[petsc-users] parallel HDF5 output of DMDA data with dof>1
Matteo Semplice
matteo.semplice at uninsubria.it
Wed Jul 21 07:04:05 CDT 2021
Hi all.
I have asked Thibault (author or this report on HDF5
https://lists.mcs.anl.gov/pipermail/petsc-users/2021-July/044045.html
<https://eur01.safelinks.protection.outlook.com/?url=https%3A%2F%2Flists.mcs.anl.gov%2Fpipermail%2Fpetsc-users%2F2021-July%2F044045.html&data=04%7C01%7Cmatteo.semplice%40uninsubria.it%7C0443f8463c604f1122fb08d9485ac463%7C9252ed8bdffc401c86ca6237da9991fa%7C0%7C0%7C637620376946153189%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C1000&sdata=w%2BAY%2FEZ7pPUintp77eEN1vGJVB3R0VX1Pzp9U0xV4E4%3D&reserved=0>
some days before mine) to run my MWE and it does not work for him either.
Further, I have tried on another machine of mine with --download-hdf5
--download-mpich and still it is not working.
A detailed report follows at the end of this message.
I am wondering if something is wrong/incompatible with the HDF5 version
of VecView, at least when the Vec is associated with a DMDA. Of course
it might just be that I didn't manage to write a correct xdmf, but I
can't spot the mistake...
I am of course available to run tests in order to find/fix this problem.
Best
Matteo
On 16/07/21 12:27, Matteo Semplice wrote:
> Il 15/07/21 17:44, Matteo Semplice ha scritto:
>> Hi.
>> When I write (HDF5 viewer) a vector associated to a DMDA with 1 dof,
>> the output is independent of the number of cpus used.
>> However, for a DMDA with dof=2, the output seems to be correct when I
>> run on 1 or 2 cpus, but is scrambled when I run with 4 cpus. Judging
>> from the ranges of the data, each field gets written to the correct
>> part, and its the data witin the field that is scrambled. Here's my MWE:
>> #include <petscversion.h>
>> #include <petscdmda.h>
>> #include <petscviewer.h>
>> #include <petscsys.h>
>> #include <petscviewerhdf5.h>
>> int main(int argc, char **argv) {
>> PetscErrorCode ierr;
>> ierr = PetscInitialize(&argc,&argv,(char*)0,help); CHKERRQ(ierr);
>> PetscInt Nx=11;
>> PetscInt Ny=11;
>> PetscScalar dx = 1.0 / (Nx-1);
>> PetscScalar dy = 1.0 / (Ny-1);
>> DM dmda;
>> ierr = DMDACreate2d(PETSC_COMM_WORLD,
>> DM_BOUNDARY_NONE,DM_BOUNDARY_NONE,
>> DMDA_STENCIL_STAR,
>> Nx,Ny, //global dim
>> PETSC_DECIDE,PETSC_DECIDE, //n proc on each dim
>> 2,1, //dof, stencil width
>> NULL, NULL, //n nodes per direction on each cpu
>> &dmda); CHKERRQ(ierr);
>> ierr = DMSetFromOptions(dmda); CHKERRQ(ierr);
>> ierr = DMSetUp(dmda); CHKERRQ(ierr); CHKERRQ(ierr);
>> ierr = DMDASetUniformCoordinates(dmda, 0.0, 1.0, 0.0, 1.0, 0.0,
>> 1.0); CHKERRQ(ierr);
>> ierr = DMDASetFieldName(dmda,0,"s"); CHKERRQ(ierr);
>> ierr = DMDASetFieldName(dmda,1,"c"); CHKERRQ(ierr);
>> DMDALocalInfo daInfo;
