[petsc-users] DM misuse causes massive memory leak?
Ferrand, Jesus A.
FERRANJ2 at my.erau.edu
Wed Dec 29 16:12:53 CST 2021
Dear PETSc Team:
I have a question about DM and PetscSection. Say I import a mesh (for FEM purposes) and create a DMPlex for it. I then use PetscSections to set degrees of freedom per "point" (by point I mean vertices, lines, faces, and cells). I then use PetscSectionGetStorageSize() to get the size of the global stiffness matrix (K) needed for my FEM problem. One last detail, this K I populate inside a rather large loop using an element stiffness matrix function of my own. Instead of using DMCreateMatrix(), I manually created a Mat using MatCreate(), MatSetType(), MatSetSizes(), and MatSetUp(). I come to find that said loop is painfully slow when I use the manually created matrix, but 20x faster when I use the Mat coming out of DMCreateMatrix().
My question is then: Is the manual Mat a noob mistake and is it somehow creating a memory leak with K? Just in case it's something else I'm attaching the code. The loop that populates K is between lines 221 and 278. Anything related to DM, DMPlex, and PetscSection is between lines 117 and 180.
Machine Type: HP Laptop
C-compiler: Gnu C
OS: Ubuntu 20.04
PETSc version: 3.16.0
MPI Implementation: MPICH
Hope you all had a Merry Christmas and that you will have a happy and productive New Year. :D
Sincerely:
J.A. Ferrand
Embry-Riddle Aeronautical University - Daytona Beach FL
M.Sc. Aerospace Engineering | May 2022
B.Sc. Aerospace Engineering
B.Sc. Computational Mathematics
Sigma Gamma Tau
Tau Beta Pi
Honors Program
Phone: (386)-843-1829
Email(s): ferranj2 at my.erau.edu
jesus.ferrand at gmail.com
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20211229/db5d4a19/attachment-0001.html>
Type: text/x-csrc
Desc: gmshBACKUP2.c
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20211229/db5d4a19/attachment-0001.bin>
