[petsc-users] Error of MatMPIAIJSetPreallocation
Thu Jan 14 14:30:04 CST 2021
On Thu, Jan 14, 2021 at 11:58 AM Qin Lu via petsc-users <
petsc-users at mcs.anl.gov> wrote:
> Hello,
> My program got error 55 from calling MatMPIAIJSetPreallocation with Petsc
> version 3.12.5, what does this error mean? Interestingly, the same program
> using an older version 3.4.2 works fine. I did make necessary interface
> change in my program when I upgraded to 3.12.5.
1) You should always call CHKERRQ(ierr) after a Petsc call. Then you will
get the full error message and stack to send in.
2) Your error code is here:
  https://gitlab.com/petsc/petsc/-/blob/v3.12.5/include/petscerror.h#L17
3) It is a memory error. You asked for more memory than your machine could
allocate.
     Matt
> Thanks in advance for your help.
> Regards,
> Qin
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210114/08c451b7/attachment.html>