>> ierr = DMDAGetLocalInfo(dmda,&daInfo); CHKERRQ(ierr);
>> IS *is;
>> DM *daField;
>> ierr = DMCreateFieldDecomposition(dmda,NULL, NULL, &is, &daField);
>> CHKERRQ(ierr);
>> Vec U0;
>> ierr = DMCreateGlobalVector(dmda,&U0); CHKERRQ(ierr);
>> //Initial data
>> typedef struct{ PetscScalar s,c;} data_type;
>> data_type **u;
>> ierr = DMDAVecGetArray(dmda,U0,&u); CHKERRQ(ierr);
>> for (PetscInt j=daInfo.ys; j<daInfo.ys+daInfo.ym; j++){
>> PetscScalar y = j*dy;
>> for (PetscInt i=daInfo.xs; i<daInfo.xs+daInfo.xm; i++){
>> PetscScalar x = i*dx;
>> u[j][i].s = x+2.*y;
>> u[j][i].c = 10. + 2.*x*x+y*y;
>> ierr = DMDAVecRestoreArray(dmda,U0,&u); CHKERRQ(ierr);
>> PetscViewer viewer;
>> ierr =
>> PetscViewerHDF5Open(PETSC_COMM_WORLD,"solutionSC.hdf5",FILE_MODE_WRITE,&viewer);
>> CHKERRQ(ierr);
>> Vec uField;
>> ierr = VecGetSubVector(U0,is[0],&uField); CHKERRQ(ierr);
>> PetscObjectSetName((PetscObject) uField, "S");
>> ierr = VecView(uField,viewer); CHKERRQ(ierr);
>> ierr = VecRestoreSubVector(U0,is[0],&uField); CHKERRQ(ierr);
>> ierr = VecGetSubVector(U0,is[1],&uField); CHKERRQ(ierr);
>> PetscObjectSetName((PetscObject) uField, "C");
>> ierr = VecRestoreSubVector(U0,is[1],&uField); CHKERRQ(ierr);
>> ierr = PetscViewerDestroy(&viewer); CHKERRQ(ierr);
>> ierr = PetscFinalize();
>> return ierr;
>> and my xdmf file
>> <?xml version="1.0" ?>
>> <Xdmf
>> xmlns:xi="https://eur01.safelinks.protection.outlook.com/?url=http%3A%2F%2Fwww.w3.org%2F2001%2FXInclude&data=04%7C01%7Cmatteo.semplice%40uninsubria.it%7C7c270ed0c49c4f8d950708d948444e1c%7C9252ed8bdffc401c86ca6237da9991fa%7C0%7C0%7C637620280470927505%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C1000&sdata=q45En4ULjQX6H%2F1ZgzUxgKmDk7Y7jK0K2IuWDHpr4HM%3D&reserved=0"
>> Version="2.0">
>> <Domain>
>> <Grid GridType="Collection" CollectionType="Temporal">
>> <Time TimeType="List">
>> <DataItem Dimensions="1">1.0</DataItem>
>> </Time>
>> <Grid GridType="Uniform" Name="domain">
>> <Topology TopologyType="2DCoRectMesh" Dimensions="11 11"/>
>> <Geometry GeometryType="ORIGIN_DXDY">
>> <DataItem Format="XML" NumberType="Float"
>> Dimensions="2">0.0 0.0</DataItem>
>> Dimensions="2">0.1 0.1</DataItem>
>> </Geometry>
>> <Attribute Name="S" Center="Node" AttributeType="Scalar">
>> <DataItem Format="HDF" Precision="8" Dimensions="11
>> 11">solutionSC.hdf5:/S</DataItem>
>> </Attribute>
>> <Attribute Name="C" Center="Node" AttributeType="Scalar">
>> 11">solutionSC.hdf5:/C</DataItem>
>> </Attribute>
>> </Grid>
>> </Grid>
>> </Domain>
>> </Xdmf>
>> Steps to reprduce: run code and open the xdmf with paraview. If the
>> code was run with 1,2 or 3 cpus, the data are correct (except the
>> plane xy has become the plane yz), but with 4 cpus the data are
>> scrambled.
>> Does anyone have any insight?
