[petsc-users] insufficient virtual memory?
Matthew Knepley
knepley at gmail.com
Wed Feb 17 19:27:29 CST 2021
On Wed, Feb 17, 2021 at 8:23 PM Park, Heeho via petsc-users <
petsc-users at mcs.anl.gov> wrote:
> Hi PETSc developers,
> Have you seen this error message?
> forrtl: severe (41): insufficient virtual memory
I believe this is an OS setting, independent of the code itself, which
explains the difference you see between
machines. This also suggests asking the local sysadmin for your cluster.
Matt
> We are running about 36 million degrees of freedom ( ~ 2.56 GB) and it is
> failing with the error message on our HPC systems.
> Ironically, it runs on our laptop (super slow.)
> type: seqbaij
> rows=46251272, cols=46251272
> total: nonzeros=323046210, allocated nonzeros=323046210
> total number of mallocs used during MatSetValues calls=0
> block size is 1
> Does anyone have experience encountering this problem?
> Thanks,
> Heeho Daniel Park
> Sandia National Laboratories
> Org: 08844, R&D
> Work: 505-844-1319
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210217/3b2c1233/attachment.html>
