[petsc-users] Combining SUPERLU_DIST with CUDA fails
Roland Richter
roland.richter at ntnu.no
Tue Dec 21 01:24:34 CST 2021
I added/replaced all six lines which are in that commit, getting
Executing: /usr/bin/cmake .. -DCMAKE_INSTALL_PREFIX=/opt/petsc
-DCMAKE_INSTALL_NAME_DIR:STRING="/opt/petsc/lib"
-DCMAKE_INSTALL_LIBDIR:STRING="lib" -DCMAKE_VERBOSE_MAKEFILE=1
-DCMAKE_BUILD_TYPE=Release
-DCMAKE_C_COMPILER="/opt/intel/oneapi/mpi/2021.5.0/bin/mpicc"
-DMPI_C_COMPILER="/opt/intel/oneapi/mpi/2021.5.0/bin/mpicc"
-DCMAKE_AR=/usr/bin/ar -DCMAKE_RANLIB=/usr/bin/ranlib
-DCMAKE_C_FLAGS:STRING="-mavx2 -march=native -O3 -fPIC -fopenmp"
-DCMAKE_C_FLAGS_DEBUG:STRING="-mavx2 -march=native -O3 -fPIC -fopenmp"
-DCMAKE_C_FLAGS_RELEASE:STRING="-mavx2 -march=native -O3 -fPIC -fopenmp"
-DCMAKE_CXX_COMPILER="/opt/intel/oneapi/mpi/2021.5.0/bin/mpicxx"
-DMPI_CXX_COMPILER="/opt/intel/oneapi/mpi/2021.5.0/bin/mpicxx"
-DCMAKE_CXX_FLAGS:STRING="-mavx2 -march=native -O3 -fopenmp -fPIC
-std=gnu++17 -fopenmp" -DCMAKE_CXX_FLAGS_DEBUG:STRING="-mavx2
-march=native -O3 -fopenmp -fPIC -std=gnu++17 -fopenmp"
-DCMAKE_CXX_FLAGS_RELEASE:STRING="-mavx2 -march=native -O3 -fopenmp
-DCMAKE_Fortran_COMPILER="/opt/intel/oneapi/mpi/2021.5.0/bin/mpifc"
-DMPI_Fortran_COMPILER="/opt/intel/oneapi/mpi/2021.5.0/bin/mpifc"
-DCMAKE_Fortran_FLAGS:STRING="-mavx2 -march=native -O3 -fPIC -fopenmp
-fallow-argument-mismatch" -DCMAKE_Fortran_FLAGS_DEBUG:STRING="-mavx2
-march=native -O3 -fPIC -fopenmp -fallow-argument-mismatch"
-DCMAKE_Fortran_FLAGS_RELEASE:STRING="-mavx2 -march=native -O3 -fPIC
-fopenmp -fallow-argument-mismatch" -DCMAKE_EXE_LINKER_FLAGS:STRING="
-fopenmp -fopenmp" -DBUILD_SHARED_LIBS:BOOL=ON -DTPL_ENABLE_CUDALIB=TRUE
-DTPL_CUDA_LIBRARIES="-Wl,-rpath,/usr/local/cuda-11.5/lib64
-L/usr/local/cuda-11.5/lib64 -lcudart -lcufft -lcublas -lcusparse
-lcusolver -lcurand -L/usr/local/cuda-11.5/lib64/stubs -lcuda"
-DCUDA_ARCH_FLAGS="-I/usr/local/cuda-11.5/include -arch=sm_61
-DDEBUGlevel=0 -DPRNTlevel=0"
-DCMAKE_CUDA_FLAGS="-allow-unsupported-compiler -Xcompiler -fPIC -O3
-ccbin /opt/intel/oneapi/mpi/2021.5.0/bin/mpicxx -std=c++17 -gencode
arch=compute_61,code=sm_61 -Wno-deprecated-gpu-targets
-I"/opt/intel/oneapi/mpi/2021.5.0/include" " -DUSE_XSDK_DEFAULTS=YES
-DTPL_BLAS_LIBRARIES="-lopenblas -Wl,-rpath,/usr/local/cuda-11.5/lib64
-lcusolver -lcurand -L/usr/local/cuda-11.5/lib64/stubs -lcuda -lm