>> (I am using Petsc Release Version 3.14.2, but I can compile a newer
>> one if you think it's important.)
> Hi,
> I have a small update on this issue.
> First, it is still here with version 3.15.2.
> Secondly, I have run the code under valgrind and
> - for 1 or 2 processes, I get no errors
> - for 4 processes, 3 out of 4, trigger the following
> ==25921== Conditional jump or move depends on uninitialised value(s)
> ==25921== at 0xB3D6259: ??? (in
> /usr/lib/x86_64-linux-gnu/openmpi/lib/openmpi3/mca_fcoll_two_phase.so)
> ==25921== by 0xB3D85C8: mca_fcoll_two_phase_file_write_all (in
> ==25921== by 0xAAEB29B: mca_common_ompio_file_write_at_all (in
> /usr/lib/x86_64-linux-gnu/openmpi/lib/libmca_common_ompio.so.41.9.0)
> ==25921== by 0xB316605: mca_io_ompio_file_write_at_all (in
> /usr/lib/x86_64-linux-gnu/openmpi/lib/openmpi3/mca_io_ompio.so)
> ==25921== by 0x73C7FE7: PMPI_File_write_at_all (in
> /usr/lib/x86_64-linux-gnu/openmpi/lib/libmpi.so.40.10.3)
> ==25921== by 0x69E8700: H5FD__mpio_write (H5FDmpio.c:1466)
> ==25921== by 0x670D6EB: H5FD_write (H5FDint.c:248)
> ==25921== by 0x66DA0D3: H5F__accum_write (H5Faccum.c:826)
> ==25921== by 0x684F091: H5PB_write (H5PB.c:1031)
> ==25921== by 0x66E8055: H5F_shared_block_write (H5Fio.c:205)
> ==25921== by 0x6674538: H5D__chunk_collective_fill (H5Dchunk.c:5064)
> ==25921== by 0x6674538: H5D__chunk_allocate (H5Dchunk.c:4736)
> ==25921== by 0x668C839: H5D__init_storage (H5Dint.c:2473)
> ==25921== Uninitialised value was created by a heap allocation
> ==25921== at 0x483577F: malloc (vg_replace_malloc.c:299)
> ==25921== by 0xB3D6155: ??? (in
> Does anyone have any hint on what might be causing this?
> Is this the "buggy MPI-IO" that Matt was mentioning in
> https://eur01.safelinks.protection.outlook.com/?url=https%3A%2F%2Flists.mcs.anl.gov%2Fpipermail%2Fpetsc-users%2F2021-July%2F044138.html&data=04%7C01%7Cmatteo.semplice%40uninsubria.it%7C7c270ed0c49c4f8d950708d948444e1c%7C9252ed8bdffc401c86ca6237da9991fa%7C0%7C0%7C637620280470927505%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C1000&sdata=gPAbClDgJ1toQxzVVnoRCrgPBNR2tjw%2BGfdrxv%2FwVmY%3D&reserved=0?
> I am using the release branch (commit c548142fde) and I have
> configured with --download-hdf5; configure finds the installed openmpi
> 3.1.3 from Debian buster. The relevant lines from configure.log are
> MPI:
> Version: 3
> Mpiexec: mpiexec --oversubscribe
> OMPI_VERSION: 3.1.3
> hdf5:
> Version: 1.12.0
> Includes: -I/home/matteo/software/petsc/opt/include
> Library: -Wl,-rpath,/home/matteo/software/petsc/opt/lib
> -L/home/matteo/software/petsc/opt/lib -lhdf5hl_fortran -lhdf5_fortran
> -lhdf5_hl -lhdf5
Update 1: on a different machine, I have compiled petsc (release branch)
with --download-hdf5 and --download-mpich and I have tried 3d HDF5
output at the end of my simulation. All's fine for 1 or 2 CPUs, but the
output is funny for more CPUs. The smooth solution gives rise to an
output that renders like little bricks, as if the data were written
doing the 3 nested loops in the wrong order.
