[petsc-users] Kokkos with OpenMP
Mark Adams
mfadams at lbl.gov
Sun Jan 17 21:39:16 CST 2021
> Here is the problem. You set --CXXOPTFLAGS="-g -O0 -fPIC -fopenmp" to
> indicate how to compile for OpenMP but when ./configure checks the
> installed KokkosKernel include files it uses CXXPPFLAGS. (Since you
> provided the flag CXXOPTFLAGS ./configure never determines the flag to put
> into CXXPPFLAGS.
> It is more desirable if you do not provide -fPIC -fopenmp. ./configure
> will figure them out for you.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210117/850f5252/attachment-0001.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210117/850f5252/attachment-0001.obj>