-lstdc++ -ldl -Wl,-rpath,/opt/intel/oneapi/mpi/2021.5.0/lib/release
-L/opt/intel/oneapi/mpi/2021.5.0/lib/release
-L/opt/intel/oneapi/mpi/2021.5.0/lib -lmpifort -lmpi -lrt -lpthread
-lgfortran -lm -Wl,-rpath,/usr/lib64/gcc/x86_64-suse-linux/11
-L/usr/lib64/gcc/x86_64-suse-linux/11
-Wl,-rpath,/opt/intel/oneapi/vpl/2022.0.0/lib
-L/opt/intel/oneapi/vpl/2022.0.0/lib
-Wl,-rpath,/opt/intel/oneapi/tbb/2021.5.0/lib/intel64/gcc4.8
-L/opt/intel/oneapi/tbb/2021.5.0/lib/intel64/gcc4.8
-Wl,-rpath,/opt/intel/oneapi/mpi/2021.5.0/libfabric/lib
-L/opt/intel/oneapi/mpi/2021.5.0/libfabric/lib
-Wl,-rpath,/opt/intel/oneapi/mkl/2022.0.1/lib/intel64
-L/opt/intel/oneapi/mkl/2022.0.1/lib/intel64
-Wl,-rpath,/opt/intel/oneapi/ipp/2021.5.1/lib/intel64
-L/opt/intel/oneapi/ipp/2021.5.1/lib/intel64
-Wl,-rpath,/opt/intel/oneapi/ippcp/2021.5.0/lib/intel64
-L/opt/intel/oneapi/ippcp/2021.5.0/lib/intel64
-Wl,-rpath,/opt/intel/oneapi/dnnl/2022.0.1/cpu_dpcpp_gpu_dpcpp/lib
-L/opt/intel/oneapi/dnnl/2022.0.1/cpu_dpcpp_gpu_dpcpp/lib
-Wl,-rpath,/opt/intel/oneapi/dal/2021.5.1/lib/intel64
-L/opt/intel/oneapi/dal/2021.5.1/lib/intel64
-Wl,-rpath,/opt/intel/oneapi/compiler/2022.0.1/linux/compiler/lib/intel64_lin
-L/opt/intel/oneapi/compiler/2022.0.1/linux/compiler/lib/intel64_lin
-Wl,-rpath,/opt/intel/oneapi/compiler/2022.0.1/linux/lib
-L/opt/intel/oneapi/compiler/2022.0.1/linux/lib
-Wl,-rpath,/opt/intel/oneapi/clck/2021.5.0/lib/intel64
-L/opt/intel/oneapi/clck/2021.5.0/lib/intel64
-Wl,-rpath,/opt/intel/oneapi/ccl/2021.5.0/lib/cpu_gpu_dpcpp
-L/opt/intel/oneapi/ccl/2021.5.0/lib/cpu_gpu_dpcpp
-Wl,-rpath,/usr/x86_64-suse-linux/lib -L/usr/x86_64-suse-linux/lib
-Wl,-rpath,/opt/intel/oneapi/mpi/2021.5.0/lib -lgfortran -lm -lgcc_s
-lquadmath" -DTPL_LAPACK_LIBRARIES="-lopenblas
-Wl,-rpath,/usr/local/cuda-11.5/lib64 -L/usr/local/cuda-11.5/lib64
-lcudart -lcufft -lcublas -lcusparse -lcusolver -lcurand
-L/usr/local/cuda-11.5/lib64/stubs -lcuda -lm -lstdc++ -ldl
-lquadmath" -Denable_parmetislib=FALSE -DTPL_ENABLE_PARMETISLIB=FALSE
-DXSDK_ENABLE_Fortran=ON -Denable_tests=0 -Denable_examples=0
-DMPI_C_COMPILE_FLAGS:STRING="" -DMPI_C_INCLUDE_PATH:STRING=""
-DMPI_C_HEADER_DIR:STRING="" -DMPI_C_LIBRARIES:STRING=""
but the compilation still fails with the same error.
Am 20.12.21 um 22:46 schrieb Roland Richter:
> Yes, just checked, I only included the changes above the comment...
> Will test tomorrow, thanks for the help!