Update 2: Thibault was kind enough to compile and run my MWE on his
setup and he gets a crash related to the VecView with the HDF5 viewer.
Here's the report that he sent me.
On 21/07/21 10:59, Thibault Bridel-Bertomeu wrote:
Hi Matteo,
I ran your test, and actually it does not give me garbage for a number
of processes greater than 1, it straight-up crashes ...
Here is the error log for 2 processes :
Compiled with Petsc Development GIT revision:
v3.14.4-671-g707297fd510GIT Date: 2021-02-24 22:50:05 +0000
[1]PETSC ERROR:
[1]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation,
probably memory access out of range
[1]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
[1]PETSC ERROR: or see
https://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind
<https://eur01.safelinks.protection.outlook.com/?url=https%3A%2F%2Fwww.mcs.anl.gov%2Fpetsc%2Fdocumentation%2Ffaq.html%23valgrind&data=04%7C01%7Cmatteo.semplice%40uninsubria.it%7C4046642d31454b13ad8708d94c299c2c%7C9252ed8bdffc401c86ca6237da9991fa%7C0%7C0%7C637624563866796549%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C1000&sdata=ZFBJWmDy6QUnBGYC2mHWBz%2F%2Bx%2BYan2Pw4ub%2FhR8PvK4%3D&reserved=0>
[1]PETSC ERROR: or try http://valgrind.org
<https://eur01.safelinks.protection.outlook.com/?url=http%3A%2F%2Fvalgrind.org%2F&data=04%7C01%7Cmatteo.semplice%40uninsubria.it%7C4046642d31454b13ad8708d94c299c2c%7C9252ed8bdffc401c86ca6237da9991fa%7C0%7C0%7C637624563866806506%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C1000&sdata=5aITh8yt1ihtXQzuhBzG5vYy8ZeQhDq%2Bhj3aLMGjEvc%3D&reserved=0>
on GNU/linux and Apple Mac OS X to find memory corruption errors
[1]PETSC ERROR: likely location of problem given in stack below
[1]PETSC ERROR: ---------------------Stack Frames
[1]PETSC ERROR: Note: The EXACT line numbers in the stack are not available,
[1]PETSC ERROR: INSTEAD the line number of the start of the function
[1]PETSC ERROR: is given.
[1]PETSC ERROR: [1] H5Dcreate2 line 716
/ccc/work/cont001/ocre/bridelbert/04-PETSC/src/vec/vec/impls/mpi/pdvec.c
[1]PETSC ERROR: [1] VecView_MPI_HDF5 line 622
[1]PETSC ERROR: [1] VecView_MPI line 815
[1]PETSC ERROR: [1] VecView line 580
/ccc/work/cont001/ocre/bridelbert/04-PETSC/src/vec/vec/interface/vector.c
[1]PETSC ERROR: --------------------- Error Message
[1]PETSC ERROR: Signal received
[1]PETSC ERROR: See https://www.mcs.anl.gov/petsc/documentation/faq.html
<https://eur01.safelinks.protection.outlook.com/?url=https%3A%2F%2Fwww.mcs.anl.gov%2Fpetsc%2Fdocumentation%2Ffaq.html&data=04%7C01%7Cmatteo.semplice%40uninsubria.it%7C4046642d31454b13ad8708d94c299c2c%7C9252ed8bdffc401c86ca6237da9991fa%7C0%7C0%7C637624563866816465%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C1000&sdata=Obo%2BDTzUQK%2BAzcBn7rmfrZwiFIhxv%2B9SAF5BQPVLCAg%3D&reserved=0>
for trouble shooting.
