[petsc-users] shell preconditioner for Schur complement
Wed Feb 10 15:23:05 CST 2021
On Wed, Feb 10, 2021 at 4:05 PM Elena Travaglia <
elena.travaglia at edu.unito.it> wrote:
> Thanks for the link.
> We have set a Schur factorization of type FULL, and we passed it when we
> run the code with
>  -pc_fieldsplit_schur_fact_type full
> Here there is the output of -ksp_view
> KSP Object: 1 MPI processes
>   type: fgmres
>     restart=30, using Classical (unmodified) Gram-Schmidt
> Orthogonalization with no iterative refinement
>     happy breakdown tolerance 1e-30
>   maximum iterations=1, initial guess is zero
>   tolerances:  relative=1e-08, absolute=1e-50, divergence=10000.
>   right preconditioning
>   using UNPRECONDITIONED norm type for convergence test
> PC Object: 1 MPI processes
>   type: fieldsplit
>     FieldSplit with Schur preconditioner, factorization FULL
>     Preconditioner for the Schur complement formed from A11
>     Split info:
>     Split number 0 Defined by IS
>     Split number 1 Defined by IS
>     KSP solver for A00 block
>       KSP Object: (fieldsplit_0_) 1 MPI processes
>         type: gmres
>         maximum iterations=10000, initial guess is zero
>         tolerances:  relative=1e-05, absolute=1e-50, divergence=10000.
>         left preconditioning
>         using PRECONDITIONED norm type for convergence test
>       PC Object: (fieldsplit_0_) 1 MPI processes
>         type: ilu
>           out-of-place factorization
>           0 levels of fill
>           tolerance for zero pivot 2.22045e-14
>           matrix ordering: natural
>           factor fill ratio given 1., needed 1.
>             Factored matrix follows:
>               Mat Object: 1 MPI processes
>                 type: seqaij
>                 rows=44, cols=44
>                 package used to perform factorization: petsc
>                 total: nonzeros=482, allocated nonzeros=482
>                 total number of mallocs used during MatSetValues calls=0
>                   using I-node routines: found 13 nodes, limit used is 5
>         linear system matrix = precond matrix:
>         Mat Object: (fieldsplit_0_) 1 MPI processes
>           type: seqaij
>           rows=44, cols=44
>     KSP solver for S = A11 - A10 inv(A00) A01
>       KSP Object: (fieldsplit_1_) 1 MPI processes
>         type: gmres
>         tolerances:  relative=1e-09, absolute=1e-50, divergence=10000.
>       PC Object: (fieldsplit_1_) 1 MPI processes
>         type: shell
>           no name
>         linear system matrix followed by preconditioner matrix:
>         Mat Object: (fieldsplit_1_) 1 MPI processes
>           type: schurcomplement
>           rows=20, cols=20
>             Schur complement A11 - A10 inv(A00) A01
>             A11
>                 type: seqaij
>                 rows=20, cols=20
>                 total: nonzeros=112, allocated nonzeros=112
>                   using I-node routines: found 10 nodes, limit used is 5
>             A10
>                 type: seqaij
>                 rows=20, cols=44
>                 total: nonzeros=160, allocated nonzeros=160
>             KSP of A00
>                 type: gmres
> divergence=10000.
>                 type: ilu
>                   0 levels of fill
>                         type: seqaij
>                         rows=44, cols=44
> calls=0
> used is 5
>                   type: seqaij
>                   rows=44, cols=44
>             A01
>                 type: seqaij
>                 rows=44, cols=20
>                 total: nonzeros=156, allocated nonzeros=156
>                   using I-node routines: found 12 nodes, limit used is 5
>           type: seqaij
>           rows=20, cols=20
>     type: seqaij
>     rows=64, cols=64
>     total: nonzeros=910, allocated nonzeros=2432
>     total number of mallocs used during MatSetValues calls=128
>       using I-node routines: found 23 nodes, limit used is 5
> We would like to understand why the first r.h.s, passed to our function
> for the Schur preconditioner, is not
> b_1-A_10*inv(A_00)*b_0,
> even if we used the full factorization ( without dropping any terms ).
Here is the code:
https://gitlab.com/petsc/petsc/-/blob/master/src/ksp/pc/impls/fieldsplit/fieldsplit.c#L1182
I think you are saying that ilinkD->x is not what you expect on line 1196.
It should be easy to print out the value
at any of the intermediate stages.
     Matt
> Thank you,
> Elena
> Il giorno mer 10 feb 2021 alle ore 18:05 Matthew Knepley <
> knepley at gmail.com> ha scritto:
>> On Wed, Feb 10, 2021 at 11:51 AM Matteo Semplice <
>> matteo.semplice at uninsubria.it> wrote:
>>> Dear PETSc users,
>>>      we are trying to program a preconditioner for the Schur complement
>>> of a Stokes system, but it seems that the r.h.s. for the Schur
>>> complement system differs from what we expect by a scale factor, which
>>> we don't understand.
>>> Our setup has a system matrix A divided in 2x2 blocks for velocity and
>>> pressure variables. We have programmed our preconditioner in a routine
>>> PrecondSchur and in the main program we do
>>> PC pc;
>>> KSPGetPC(kspA,&pc);
>>> PCSetFromOptions(pc);
>>> KSPSetOperators(kspA, A, A);
>>> KSPSetInitialGuessNonzero(kspA,PETSC_FALSE);
>>> KSPSetFromOptions(kspA);
>>> KSP *subksp;
>>> PetscInt nfield;
>>> PCSetUp(pc);
>>> PCFieldSplitGetSubKSP(pc, &nfield, &subksp);
>>> PC pcSchur;
>>> KSPGetPC(subksp[1],&pcSchur);
>>> PCSetType(pcSchur,PCSHELL);
>>> PCShellSetApply(pcSchur,PrecondSchur);
>>> KSPSetFromOptions(subksp[1]);
>>> and eventually
>>> KSPSolve(A,b,solution);
>>> We run the code with options
>>>   -ksp_type fgmres \
>>>   -pc_type fieldsplit -pc_fieldsplit_type schur \
>>>   -pc_fieldsplit_schur_fact_type full \
>>> and, from reading section 2.3.5 of the PETSc manual, we'd expect that
>>> the first r.h.s. passed to PrecondSchur be exactly
>>> Instead (from a monitor function attached to the subksp[1] solver), the
>>> first r.h.s. appears to be scalar multiple of the above vector; we are
>>> guessing that we should take into account this multiplicative factor in
>>> our preconditioner routine, but we cannot understand where it comes from
>>> and how its value is determined.
>>> Could you explain us what is going on in the PC_SCHUR exactly, or point
>>> us to some working code example?
>> 1) It is hard to understand solver questions without the output of
>> -ksp_view
>> 2) The RHS will depend on the kind of factorization you are using for the
>> system
>> https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/PC/PCFieldSplitSetSchurFactType.html#PCFieldSplitSetSchurFactType
>>     I can see which one in the view output
>>   Thanks,
>>     Matt
>>> Thanks in advance!
>>>      Matteo
>> experiments lead.
>> -- Norbert Wiener
>> https://www.cse.buffalo.edu/~knepley/
>> <http://www.cse.buffalo.edu/~knepley/>
> Indirizzo istituzionale di posta elettronica degli studenti e dei laureati
> dell'Università degli Studi di Torino
> Official University of Turin email address for students and graduates
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210210/981277fe/attachment-0001.html>
