[petsc-users] Combining SUPERLU_DIST with CUDA fails
    Roland Richter
    roland.richter at ntnu.no
    Mon Dec 20 15:46:17 CST 2021
Yes, just checked, I only included the changes above the comment...
Will test tomorrow, thanks for the help!
Roland
Am 20.12.2021 um 21:46 schrieb Barry Smith:
>   Hmm, the fix should now be supplying a -DCMAKE_CUDA_FLAGS to this
> cmake command (line 48 at
> https://gitlab.com/petsc/petsc/-/merge_requests/4635/diffs) I do not
> see that flag being set inside the configure.log so I am guessing you
> didn't get the complete fix.
> Executing: /usr/bin/cmake .. -DCMAKE_INSTALL_PREFIX=/opt/petsc
> -DCMAKE_INSTALL_NAME_DIR:STRING="/opt/petsc/lib"
> -DCMAKE_INSTALL_LIBDIR:STRING="lib" -DCMAKE_VERBOSE_MAKEFILE=1
> -DCMAKE_BUILD_TYPE=Release
> -DCMAKE_C_COMPILER="/opt/intel/oneapi/mpi/2021.5.0/bin/mpicc"
> -DMPI_C_COMPILER="/opt/intel/oneapi/mpi/2021.5.0/bin/mpicc"
> -DCMAKE_AR=/usr/bin/ar -DCMAKE_RANLIB=/usr/bin/ranlib
> -DCMAKE_C_FLAGS:STRING="-mavx2 -march=native -O3 -fPIC -fopenmp"
> -DCMAKE_C_FLAGS_DEBUG:STRING="-mavx2 -march=native -O3 -fPIC -fopenmp"
> -DCMAKE_C_FLAGS_RELEASE:STRING="-mavx2 -march=native -O3 -fPIC
> -fopenmp"
> -DCMAKE_CXX_COMPILER="/opt/intel/oneapi/mpi/2021.5.0/bin/mpicxx"
> -DMPI_CXX_COMPILER="/opt/intel/oneapi/mpi/2021.5.0/bin/mpicxx"
> -DCMAKE_CXX_FLAGS:STRING="-mavx2 -march=native -O3 -fopenmp -fPIC
> -std=gnu++17 -fopenmp" -DCMAKE_CXX_FLAGS_DEBUG:STRING="-mavx2
> -march=native -O3 -fopenmp -fPIC -std=gnu++17 -fopenmp"
> -DCMAKE_CXX_FLAGS_RELEASE:STRING="-mavx2 -march=native -O3 -fopenmp
> -DCMAKE_Fortran_COMPILER="/opt/intel/oneapi/mpi/2021.5.0/bin/mpifc"
> -DMPI_Fortran_COMPILER="/opt/intel/oneapi/mpi/2021.5.0/bin/mpifc"
> -DCMAKE_Fortran_FLAGS:STRING="-mavx2 -march=native -O3 -fPIC -fopenmp
> -fallow-argument-mismatch" -DCMAKE_Fortran_FLAGS_DEBUG:STRING="-mavx2
> -march=native -O3 -fPIC -fopenmp -fallow-argument-mismatch"
> -DCMAKE_Fortran_FLAGS_RELEASE:STRING="-mavx2 -march=native -O3 -fPIC
> -fopenmp -fallow-argument-mismatch" -DCMAKE_EXE_LINKER_FLAGS:STRING="
> -fopenmp -fopenmp" -DBUILD_SHARED_LIBS:BOOL=ON
> -DTPL_ENABLE_CUDALIB=TRUE
> -DTPL_CUDA_LIBRARIES="-Wl,-rpath,/usr/local/cuda-11.5/lib64
> -L/usr/local/cuda-11.5/lib64 -lcudart -lcufft -lcublas -lcusparse
> -lcusolver -lcurand -L/usr/local/cuda-11.5/lib64/stubs -lcuda"
> -DCUDA_ARCH_FLAGS="-I/usr/local/cuda-11.5/include -arch=sm_61
> -DDEBUGlevel=0 -DPRNTlevel=0" -DUSE_XSDK_DEFAULTS=YES
> -DTPL_BLAS_LIBRARIES="-lopenblas -Wl,-rpath,/usr/local/cuda-11.5/lib64