[1]PETSC ERROR: Petsc Development GIT revision:
[1]PETSC ERROR:
/ccc/work/cont001/ocre/bridelbert/MWE_HDF5_Output/testHDF5 on anamed
r1login by bridelbert Wed Jul 21 10:57:11 2021
[1]PETSC ERROR: Configure options --with-clean=1
--prefix=/ccc/work/cont001/ocre/bridelbert/04-PETSC/build_uns3D_inti
--with-make-np=8 --with-windows-graphics=0 --with-debugging=1
--download-mpich-shared=0 --with-x=0 --with-pthread=0 --with-valgrind=0
--PETSC_ARCH=INTI_UNS3D
--with-fc=/ccc/products/openmpi-2.0.4/gcc--8.3.0/default/bin/mpifort
--with-cc=/ccc/products/openmpi-2.0.4/gcc--8.3.0/default/bin/mpicc
--with-cxx=/ccc/products/openmpi-2.0.4/gcc--8.3.0/default/bin/mpicxx
--with-openmp=0
--download-sowing=/ccc/work/cont001/ocre/bridelbert/v1.1.26-p1.tar.gz
--download-metis=/ccc/work/cont001/ocre/bridelbert/git.metis.tar.gz
--download-parmetis=/ccc/work/cont001/ocre/bridelbert/git.parmetis.tar.gz
--download-fblaslapack=/ccc/work/cont001/ocre/bridelbert/git.fblaslapack.tar.gz
--with-cmake-dir=/ccc/products/cmake-3.13.3/system/default
--download-hdf5=/ccc/work/cont001/ocre/bridelbert/hdf5-1.12.0.tar.bz2
--download-zlib=/ccc/work/cont001/ocre/bridelbert/zlib-1.2.11.tar.gz
[1]PETSC ERROR: #1 User provided function() line 0 inunknown file
[1]PETSC ERROR: Checking the memory for corruption.
MPI_ABORT was invoked on rank 1 in communicator MPI_COMM_WORLD
with errorcode 50176059.
NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes.
You may or may not see output from other processes, depending on
exactly when Open MPI kills them.
[0]PETSC ERROR:
[0]PETSC ERROR: Caught signal number 15 Terminate: Some process (or the
batch system) has told this process to end
[0]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
[0]PETSC ERROR: or see
<https://eur01.safelinks.protection.outlook.com/?url=https%3A%2F%2Fwww.mcs.anl.gov%2Fpetsc%2Fdocumentation%2Ffaq.html%23valgrind&data=04%7C01%7Cmatteo.semplice%40uninsubria.it%7C4046642d31454b13ad8708d94c299c2c%7C9252ed8bdffc401c86ca6237da9991fa%7C0%7C0%7C637624563866816465%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C1000&sdata=EzrdlWi7y%2FWU7LsRuqGd%2BAp%2B17bdX8bOxKbszA15k5E%3D&reserved=0>
[0]PETSC ERROR: or try http://valgrind.org
<https://eur01.safelinks.protection.outlook.com/?url=http%3A%2F%2Fvalgrind.org%2F&data=04%7C01%7Cmatteo.semplice%40uninsubria.it%7C4046642d31454b13ad8708d94c299c2c%7C9252ed8bdffc401c86ca6237da9991fa%7C0%7C0%7C637624563866826422%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C1000&sdata=o%2BFJ7bq2dp5bokp%2BKQj1efXC7Dqfbl0yBjHi2xobvug%3D&reserved=0>
[0]PETSC ERROR: likely location of problem given in stack below
[0]PETSC ERROR: ---------------------Stack Frames
[0]PETSC ERROR: Note: The EXACT line numbers in the stack are not available,
[0]PETSC ERROR: INSTEAD the line number of the start of the function
[0]PETSC ERROR: is given.
