[petsc-users] Step size for adaptive stepper when running on several MPI threads
Tue Jan 19 09:18:52 CST 2021
On Tue, Jan 19, 2021 at 10:16 AM Roland Richter <roland.richter at ntnu.no>
wrote:
> Hei,
> during recent experiments with the adaptive stepper in odeint I noticed
> that the step size used for each step can vary if I am using more than
> one thread at the same time (i.e. thread 1 can have a different step
> size than thread 2 when doing the same step). This is not suitable for
> my project, after the function calculating the right hand side relies on
> having the same step size for each thread.
> Before starting deeper experiments with the adaptive steppers in PETSc,
> I therefore wanted to ask if those steppers synchronize the step size of
> the sub-steps between the different mpi processes at each step, or if not?
Yes, the timestep is the same across the communicator that you create the
TS with.
     Matt
> Thanks!
> Regards,
> Roland
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210119/413a6787/attachment.html>
