[petsc-users] Caught signal number 11 SEGV
Francesco Brarda
brardafrancesco at gmail.com
Tue Feb 23 02:51:27 CST 2021
Hi!
I am very new to the PETSc world. I am working with a GitHub repo that uses PETSc together with Stan (a statistics open source software), here <https://discourse.mc-stan.org/t/using-petsc-library-together-with-stan/17550> you can find the discussion.
It has been defined a functor <https://github.com/IvanYashchuk/stan-math-petsc/blob/stan-petsc/stan/math/prim/fun/stan_petsc_interface.hpp> to convert EigenVector to PetscVec and viceversa, both sequentially and in parallel.
The file <https://github.com/IvanYashchuk/stan-math-petsc/blob/stan-petsc/stan/math/rev/functor/petsc_functor.hpp> using these functions does the conversions with the sequential setting. I changed to those using MPI, that is from EigenVectorToPetscVecSeq to EigenVectorToPetscVecMPI and so on because I want to evaluate the scaling.
Running the example with mpirun -n 5 examples/rosenbrock/rosenbrock optimize in the debug mode I get the error Caught signal number 11 SEGV. I therefore used the option -start_in_debugger and I get the following:
[2]PETSC ERROR: ------------------------------------------------------------------------
[2]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation, probably memory access out of range
[2]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
[2]PETSC ERROR: or see https://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind
[2]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac OS X to find memory corruption errors
[2]PETSC ERROR: likely location of problem given in stack below
[2]PETSC ERROR: --------------------- Stack Frames ------------------------------------
[2]PETSC ERROR: Note: The EXACT line numbers in the stack are not available,
[2]PETSC ERROR: INSTEAD the line number of the start of the function
[2]PETSC ERROR: is given.
[3]PETSC ERROR: ------------------------------------------------------------------------
[3]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation, probably memory access out of range
[3]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
[3]PETSC ERROR: or see https://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind
[3]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac OS X to find memory corruption errors
[3]PETSC ERROR: likely location of problem given in stack below
[3]PETSC ERROR: --------------------- Stack Frames ------------------------------------
[3]PETSC ERROR: Note: The EXACT line numbers in the stack are not available,
[3]PETSC ERROR: INSTEAD the line number of the start of the function
[3]PETSC ERROR: is given.
[3]PETSC ERROR: PetscAbortErrorHandler: User provided function() line 0 in unknown file (null)
To prevent termination, change the error handler using PetscPushErrorHandler()
[2]PETSC ERROR: PetscAbortErrorHandler: User provided function() line 0 in unknown file (null)
= BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES
= PID 22939 RUNNING AT srvulx13
= EXIT CODE: 134
= CLEANING UP REMAINING PROCESSES
= YOU CAN IGNORE THE BELOW CLEANUP MESSAGES
YOUR APPLICATION TERMINATED WITH THE EXIT STRING: Aborted (signal 6)
This typically refers to a problem with your application.
Please see the FAQ page for debugging suggestions
I read the documentation regarding the PetscAbortErrorHandler, but I do not know where should I use it. How can I solve the problem?
I hope I have been clear enough.
Attached you can find also my configure.log and make.log files.
Best,
Francesco
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210223/a1702e6c/attachment-0003.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210223/a1702e6c/attachment-0002.obj>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210223/a1702e6c/attachment-0004.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210223/a1702e6c/attachment-0003.obj>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210223/a1702e6c/attachment-0005.html>
