[petsc-users] Unstructured mesh
Mark Adams mfadams at lbl.gov
Thu Dec 16 06:40:53 CST 2021
Just a note, I think you can get meaningful hypre data by not timing the
first solve and perhaps by simply calling KSPSetup before KSPSolve to get
the conversion to a hypre matrix out of the way and not timed in KSPSolve.
ksp/ksp/tutorials/ex56.c does do this but I see snes does not. You could
add KSPSetup before KSPSolve and you should see that the time reported for
setup + solve == original  solve.
On Wed, Dec 15, 2021 at 3:31 PM Karthikeyan Chockalingam - STFC UKRI <
karthikeyan.chockalingam at stfc.ac.uk> wrote:
> Thank you for your detailed response. Yes, using aijcusparse worked (as
> you mentioned it is not optimal).
> My objective was to run an unstructured mesh (which I believe would be of
> type DMPlex), for varying size using different preconditioners by comparing
> their performance on cpus and gpus. I understand that would not be possible
> using hypre. Leaving out hypre - I need some recommendation to move onto
> other unstructured (DMPlex) example problems, where I change the size of
> the domain via command line input.
> Kind regards,
> Karthik.
> *From: *Mark Adams <mfadams at lbl.gov>
> *Date: *Tuesday, 14 December 2021 at 18:58
> *To: *"Chockalingam, Karthikeyan (STFC,DL,HC)" <
> *Cc: *Matthew Knepley <knepley at gmail.com>, "petsc-users at mcs.anl.gov" <
> petsc-users at mcs.anl.gov>
> *Subject: *Re: [petsc-users] Unstructured mesh
> I was able to get hypre to work on ex56 (snes) with -ex56_dm_mat_type
> aijcusparse -ex56_dm_vec_type cuda (not hypre matrix).
> This should copy the cusparse matrix to a hypre matrix before the solve.
> So not optimal but the actual solve should be the same.
> Hypre is not yet supported on this example so you might not want to spend
> too much time on it.
> In particular, we do not have an example that uses DMPlex and hypre on a
> GPU.
> src/ksp/ksp/tutotials/ex56 is old and does not use DMPLex, but it is
> missing a call like ksp ex4 for hypre like this:
> #if defined(PETSC_HAVE_HYPRE)
>   ierr = MatHYPRESetPreallocation(A,5,NULL,5,NULL);CHKERRQ(ierr);
> #endif
> If you add that it might work, but again this is all pretty fragile at
> this point.
> Mark
> Mark
> On Tue, Dec 14, 2021 at 2:42 AM Karthikeyan Chockalingam - STFC UKRI <
> I tried adding the -mat_block_size 3 but I still get the same error
> message.
> Thanks,
> Karthik.
> *Date: *Monday, 13 December 2021 at 19:54
> Try adding -mat_block_size 3
> On Mon, Dec 13, 2021 at 11:57 AM Karthikeyan Chockalingam - STFC UKRI <
> I tried to run the problem using -pc_type hypre but it errored out:
> ./ex56 -cells 4,4,2  -max_conv_its 1 -lx 1. -alpha .01 -petscspace_degree
> 1 -ksp_type cg -ksp_monitor -ksp_rtol 1.e-8 -pc_type hypre -pc_hypre_type boomeramg
> -snes_monitor -use_mat_nearnullspace true -snes_rtol 1.e-10 -ex56_dm_view
> -log_view -ex56_dm_vec_type cuda *-ex56_dm_mat_type hypre*  -options_left
> *[0]PETSC ERROR: --------------------- Error Message
> [0]PETSC ERROR: Petsc has generated inconsistent data
> [0]PETSC ERROR: Blocksize of layout 1 must match that of mapping 3 (or the
> latter must be 1)
> [0]PETSC ERROR: See https://petsc.org/release/faq/ for trouble shooting.