> Regards,
> Roland
> Am 20.12.2021 um 21:46 schrieb Barry Smith:
>> Hmm, the fix should now be supplying a -DCMAKE_CUDA_FLAGS to this
>> cmake command (line 48
>> at https://gitlab.com/petsc/petsc/-/merge_requests/4635/diffs) I do
>> not see that flag being set inside the configure.log so I am guessing
>> you didn't get the complete fix.
>> -fopenmp" -DCMAKE_C_FLAGS_RELEASE:STRING="-mavx2 -march=native -O3
>> -fPIC -fopenmp"
>> -DDEBUGlevel=0 -DPRNTlevel=0" -DUSE_XSDK_DEFAULTS=YES
>>> On Dec 20, 2021, at 2:59 PM, Roland Richter <roland.richter at ntnu.no>
>>> wrote:
>>> I introduced the changes from that patch directly, without checking
>>> out. Is that insufficient?
>>> Regards,
>>> Roland
>>> Am 20.12.2021 um 20:38 schrieb Barry Smith:
>>>> Are you sure you have the correct PETSc branch? From
>>>> configure.log it has
>>>> Defined "VERSION_GIT" to ""v3.16.2-466-g959e1fce86""
>>>> Defined "VERSION_DATE_GIT" to ""2021-12-18 11:17:24 -0600""
>>>> Defined "VERSION_BRANCH_GIT" to ""master""
>>>> It should have balay/slu-without-omp-3 for the branch.
>>>>> On Dec 20, 2021, at 10:50 AM, Roland Richter
>>>>> <roland.richter at ntnu.no> wrote:
>>>>> In that case it fails with
>>>>> /~/Downloads/git-files/petsc/mpich-complex-linux-gcc-demo/externalpackages/git.superlu_dist/SRC/cublas_utils.h:22:10:
>>>>> fatal error: cublas_v2.h: No such file or directory/
>>>>> even though this header is available. I assume some header paths
>>>>> are not set correctly?
>>>>> Thanks,
>>>>> regards,
>>>>> Roland
>>>>> Am 20.12.21 um 16:29 schrieb Barry Smith:
>>>>>> Please try the branch balay/slu-without-omp-3 It is in
>>>>>> MR https://gitlab.com/petsc/petsc/-/merge_requests/4635
>>>>>>> On Dec 20, 2021, at 8:14 AM, Roland Richter
>>>>>>> Hei,
>>>>>>> I tried to combine CUDA with superlu_dist in petsc using the
>>>>>>> following configure-line:
>>>>>>> /./configure PETSC_ARCH=mpich-complex-linux-gcc-demo
>>>>>>> --CC=/opt/intel/oneapi/mpi/2021.5.0/bin/mpicc
>>>>>>> --CXX=/opt/intel/oneapi/mpi/2021.5.0/bin/mpicxx
>>>>>>> --FC=/opt/intel/oneapi/mpi/2021.5.0/bin/mpifc --CFLAGS="-mavx2
>>>>>>> -march=native -O3" --CXXFLAGS="-mavx2 -march=native -O3"
>>>>>>> --FFLAGS="-mavx2 -march=native -O3"
>>>>>>> --CUDAFLAGS=-allow-unsupported-compiler --CUDA-CXX=g++
>>>>>>> --prefix=/opt/petsc --with-blaslapack=1 --with-mpi=1
>>>>>>> --with-scalar-type=complex --download-suitesparse=1 --with-cuda
>>>>>>> --with-debugging=0 --with-openmp --download-superlu_dist --force/
>>>>>>> but the configure-step fails with several errors correlated with
>>>>>>> CUDA and superlu_dist, the first one being
>>>>>>> /cublas_utils.c:21:37: error: ‘CUDART_VERSION’ undeclared (first
>>>>>>> use in this function); did you mean ‘CUDA_VERSION’?//
>>>>>>> // 21 | printf("CUDA version: v %d\n",CUDART_VERSION);//
>>>>>>> // | CUDA_VERSION/
>>>>>>> Compiling superlu_dist separately works, though (including CUDA).
>>>>>>> Is there a bug somewhere in the configure-routine? I attached
>>>>>>> the full configure-log.
>>>>>>> Thanks!
>>>>>>> Regards,
>>>>>>> Roland
>>>>>>> <configure.log>
>>>>> <configure.log>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20211221/31359511/attachment-0001.html>
Type: text/x-log
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20211221/31359511/attachment-0001.bin>
