vEnd; ++v) {
>      >         PetscSectionSetDof(s, v, 1);
>      >         PetscSectionSetFieldDof(s, v, 0, 1);
>      >     PetscSectionSetUp(s);
>      >     DMSetLocalSection(dm, s);
>      >     PetscSectionDestroy(&s);
>      >     DMGetGlobalSection(dm,&s); //update the global section
>     We then try to write values into a local Vec for the on-process
>     vertices
>     (roots and leaves in sf terms) and hit an ordering problem.
>     Specifically, we make the following sequence of calls:
>     DMGetLocalVector(dm,&bloc);
>     VecGetArrayWrite(bloc, &bwrite);
>     //for loop to write values to bwrite
>     VecRestoreArrayWrite(bloc, &bwrite);
>     DMLocalToGlobal(dm,bloc,INSERT_VALUES,b);
>     DMRestoreLocalVector(dm,&bloc);
> There is an easy way to get diagnostics here. For the local vector
>    DMGetLocalSection(dm, &s);
>    PetscSectionGetOffset(s, v, &off);
> will give you the offset into the array you got from VecGetArrayWrite()
> for that vertex. You can get this wrapped up using DMPlexPointLocalWrite()
> which is what I tend to use for this type of stuff.
> For the global vector
>    DMGetGlobalSection(dm, &gs);
>    PetscSectionGetOffset(gs, v, &off);
> will give you the offset into the portion of the global array that is
> stored in this process.
> If you do not own the values for this vertex, the number is negative,
> and it is actually
> -(i+1) if the index i is the valid one on the owning process.
>     Visualizing Vec 'b' in paraview, and the
>     original mesh, tells us that the dmplex topology and geometry (the
>     vertex coordinates) are correct but that the order we write values is
>     wrong (not total garbage... but clearly shifted).
> We do not make any guarantees that global orders match local orders.
> However, by default
> we number up global unknowns in rank order, leaving out the dofs that we
> not owned.
> Does this make sense?
>    Thanks,
>       Matt
>     Is there anything obviously wrong in our described approach?  I suspect
>     the section creation is wrong and/or we don't understand the order of
>     entries in the array returned by VecGetArrayWrite.
>     Please let us know if other info is needed.  We are happy to share the
>     relevant source code.
>     Thank-you,
>     Cameron
>     On 8/25/20 8:34 AM, Cameron Smith wrote:
>      > On 8/24/20 4:57 PM, Matthew Knepley wrote:
>      >> On Mon, Aug 24, 2020 at 4:27 PM Jed Brown <jed at jedbrown.org
>     <mailto:jed at jedbrown.org>
>      >> <mailto:jed at jedbrown.org <mailto:jed at jedbrown.org>>> wrote:
>      >>     Cameron Smith <smithc11 at rpi.edu <mailto:smithc11 at rpi.edu>
>     <mailto:smithc11 at rpi.edu <mailto:smithc11 at rpi.edu>>> writes:
>      >>      > We made some progress with star forest creation but still
>     have
>      >>     work to do.
>      >>      > We revisited DMPlexCreateFromCellListParallelPetsc(...)
>     and got it
>      >>      > working by sequentially partitioning the vertex
>     coordinates across
>      >>      > processes to satisfy the 'vertexCoords' argument.
>     Specifically,
>      >>     rank 0
>      >>      > has the coordinates for vertices with global id 0:N/P-1,
>     rank 1
>      >> has
>      >>      > N/P:2*(N/P)-1, and so on (N is the total number of global
>      >>     vertices and P
>      >>      > is the number of processes).
>      >>      > The consequences of the sequential partition of vertex
>      >>     coordinates in
>      >>      > subsequent solver operations is not clear.  Does it make
>     process i
>      >>      > responsible for computations and communications
>     associated with
>      >>     global
>      >>      > vertices i*(N/P):(i+1)*(N/P)-1 ?  We assumed it does and
>     wanted
>      >>     to confirm.
>      >>     Yeah, in the sense that the corners would be owned by the
>     rank you
>      >>     place them on.
>      >>     But many methods, especially high-order, perform assembly via
>      >>     non-overlapping partition of elements, in which case the
>      >>     "computations" happen where the elements are (with any required
>      >>     vertex data for the closure of those elements being sent to
>     the rank
>      >>     handling the element).
>      >>     Note that a typical pattern would be to create a parallel DMPlex
>      >>     with a naive distribution, then repartition/distribute it.
>      >> As Jed says, CreateParallel() just makes the most naive
>     partition of
>      >> vertices because we have no other information. Once
>      >> the mesh is made, you call DMPlexDistribute() again to reduce
>     the edge
>      >> cut.
>      >>    Thanks,
>      >>       Matt
>      > Thank you.
>      > This is being used for PIC code with low order 2d elements whose
>     mesh is
>      > partitioned to minimize communications during particle
>     operations.  This
>      > partition will not be ideal for the field solve using petsc so we're
>      > exploring alternatives that will require minimal data movement
>     between
>      > the two partitions.  Towards that, we'll keep pursuing the SF
>     creation.
>      > -Cameron
> experiments is infinitely more interesting than any results to which
> their experiments lead.
> -- Norbert Wiener
> https://www.cse.buffalo.edu/~knepley/ <http://www.cse.buffalo.edu/~knepley/>
