[petsc-users] Finite difference approximation of Jacobian
Matthew Knepley
knepley at gmail.com
Mon Dec 13 12:29:24 CST 2021
On Mon, Dec 13, 2021 at 1:16 PM Dave May <dave.mayhem23 at gmail.com> wrote:
> On Sat 11. Dec 2021 at 22:28, Matthew Knepley <knepley at gmail.com> wrote:
>> On Sat, Dec 11, 2021 at 1:58 PM Tang, Qi <tangqi at msu.edu> wrote:
>>> Hi,
>>> Does anyone have comment on finite difference coloring with DMStag? We
>>> are using DMStag and TS to evolve some nonlinear equations implicitly. It
>>> would be helpful to have the coloring Jacobian option with that.
>> Since DMStag produces the Jacobian connectivity,
> This is incorrect.
> The DMCreateMatrix implementation for DMSTAG only sets the number of
> nonzeros (very inaccurately). It does not insert any zero values and thus
> the nonzero structure is actually not defined.
> That is why coloring doesn’t work.
Ah, thanks Dave.
Okay, we should fix that.It is perfectly possible to compute the nonzero
pattern from the DMStag information.
Paging Patrick :)
Matt
> Thanks,
> Dave
> you can use -snes_fd_color_use_mat. It has many options. Here is an
>> example of us using that:
>> https://gitlab.com/petsc/petsc/-/blob/main/src/snes/tutorials/ex19.c#L898
>> Thanks,
>> Matt
>>> Thanks,
>>> Qi
>>> On Oct 15, 2021, at 3:07 PM, Jorti, Zakariae via petsc-users <
>>> petsc-users at mcs.anl.gov> wrote:
>>> Hello,
>>> Does the Jacobian approximation using coloring and finite differencing
>>> of the function evaluation work in DMStag?
>>> Thank you.
>>> Best regards,
>>> Zakariae
>> experiments lead.
>> -- Norbert Wiener
>> https://www.cse.buffalo.edu/~knepley/
>> <http://www.cse.buffalo.edu/~knepley/>
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20211213/cb315bb5/attachment-0001.html>
