[petsc-users] --with-mpi=0
Barry Smith
bsmith at petsc.dev
Sat Dec 18 17:08:15 CST 2021
Satish,
Yes, you are probably right; there may be no way to organize things to handle all the possibilities well.
Probably I over-reacted and it is best to leave things as if.
Barry
> On Dec 18, 2021, at 6:03 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> Also we have:
> include/petscsys.h:# include <petsc/mpiuni/mpi.h>
> src/sys/mpiuni/f90-mod/mpiunimod.F90:#include <petsc/mpiuni/mpif.h>
> And avoid -Iprefix/include/petsc/mpiuni/
> So I'm not sure if adding this in can cause grief (as it would be required for mpi.mod at this location).
> I have changes for mpiuni.mod -> mpi.mod at:
> https://gitlab.com/petsc/petsc/-/merge_requests/4662
> [they are a bit hakey]
> Satish
> On Sat, 18 Dec 2021, Satish Balay via petsc-users wrote:
>> On Sat, 18 Dec 2021, Barry Smith wrote:
>>> It seems like this might be a good strategy, presumably the directory is already made to hold mpi.h for MPI uni
>>>> Perhaps its possible to change our installer to have mpiuni's mod file at prefix/include/petsc/mpiuni/mpi.mod - [to enable reusing mpi.mod name ]
>> module petscmpi
>> #include <petscconf.h>
>> #include "petsc/finclude/petscsys.h"
>> #if defined(PETSC_HAVE_MPIUNI)
>> use mpiuni
>> #else
>> #if defined(PETSC_HAVE_MPI_F90MODULE)
>> use mpi
>> #else
>> #include "mpif.h"
>> #endif
>> #endif
>> There is also this use-case where there is no usable mpi.mod - that petscmpi is currently
>> handling... Not sure how to deal with that..
>> Satish