> [0]PETSC ERROR: Petsc Development GIT revision: v3.16.1-353-g887dddf386  GIT
> Date: 2021-11-19 20:24:41 +0000
> [0]PETSC ERROR: ./ex56 on a arch-linux2-c-opt named sqg2b13.bullx by
> kxc07-lxm25 Mon Dec 13 16:50:02 2021
> [0]PETSC ERROR: Configure options --with-debugging=0
> --with-blaslapack-dir=/lustre/scafellpike/local/apps/intel/intel_cs/2018.0.128/mkl
> --with-cuda=1 --with-cuda-arch=70 --download-hypre=yes
> --download-hypre-configure-arguments="--with-cuda=yes
> --enable-gpu-profiling=yes --enable-cusparse=yes --enable-cublas=yes
> --enable-curand=yes  --enable-unified-memory=yes HYPRE_CUDA_SM=70"
> --with-shared-libraries=1 --known-mpi-shared-libraries=1 --with-cc=mpicc
> --with-cxx=mpicxx -with-fc=mpif90
> [0]PETSC ERROR: #1 PetscLayoutSetISLocalToGlobalMapping() at
> /lustre/scafellpike/local/HT04048/lxm25/kxc07-lxm25/petsc-main/petsc/src/vec/is/utils/pmap.c:371
> [0]PETSC ERROR: #2 MatSetLocalToGlobalMapping() at
> /lustre/scafellpike/local/HT04048/lxm25/kxc07-lxm25/petsc-main/petsc/src/mat/interface/matrix.c:2089
> [0]PETSC ERROR: #3 DMCreateMatrix_Plex() at
> /lustre/scafellpike/local/HT04048/lxm25/kxc07-lxm25/petsc-main/petsc/src/dm/impls/plex/plex.c:2460
> [0]PETSC ERROR: #4 DMCreateMatrix() at
> /lustre/scafellpike/local/HT04048/lxm25/kxc07-lxm25/petsc-main/petsc/src/dm/interface/dm.c:1445
> [0]PETSC ERROR: #5 main() at ex56.c:439
> [0]PETSC ERROR: PETSc Option Table entries:
> [0]PETSC ERROR: -alpha .01
> [0]PETSC ERROR: -cells 4,4,2
> [0]PETSC ERROR: -ex56_dm_mat_type hypre
> [0]PETSC ERROR: -ex56_dm_vec_type cuda
> [0]PETSC ERROR: -ex56_dm_view
> [0]PETSC ERROR: -ksp_monitor
> [0]PETSC ERROR: -ksp_rtol 1.e-8
> [0]PETSC ERROR: -ksp_type cg
> [0]PETSC ERROR: -log_view
> [0]PETSC ERROR: -lx 1.
> [0]PETSC ERROR: -max_conv_its 1
> [0]PETSC ERROR: -options_left
> [0]PETSC ERROR: -pc_hypre_type boomeramg
> [0]PETSC ERROR: -pc_type hypre
> [0]PETSC ERROR: -petscspace_degree 1
> [0]PETSC ERROR: -snes_monitor
> [0]PETSC ERROR: -snes_rtol 1.e-10
> [0]PETSC ERROR: -use_gpu_aware_mpi 0
> [0]PETSC ERROR: -use_mat_nearnullspace true
> *[0]PETSC ERROR: ----------------End of Error Message -------send entire
> error message to petsc-maint at mcs.anl.gov----------*
> MPI_ABORT was invoked on rank 0 in communicator MPI_COMM_WORLD
> with errorcode 77.
> NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes.
> You may or may not see output from other processes, depending on
> exactly when Open MPI kills them.
> *Date: *Monday, 13 December 2021 at 13:58
> On Mon, Dec 13, 2021 at 8:35 AM Karthikeyan Chockalingam - STFC UKRI <
> Thanks Matt. Couple of weeks back you mentioned
> “There are many unstructured grid examples, e.g. SNES ex13, ex17, ex56.
> The solver can run on the GPU, but the vector/matrix FEM assembly does not.
> I am working on that now.”
> I am able to run other examples in ksp/tutorials on gpus. I complied ex56
> in snes/tutorials no differently. The only difference being I didn’t
> specify _dm_vec_type and _dm_vec_type (as you mentioned they are not
> assembled on gpus anyways plus I am working on an unstructured grid thought
> _dm is not right type for this problem). I was hoping to see gpu flops
> recorded for KSPSolve, which I didn’t.
> Okay, I will wait for Mark to comment.
