[petsc-users] The exact Jacobian for ASPIN
Lulu Liu lulu.liu at kaust.edu.sa
Sat Dec 25 23:48:28 CST 2021
Dear Barry,
Yes, J_{I} is the typo, and it should be J_{j}.  The exact Jacobian of the
preconditioned Jacobian is
J_exact=\sum_{j=1}^{N}J_{j}(x-T_{i})J(x-T_{j})                     (1)
It seems that PETSc uses the approximate Jacobian,
J_exact=\sum_{j=1}^{N}J_{j}(x-T_{i})J(x-\sum_{j=1}^{N}T_{j})           (2)
In the RASPEN algorithm, it requires the exact Jacobian of ASPIN in the
equation (1).  Currently, the J_{j}(x-T_{i}) is only  computed on each
processor in PETSc, how can I get the global term J(x-T_{j})(j=1,2,..N)?
Thanks.
On Tue, Nov 9, 2021 at 11:18 AM Barry Smith <bsmith at petsc.dev> wrote:
>   Lulu,
>     Sorry for not responding quicker. This question will take a little
> research to figure out exactly what is needed, I am not sure it is
> possible.
>     I note below you have a J_{I} is that intentional? If so what does it
> mean, or is a typo that should be J_{j} as in the next equation?
>   Barry
> On Nov 6, 2021, at 7:19 AM, Lulu Liu <lulu.liu at kaust.edu.sa> wrote:
> Hi,
> For ASPIN, the local problem F_{j}(x-T_{j})=0 (j=1,2,...N)  is solved. The
> exact Jacobian of the preconditioned Jacobian is
> J_exact=\sum_{j=1}^{N}J_{I}(x-T_{i})J(x-T_{j}).
> J_exact=\sum_{j=1}^{N}J_{j}(x-T_{i})J(x-\sum_{j=1}^{N}T_{j}).
> I want to implement RASPEN, which requires the exact Jacobian of ASPIN.  Is there
> any easy way to compute J(x-T_{j}) (j=1,2,..N)? How can I get the global
> vectors like  x-T_{j}  ? PETSc only provides  the vector x-T_{j} on the
> subdomain now.
> Thanks very much!
> Best wishes,
> Lulu Liu
> This message and its contents, including attachments are intended solely
> for the original recipient. If you are not the intended recipient or have
> received this message in error, please notify me immediately and delete
> this message from your computer system. Any unauthorized use or
> distribution is prohibited. Please consider the environment before printing
> this email.
Best wishes,
Lulu Liu
Applied Mathematics and Computational Science
King Abdullah University of Science and Technology
Tel:+966-0544701599
this email.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20211226/0b7f78a8/attachment.html>
