[petsc-users] shell preconditioner for Schur complement
Elena Travaglia elena.travaglia at edu.unito.it
Wed Feb 10 15:05:23 CST 2021
Thanks for the link.
We have set a Schur factorization of type FULL, and we passed it when we
run the code with
 -pc_fieldsplit_schur_fact_type full
Here there is the output of -ksp_view
KSP Object: 1 MPI processes
  type: fgmres
    restart=30, using Classical (unmodified) Gram-Schmidt Orthogonalization
with no iterative refinement
    happy breakdown tolerance 1e-30
  maximum iterations=1, initial guess is zero
  tolerances:  relative=1e-08, absolute=1e-50, divergence=10000.
  right preconditioning
  using UNPRECONDITIONED norm type for convergence test
PC Object: 1 MPI processes
  type: fieldsplit
    FieldSplit with Schur preconditioner, factorization FULL
    Preconditioner for the Schur complement formed from A11
    Split info:
    Split number 0 Defined by IS
    Split number 1 Defined by IS
    KSP solver for A00 block
      KSP Object: (fieldsplit_0_) 1 MPI processes
        type: gmres
Orthogonalization with no iterative refinement
        maximum iterations=10000, initial guess is zero
        tolerances:  relative=1e-05, absolute=1e-50, divergence=10000.
        left preconditioning
        using PRECONDITIONED norm type for convergence test
      PC Object: (fieldsplit_0_) 1 MPI processes
        type: ilu
          out-of-place factorization
          0 levels of fill
          tolerance for zero pivot 2.22045e-14
          matrix ordering: natural
          factor fill ratio given 1., needed 1.
            Factored matrix follows:
              Mat Object: 1 MPI processes
                type: seqaij
                rows=44, cols=44
                package used to perform factorization: petsc
                total: nonzeros=482, allocated nonzeros=482
                total number of mallocs used during MatSetValues calls=0
                  using I-node routines: found 13 nodes, limit used is 5
        linear system matrix = precond matrix:
        Mat Object: (fieldsplit_0_) 1 MPI processes
          type: seqaij
          rows=44, cols=44
    KSP solver for S = A11 - A10 inv(A00) A01
      KSP Object: (fieldsplit_1_) 1 MPI processes
        type: gmres
        tolerances:  relative=1e-09, absolute=1e-50, divergence=10000.
      PC Object: (fieldsplit_1_) 1 MPI processes
        type: shell
          no name
        linear system matrix followed by preconditioner matrix:
        Mat Object: (fieldsplit_1_) 1 MPI processes
          type: schurcomplement
          rows=20, cols=20
            Schur complement A11 - A10 inv(A00) A01
            A11
                type: seqaij
                rows=20, cols=20
                total: nonzeros=112, allocated nonzeros=112
                  using I-node routines: found 10 nodes, limit used is 5
            A10
                type: seqaij
                rows=20, cols=44
                total: nonzeros=160, allocated nonzeros=160
            KSP of A00
                type: gmres
divergence=10000.
                type: ilu
                  0 levels of fill
                        type: seqaij
                        rows=44, cols=44
calls=0
is 5
                  type: seqaij
                  rows=44, cols=44
            A01
                type: seqaij
                rows=44, cols=20
                total: nonzeros=156, allocated nonzeros=156
                  using I-node routines: found 12 nodes, limit used is 5
          type: seqaij
          rows=20, cols=20
    type: seqaij
    rows=64, cols=64
    total: nonzeros=910, allocated nonzeros=2432
    total number of mallocs used during MatSetValues calls=128
      using I-node routines: found 23 nodes, limit used is 5
We would like to understand why the first r.h.s, passed to our function for
the Schur preconditioner, is not
b_1-A_10*inv(A_00)*b_0,
even if we used the full factorization ( without dropping any terms ).
Thank you,
Elena
Il giorno mer 10 feb 2021 alle ore 18:05 Matthew Knepley <knepley at gmail.com>
ha scritto:
> On Wed, Feb 10, 2021 at 11:51 AM Matteo Semplice <
> matteo.semplice at uninsubria.it> wrote:
>> Dear PETSc users,
>>      we are trying to program a preconditioner for the Schur complement
>> of a Stokes system, but it seems that the r.h.s. for the Schur
>> complement system differs from what we expect by a scale factor, which
>> we don't understand.
>> Our setup has a system matrix A divided in 2x2 blocks for velocity and
>> pressure variables. We have programmed our preconditioner in a routine
>> PrecondSchur and in the main program we do
>> PC pc;
>> KSPGetPC(kspA,&pc);
>> PCSetFromOptions(pc);
>> KSPSetOperators(kspA, A, A);
>> KSPSetInitialGuessNonzero(kspA,PETSC_FALSE);
>> KSPSetFromOptions(kspA);
>> KSP *subksp;
>> PetscInt nfield;
>> PCSetUp(pc);
>> PCFieldSplitGetSubKSP(pc, &nfield, &subksp);
>> PC pcSchur;
>> KSPGetPC(subksp[1],&pcSchur);
>> PCSetType(pcSchur,PCSHELL);
>> PCShellSetApply(pcSchur,PrecondSchur);
>> KSPSetFromOptions(subksp[1]);
>> and eventually
>> KSPSolve(A,b,solution);
>> We run the code with options
>>   -ksp_type fgmres \
>>   -pc_type fieldsplit -pc_fieldsplit_type schur \
>>   -pc_fieldsplit_schur_fact_type full \
>> and, from reading section 2.3.5 of the PETSc manual, we'd expect that
>> the first r.h.s. passed to PrecondSchur be exactly
>> Instead (from a monitor function attached to the subksp[1] solver), the
>> first r.h.s. appears to be scalar multiple of the above vector; we are
>> guessing that we should take into account this multiplicative factor in
>> our preconditioner routine, but we cannot understand where it comes from
>> and how its value is determined.
>> Could you explain us what is going on in the PC_SCHUR exactly, or point
>> us to some working code example?
> 1) It is hard to understand solver questions without the output of
> -ksp_view
> 2) The RHS will depend on the kind of factorization you are using for the
> system
> https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/PC/PCFieldSplitSetSchurFactType.html#PCFieldSplitSetSchurFactType
>     I can see which one in the view output
>   Thanks,
>     Matt
>> Thanks in advance!
>>      Matteo
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
Indirizzo istituzionale di posta elettronica
degli studenti e dei laureati dell'Università degli Studi di TorinoOfficial
University of Turin email address for students and graduates
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210210/705208ce/attachment.html>