> -lcusolver -lcurand -L/usr/local/cuda-11.5/lib64/stubs -lcuda -lm
> -lstdc++ -ldl -Wl,-rpath,/opt/intel/oneapi/mpi/2021.5.0/lib/release
> -L/opt/intel/oneapi/mpi/2021.5.0/lib/release
> -L/opt/intel/oneapi/mpi/2021.5.0/lib -lmpifort -lmpi -lrt -lpthread
> -lgfortran -lm -Wl,-rpath,/usr/lib64/gcc/x86_64-suse-linux/11
> -L/usr/lib64/gcc/x86_64-suse-linux/11
> -Wl,-rpath,/opt/intel/oneapi/vpl/2022.0.0/lib
> -L/opt/intel/oneapi/vpl/2022.0.0/lib
> -Wl,-rpath,/opt/intel/oneapi/tbb/2021.5.0/lib/intel64/gcc4.8
> -L/opt/intel/oneapi/tbb/2021.5.0/lib/intel64/gcc4.8
> -Wl,-rpath,/opt/intel/oneapi/mpi/2021.5.0/libfabric/lib
> -L/opt/intel/oneapi/mpi/2021.5.0/libfabric/lib
> -Wl,-rpath,/opt/intel/oneapi/mkl/2022.0.1/lib/intel64
> -L/opt/intel/oneapi/mkl/2022.0.1/lib/intel64
> -Wl,-rpath,/opt/intel/oneapi/ipp/2021.5.1/lib/intel64
> -L/opt/intel/oneapi/ipp/2021.5.1/lib/intel64
> -Wl,-rpath,/opt/intel/oneapi/ippcp/2021.5.0/lib/intel64
> -L/opt/intel/oneapi/ippcp/2021.5.0/lib/intel64
> -Wl,-rpath,/opt/intel/oneapi/dnnl/2022.0.1/cpu_dpcpp_gpu_dpcpp/lib
> -L/opt/intel/oneapi/dnnl/2022.0.1/cpu_dpcpp_gpu_dpcpp/lib
> -Wl,-rpath,/opt/intel/oneapi/dal/2021.5.1/lib/intel64
> -L/opt/intel/oneapi/dal/2021.5.1/lib/intel64
> -Wl,-rpath,/opt/intel/oneapi/compiler/2022.0.1/linux/compiler/lib/intel64_lin
> -L/opt/intel/oneapi/compiler/2022.0.1/linux/compiler/lib/intel64_lin
> -Wl,-rpath,/opt/intel/oneapi/compiler/2022.0.1/linux/lib
> -L/opt/intel/oneapi/compiler/2022.0.1/linux/lib
> -Wl,-rpath,/opt/intel/oneapi/clck/2021.5.0/lib/intel64
> -L/opt/intel/oneapi/clck/2021.5.0/lib/intel64
> -Wl,-rpath,/opt/intel/oneapi/ccl/2021.5.0/lib/cpu_gpu_dpcpp
> -L/opt/intel/oneapi/ccl/2021.5.0/lib/cpu_gpu_dpcpp
> -Wl,-rpath,/usr/x86_64-suse-linux/lib -L/usr/x86_64-suse-linux/lib
> -Wl,-rpath,/opt/intel/oneapi/mpi/2021.5.0/lib -lgfortran -lm -lgcc_s
> -lquadmath" -DTPL_LAPACK_LIBRARIES="-lopenblas
> -Wl,-rpath,/usr/local/cuda-11.5/lib64 -L/usr/local/cuda-11.5/lib64
> -lcudart -lcufft -lcublas -lcusparse -lcusolver -lcurand
> -L/usr/local/cuda-11.5/lib64/stubs -lcuda -lm -lstdc++ -ldl
> -lquadmath" -Denable_parmetislib=FALSE -DTPL_ENABLE_PARMETISLIB=FALSE
> -DXSDK_ENABLE_Fortran=ON -Denable_tests=0 -Denable_examples=0
> -DMPI_C_COMPILE_FLAGS:STRING="" -DMPI_C_INCLUDE_PATH:STRING=""
> -DMPI_C_HEADER_DIR:STRING="" -DMPI_C_LIBRARIES:STRING=""
>> On Dec 20, 2021, at 2:59 PM, Roland Richter <roland.richter at ntnu.no>
>> wrote:
>> I introduced the changes from that patch directly, without checking
>> out. Is that insufficient?