[0]PETSC ERROR: [0] H5Dcreate2 line 716
[0]PETSC ERROR: [0] VecView_MPI_HDF5 line 622
[0]PETSC ERROR: [0] VecView_MPI line 815
[0]PETSC ERROR: [0] VecView line 580
[0]PETSC ERROR: --------------------- Error Message
[0]PETSC ERROR: Signal received
[0]PETSC ERROR: See https://www.mcs.anl.gov/petsc/documentation/faq.html
<https://eur01.safelinks.protection.outlook.com/?url=https%3A%2F%2Fwww.mcs.anl.gov%2Fpetsc%2Fdocumentation%2Ffaq.html&data=04%7C01%7Cmatteo.semplice%40uninsubria.it%7C4046642d31454b13ad8708d94c299c2c%7C9252ed8bdffc401c86ca6237da9991fa%7C0%7C0%7C637624563866826422%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C1000&sdata=TZ3qXboAnlDtWc6%2Bh5V175dPVzqCUhTTyFdCtm3J7lM%3D&reserved=0>
[0]PETSC ERROR: Petsc Development GIT revision:
[0]PETSC ERROR:
[0]PETSC ERROR: Configure options --with-clean=1
--with-openmp=0
[0]PETSC ERROR: #1 User provided function() line 0 inunknown file
[r1login:24498] 1 more process has sent help message help-mpi-api.txt /
mpi-abort
[r1login:24498] Set MCA parameter "orte_base_help_aggregate" to 0 to see
all help / error messages
I am starting to wonder if the PETSc configure script installs HDF5 with
MPI correctly at all ...
Here is my conf :
Compilers:
C Compiler:
/ccc/products/openmpi-2.0.4/gcc--8.3.0/default/bin/mpicc-fPIC -Wall
-Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas
-fstack-protector -fvisibility=hidden -g3
Version: gcc (GCC) 8.3.0
C++ Compiler:
/ccc/products/openmpi-2.0.4/gcc--8.3.0/default/bin/mpicxx-Wall
-fstack-protector -fvisibility=hidden -g-fPIC
Version: g++ (GCC) 8.3.0
Fortran Compiler:
/ccc/products/openmpi-2.0.4/gcc--8.3.0/default/bin/mpifort-fPIC -Wall
-ffree-line-length-0 -Wno-unused-dummy-argument -g
Version: GNU Fortran (GCC) 8.3.0
Linkers:
Shared linker:
/ccc/products/openmpi-2.0.4/gcc--8.3.0/default/bin/mpicc-shared-fPIC
-Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas
Dynamic linker:
Libraries linked against: -lquadmath -lstdc++ -ldl
BlasLapack:
Library:-Wl,-rpath,/ccc/work/cont001/ocre/bridelbert/04-PETSC/build_uns3D_inti/lib
-L/ccc/work/cont001/ocre/bridelbert/04-PETSC/build_uns3D_inti/lib
-lflapack -lfblas
uses 4 byte integers
MPI:
Version:3
Mpiexec: /ccc/products/openmpi-2.0.4/gcc--8.3.0/default/bin/mpiexec
OMPI_VERSION: 2.0.4
fblaslapack:
zlib:
Version:1.2.11
Includes:
-I/ccc/work/cont001/ocre/bridelbert/04-PETSC/build_uns3D_inti/include
-L/ccc/work/cont001/ocre/bridelbert/04-PETSC/build_uns3D_inti/lib -lz
hdf5:
Version:1.12.0
Includes:
-lhdf5hl_fortran -lhdf5_fortran -lhdf5_hl -lhdf5
cmake:
Version:3.13.3
/ccc/products/cmake-3.13.3/system/default/bin/cmake
metis:
Version:5.1.0
Includes:
-L/ccc/work/cont001/ocre/bridelbert/04-PETSC/build_uns3D_inti/lib -lmetis
parmetis:
Version:4.0.3
Includes:
-L/ccc/work/cont001/ocre/bridelbert/04-PETSC/build_uns3D_inti/lib -lparmetis
regex:
sowing:
Version:1.1.26
/ccc/work/cont001/ocre/bridelbert/04-PETSC/INTI_UNS3D/bin/bfort
Language used to compile PETSc: C
Please don't hesitate to ask if you need something else from me !
Cheers,
Thibault
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210721/e88930fa/attachment-0001.html>
