[petsc-users] MatZeroRows changes my sparsity pattern
Alexander Lindsay
alexlindsay239 at gmail.com
Thu Jul 15 10:51:29 CDT 2021
On Thu, Jul 15, 2021 at 8:46 AM Fande Kong <fdkong.jd at gmail.com> wrote:
> "if (a->keepnonzeropattern)" branch does not change ilen so that
> A->ops->assemblyend will be fine. It would help if you made sure that
> elements have been inserted for these rows before you call MatZeroRows.
So this is the crux of the problem. In ex11 let's say that I had not insert
a value at (0,5) but I know I'm going to later and I've preallocated the
space for it. MatZeroValues will erase that preallocation with its call to
MatAssemblyEnd with MAT_FINAL_ASSEMBLY regardless of the value of
keepnonzeropattern.
> However, I am not sure it is necessary to call A->ops->assemblyend if we
> already require a->keepnonzeropattern. That being said, we might have
> something like this
> *diff --git a/src/mat/impls/aij/seq/aij.c b/src/mat/impls/aij/seq/aij.c*
> *index 42c93a82b1..3f20a599d6 100644*
> *--- a/src/mat/impls/aij/seq/aij.c*
> *+++ b/src/mat/impls/aij/seq/aij.c*
> @@ -2203,7 +2203,9 @@ PetscErrorCode MatZeroRows_SeqAIJ(Mat A,PetscInt
> N,const PetscInt rows[],PetscSc
> #if defined(PETSC_HAVE_DEVICE)
> if (A->offloadmask != PETSC_OFFLOAD_UNALLOCATED) A->offloadmask =
> PETSC_OFFLOAD_CPU;
> #endif
> - ierr = (*A->ops->assemblyend)(A,MAT_FINAL_ASSEMBLY);CHKERRQ(ierr);
> + if (!a->keepnonzeropattern) {
> + ierr = (*A->ops->assemblyend)(A,MAT_FINAL_ASSEMBLY);CHKERRQ(ierr);
> PetscFunctionReturn(0);
> Fande
> On Thu, Jul 15, 2021 at 9:30 AM Stefano Zampini <stefano.zampini at gmail.com>
> wrote:
>> Alexander
>> Do you have a small code to reproduce the issue?
>> Below is the output using a PETSc example (src/mat/tests/ex11). The
>> pattern is kept.
>> kl-18448:tests szampini$ ./ex11
>> Mat Object: 1 MPI processes
>> type: seqaij
>> row 0: (0, 5.)
>> row 1: (0, -1.) (1, 4.) (2, -1.) (6, -1.)
>> row 2: (2, 5.)
>> row 3: (2, -1.) (3, 4.) (4, -1.) (8, -1.)
>> row 4: (4, 5.)
>> row 5: (0, -1.) (5, 4.) (6, -1.) (10, -1.)
>> row 6: (6, 5.)
>> row 7: (2, -1.) (6, -1.) (7, 4.) (8, -1.) (12, -1.)
>> row 8: (8, 5.)
>> row 9: (4, -1.) (8, -1.) (9, 4.) (14, -1.)
>> row 10: (10, 5.)
>> row 11: (6, -1.) (10, -1.) (11, 4.) (12, -1.) (16, -1.)
>> row 12: (12, 5.)
>> row 13: (8, -1.) (12, -1.) (13, 4.) (14, -1.) (18, -1.)
>> row 14: (14, 5.)
>> row 15: (10, -1.) (15, 4.) (16, -1.) (20, -1.)
>> row 16: (16, 5.)
>> row 17: (12, -1.) (16, -1.) (17, 4.) (18, -1.) (22, -1.)
>> row 18: (18, 5.)
>> row 19: (14, -1.) (18, -1.) (19, 4.) (24, -1.)
>> row 20: (20, 5.)
>> row 21: (16, -1.) (20, -1.) (21, 4.) (22, -1.)
>> row 22: (22, 5.)
>> row 23: (18, -1.) (22, -1.) (23, 4.) (24, -1.)
>> row 24: (19, -1.) (23, -1.) (24, 4.)
>> kl-18448:tests szampini$ ./ex11 -keep_nonzero_pattern
>> type: seqaij
>> row 0: (0, 5.) (1, 0.) (5, 0.)
>> row 2: (1, 0.) (2, 5.) (3, 0.) (7, 0.)
>> row 4: (3, 0.) (4, 5.) (9, 0.)
>> row 6: (1, 0.) (5, 0.) (6, 5.) (7, 0.) (11, 0.)
>> row 8: (3, 0.) (7, 0.) (8, 5.) (9, 0.) (13, 0.)
>> row 10: (5, 0.) (10, 5.) (11, 0.) (15, 0.)
>> row 12: (7, 0.) (11, 0.) (12, 5.) (13, 0.) (17, 0.)
>> row 14: (9, 0.) (13, 0.) (14, 5.) (19, 0.)
>> row 16: (11, 0.) (15, 0.) (16, 5.) (17, 0.) (21, 0.)
>> row 18: (13, 0.) (17, 0.) (18, 5.) (19, 0.) (23, 0.)
>> row 20: (15, 0.) (20, 5.) (21, 0.)
>> row 22: (17, 0.) (21, 0.) (22, 5.) (23, 0.)
>> On Jul 15, 2021, at 4:41 PM, Alexander Lindsay <alexlindsay239 at gmail.com>
>> wrote:
>> My interpretation of the documentation page of MatZeroRows is that if
>> I've set MAT_KEEP_NONZERO_PATTERN to true, then my sparsity pattern
>> shouldn't be changed by a call to it, e.g. a->imax should not change.
>> However, at least for sequential matrices, MatAssemblyEnd is called with
>> MAT_FINAL_ASSEMBLY at the end of MatZeroRows_SeqAIJ and that does indeed
>> change my sparsity pattern. Is my interpretation of the documentation page
>> wrong?
>> Alex
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210715/e0e06627/attachment.html>