>> Regards,
>> Roland
>> Am 20.12.2021 um 20:38 schrieb Barry Smith:
>>>   Are you sure you have the correct PETSc branch? From configure.log
>>> it has
>>>             Defined "VERSION_GIT" to ""v3.16.2-466-g959e1fce86""
>>>             Defined "VERSION_DATE_GIT" to ""2021-12-18 11:17:24 -0600""
>>>             Defined "VERSION_BRANCH_GIT" to ""master""
>>> It should have balay/slu-without-omp-3 for the branch.
>>>> On Dec 20, 2021, at 10:50 AM, Roland Richter
>>>> <roland.richter at ntnu.no> wrote:
>>>> In that case it fails with
>>>> /~/Downloads/git-files/petsc/mpich-complex-linux-gcc-demo/externalpackages/git.superlu_dist/SRC/cublas_utils.h:22:10:
>>>> fatal error: cublas_v2.h: No such file or directory/
>>>> even though this header is available. I assume some header paths
>>>> are not set correctly?
>>>> Thanks,
>>>> regards,
>>>> Roland
>>>> Am 20.12.21 um 16:29 schrieb Barry Smith:
>>>>>   Please try the branch balay/slu-without-omp-3  It is in MR
>>>>>> On Dec 20, 2021, at 8:14 AM, Roland Richter
>>>>>> Hei,
>>>>>> I tried to combine CUDA with superlu_dist in petsc using the
>>>>>> following configure-line:
>>>>>> /./configure PETSC_ARCH=mpich-complex-linux-gcc-demo
>>>>>> --CC=/opt/intel/oneapi/mpi/2021.5.0/bin/mpicc
>>>>>> --CXX=/opt/intel/oneapi/mpi/2021.5.0/bin/mpicxx
>>>>>> --FC=/opt/intel/oneapi/mpi/2021.5.0/bin/mpifc --CFLAGS="-mavx2
>>>>>> -march=native -O3" --CXXFLAGS="-mavx2 -march=native -O3"
>>>>>> --FFLAGS="-mavx2 -march=native -O3"
>>>>>> --CUDAFLAGS=-allow-unsupported-compiler --CUDA-CXX=g++
>>>>>> --prefix=/opt/petsc --with-blaslapack=1 --with-mpi=1
>>>>>> --with-scalar-type=complex --download-suitesparse=1 --with-cuda
>>>>>> --with-debugging=0 --with-openmp --download-superlu_dist --force/
>>>>>> but the configure-step fails with several errors correlated with
>>>>>> CUDA and superlu_dist, the first one being
>>>>>> /cublas_utils.c:21:37: error: ‘CUDART_VERSION’ undeclared (first
>>>>>> use in this function); did you mean ‘CUDA_VERSION’?//
>>>>>> //   21 | printf("CUDA version:   v %d\n",CUDART_VERSION);//
>>>>>> //| CUDA_VERSION/
>>>>>> Compiling superlu_dist separately works, though (including CUDA).
>>>>>> Is there a bug somewhere in the configure-routine? I attached the
>>>>>> full configure-log.
>>>>>> Thanks!
>>>>>> Regards,
>>>>>> Roland
>>>>>> <configure.log>
>>>> <configure.log>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20211220/75aa70e4/attachment.html>