> This (DM) example works like any other, with a prefix, as far as GPU:
> -ex56_dm_vec_type cuda and -ex56_dm_mat_type cusparse, or aijkokkos/kokkos,
> etc.
> Run with -options_left to verify that these are used.
> Kind regards,
> Karthik.
> *From: *Matthew Knepley <knepley at gmail.com>
> *Date: *Monday, 13 December 2021 at 13:17
> *Cc: *Mark Adams <mfadams at lbl.gov>, "petsc-users at mcs.anl.gov" <
> On Mon, Dec 13, 2021 at 7:15 AM Karthikeyan Chockalingam - STFC UKRI <
> Thank you. I was able to confirm both the below options produced the same
> mesh
>  ./ex56 -cells 2,2,1 -max_conv_its 2
> Good
> But I didn’t get how is -cells i,j,k <1,1,1> is related to the number of
> MPI processes.
> It is not. The number of processes is specified independently using
> 'mpiexec -n <p>' or when using the test system NP=<p>.
> (i)     Say I start with -cells 1,1,1 -max_conv its 7; that would
> eventually leave all refinement on level 7 running on 1 MPI process?
> (ii)    Say I start with -cells 2,2,1 -max_conv its n; is it recommended
> to run on 4 MPI processes?
> No, those options do not influence the number of processes.
> I am running ex56 on gpu; I am looking at KSPSolve (or any other event)
> but no gpu flops are recorded in the -log_view?
> I do not think you are running on the GPU then. Mark can comment, but we
> usually specify GPU execution using the Vec and Mat types
> through -dm_vec_type and -dm_mat_type.
>   Thanks,
>      Matt
> For your reference I used the below flags:
> ./ex56 -cells 1,1,1 -max_conv_its 3 -lx 1. -alpha .01 -petscspace_degree 1
> -ksp_type cg -ksp_monitor -ksp_rtol 1.e-8 -pc_type asm -snes_monitor
> -use_mat_nearnullspace true -snes_rtol 1.e-10 -ex56_dm_view -log_view
> Kind regards,
> Karthik.
> *Date: *Sunday, 12 December 2021 at 23:00
> On Sun, Dec 12, 2021 at 3:19 PM Karthikeyan Chockalingam - STFC UKRI <
> Thank for your response that was helpful. I have a couple of questions:
> (i)                  How can I control the level of refinement? I tried
> to pass the flag “-ex56_dm_refine 0” but that didn’t stop the refinement
> from 8 giving 32 cubes.
> I answered this question recently but ex56 clobbers ex56_dm_refine in the
> convergence loop. I have an MR that prints a warning if you provide a
> ex56_dm_refine.
> * snes/ex56 runs a convergence study and confusingly sets the options
> manually, thus erasing your -ex56_dm_refine.
> * To refine, use -max_conv_its N <3>, this sets the number of steps of
> refinement. That is, the length of the convergence study
> * You can adjust where it starts from with -cells i,j,k <1,1,1>
> You do want to set this if you have multiple MPI processes so that the
> size of this mesh is the number of processes. That way it starts with one
> cell per process and refines from there.
> (ii)                What does -cell 2,2,1 correspond to?
> The initial mesh or mesh_0. The convergence test uniformly refines this
> mesh. So if you want to refine this twice you could use -cells 8,8,4
> How can I determine the total number of dofs?
> Unfortunately, that is not printed but you can calculate from the initial
> cell grid, the order of the element and the refinement in each iteration of
> the convergence tests.
> So that I can perform a scaling study by changing the input of the flag
> -cells.
> You can and the convergence test gives you data for a strong speedup study
> in one run. Each solve is put in its own "stage" of the output and you want
> to look at KSPSolve lines in the log_view output.
> This email and any attachments are intended solely for the use of the
> named recipients. If you are not the intended recipient you must not use,
> disclose, copy or distribute this email or any of its attachments and
> should notify the sender immediately and delete this email from your
> system. UK Research and Innovation (UKRI) has taken every reasonable
> precaution to minimise risk of this email or any attachments containing
> viruses or malware but the recipient should carry out its own virus and
> malware checks before opening the attachments. UKRI does not accept any
> liability for any losses or damages which the recipient may sustain due to
> presence of any viruses.
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20211216/89bad4cc/attachment-0001.html>
