[petsc-users] HDF5 DM and VecView with MPI :: Crash
Thibault Bridel-Bertomeu
thibault.bridelbertomeu at gmail.com
Mon Jul 5 11:50:30 CDT 2021
Dear all,
I keep having this error on one of the supercomputers I have access to :
[1]PETSC ERROR: The EXACT line numbers in the error traceback are not
available.
[1]PETSC ERROR: instead the line number of the start of the function is
given.
[1]PETSC ERROR: #1 H5Dcreate2() at
/ccc/work/cont001/ocre/bridelbert/05-PETSC/src/vec/vec/impls/mpi/pdvec.c:690
[1]PETSC ERROR: #2 VecView_MPI_HDF5() at
/ccc/work/cont001/ocre/bridelbert/05-PETSC/src/vec/vec/impls/mpi/pdvec.c:594
[1]PETSC ERROR: #3 VecView_MPI() at
/ccc/work/cont001/ocre/bridelbert/05-PETSC/src/vec/vec/impls/mpi/pdvec.c:787
[1]PETSC ERROR: #4 VecView() at
/ccc/work/cont001/ocre/bridelbert/05-PETSC/src/vec/vec/interface/vector.c:576
[1]PETSC ERROR: #5 DMPlexCoordinatesView_HDF5_Internal() at
/ccc/work/cont001/ocre/bridelbert/05-PETSC/src/dm/impls/plex/plexhdf5.c:560
[1]PETSC ERROR: #6 DMPlexView_HDF5_Internal() at
/ccc/work/cont001/ocre/bridelbert/05-PETSC/src/dm/impls/plex/plexhdf5.c:802
[1]PETSC ERROR: #7 DMView_Plex() at
/ccc/work/cont001/ocre/bridelbert/05-PETSC/src/dm/impls/plex/plex.c:1366
[1]PETSC ERROR: #8 DMView() at
/ccc/work/cont001/ocre/bridelbert/05-PETSC/src/dm/interface/dm.c:954
[1]PETSC ERROR: --------------------- Error Message
The configure options are as follow :
[1]PETSC ERROR: Configure options --with-clean=1
--prefix=/ccc/work/cont001/ocre/bridelbert/05-PETSC/build_uns3D_inti
--with-make-np=8 --with-windows-graphics=0 --with-debugging=1
--download-mpich-shared=0 --with-x=0 --with-pthread=0 --with-valgrind=0
--PETSC_ARCH=INTI_UNS3D
--with-fc=/ccc/products/openmpi-4.0.3/gcc--8.3.0/default/bin/mpifort
--with-cc=/ccc/products/openmpi-4.0.3/gcc--8.3.0/default/bin/mpicc
--with-cxx=/ccc/products/openmpi-4.0.3/gcc--8.3.0/default/bin/mpicxx
--with-openmp=0
--download-sowing=/ccc/work/cont001/ocre/bridelbert/v1.1.26-p2.tar.gz
--download-metis=/ccc/work/cont001/ocre/bridelbert/git.metis.tar.gz
--download-parmetis=/ccc/work/cont001/ocre/bridelbert/git.parmetis.tar.gz
--download-fblaslapack=/ccc/work/cont001/ocre/bridelbert/git.fblaslapack.tar.gz
--with-cmake-dir=/ccc/products/cmake-3.13.3/system/default
--download-hdf5=/ccc/work/cont001/ocre/bridelbert/hdf5-1.12.0.tar.bz2
--download-netcdf=/ccc/work/cont001/ocre/bridelbert/netcdf-4.5.0.tar.gz
--download-pnetcdf=/ccc/work/cont001/ocre/bridelbert/pnetcdf-1.12.1.tar.gz
--download-exodusii=/ccc/work/cont001/ocre/bridelbert/v2021-01-20.tar.gz
--download-zlib=/ccc/work/cont001/ocre/bridelbert/zlib-1.2.11.tar.gz
The piece of code that is responsible is that one :
call PetscViewerHDF5Open(PETSC_COMM_WORLD,
"debug_initmesh.h5", FILE_MODE_WRITE, hdf5Viewer, ierr); CHKERRA(ierr)
call PetscViewerPushFormat(hdf5Viewer,
PETSC_VIEWER_HDF5_XDMF, ierr); CHKERRA(ierr)
call DMView(dm, hdf5Viewer, ierr); CHKERRA(ierr)
call PetscViewerPopFormat(hdf5Viewer, ierr); CHKERRA(ierr)
call PetscViewerDestroy(hdf5Viewer, ierr); CHKERRA(ierr)
I tried with gcc, intel compiler, openmpi 2.x.x or openmpi 4.x.x ... same
problems ... can anyone please advise ? It's starting to make me quite
crazy ... x(
Thank you !!!
Thibault
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210705/f41e3989/attachment.html>
