[petsc-users] Question about MatGetSubMatrix
Barry Smith
bsmith at petsc.dev
Fri Jul 16 21:17:33 CDT 2021
Zakariae,
MatGetSubMatrix() was removed a long time ago, the routine is now MatCreateSubMatrix() but it does not work in way you had hoped. There is currently no mechanism to move values you put into the sub matrix back into the original larger matrix (though perhaps there should be?).
Please look at MatCreateSubMatrixVirtual() and also MatCreateNest() to see if either of those approaches satisfy your needs.
Please let us know if there are extensions that would be useful for you to accomplish what you need.
Barry
> On Jul 16, 2021, at 7:45 PM, Jorti, Zakariae via petsc-users <petsc-users at mcs.anl.gov> wrote:
> Hello,
> I have a matrix A = [A00 , A01 ; A10, A11].
> I extract the submatrix A11 with MatGetSubMatrix.
> I only know the global IS is1 and is2, so to get A11 I call:
> MatGetSubMatrix(A,is2,is2,MAT_INITIAL_MATRIX,&A11);
> I want to modify A11 and update the changes on the global matrix A but I could not find any MatRestoreSubMatrix routine.
> Is there something similar to VecGetSubVector and VecRestoreSubVector for matrices that uses only global indices?
> Many thanks.
> Best regards,
> Zakariae
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210716/58239345/attachment.html>
