[petsc-users] download zlib error
Mark Adams mfadams at lbl.gov
Tue Jul 6 19:48:41 CDT 2021
I see this:
                          Trying to download
http://www.zlib.net/zlib-1.2.11.tar.gz for ZLIB
                          Building and installing zlib; this may take
several minutes
         UNABLE to CONFIGURE with GIVEN OPTIONS    (see configure.log for
details):
Error building/install zlib files from
/gpfs/alpine/csc314/scratch/adams/petsc/arch-spock-opt-cray-kokkos/externalpackages/zlib-1.2.11/zlib
to
And I did look in the configure log and saw these suggestions, but I was so
confused by this output that I did not want to chase it down.
I will try this --download-zlib=/yourselectedlocation/zlib-1.2.11.tar.gz
stuff.
On Tue, Jul 6, 2021 at 6:42 PM Barry Smith <bsmith at petsc.dev> wrote:
>   Mark,
>    You can try what the configure error message should be suggesting (it
> is not clear if that is being printed to your screen or no).
> ERROR: Unable to download package ZLIB from:
> * If URL specified manually - perhaps there is a typo?
> * If your network is disconnected - please reconnect and rerun ./configure
> * Or perhaps you have a firewall blocking the download
> * You can run with --with-packages-download-dir=/adirectory and
> ./configure will instruct you what packages to download manually
> * or you can download the above URL manually, to
>   and use the configure option:
>   Barry
> > On Jul 6, 2021, at 4:29 PM, Mark Adams <mfadams at lbl.gov> wrote:
> > I am getting some sort of error in build zlib on Spock at ORNL.
> > Other libraries are downloaded and I am sure the network is fine.
> > Any ideas?
> > Thanks,
> > Mark
> > <configure.log>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210706/4d8493d8/attachment.html>
