[petsc-users] CV_CONV_FAILURE with TSSUNDIALS in PETSc
    Matthew Knepley
    knepley at gmail.com
    Mon Dec  6 13:30:13 CST 2021
On Mon, Dec 6, 2021 at 2:04 PM Sanjoy Kumar Mazumder <mazumder at purdue.edu>
wrote:
> Thank you for your suggestion. I will look into the documentation of
> ts_type bdf and try implementing the same. However, it seems like there is
> not much example on TSBDF available. If you can kindly share with me an
> example on the implementation of TSBDF it would be helpful.
If your problem is defined using IFunction, then it works like any other
implicit solver. You can look at any example that uses -ts_type bdf, such
as TS ex19.
     Matt
> Thank You
> Sanjoy
> Get Outlook for Android <https://aka.ms/AAb9ysg>
> *From:* Matthew Knepley <knepley at gmail.com>
> *Sent:* Monday, December 6, 2021 1:00:49 PM
> *To:* Sanjoy Kumar Mazumder <mazumder at purdue.edu>
> *Cc:* petsc-users at mcs.anl.gov <petsc-users at mcs.anl.gov>
> *Subject:* Re: [petsc-users] CV_CONV_FAILURE with TSSUNDIALS in PETSc
> On Mon, Dec 6, 2021 at 12:17 PM Sanjoy Kumar Mazumder <mazumder at purdue.edu>
> wrote:
> Hi all,
> I am trying to solve a set of coupled stiff ODEs in parallel using
> TSSUNDIALS with SUNDIALS_BDF as 'TSSundialsSetType' in PETSc. I am using a
> sparse Jacobian matrix of type MATMPIAIJ with no preconditioner. It runs
> for some time with a very small initial timestep (~10^-18) and then
> terminates abruptly with the following error:
> [CVODE ERROR]  CVode
>   At t = 1.83912e-06 and h = 3.74248e-13, the corrector convergence test
> failed repeatedly or with |h| = hmin.
> Is there anything I am missing out or not doing properly? Given below is
> the complete error that is showing up after the termination.
> It is hard to know for us. BDF is implicit, so CVODE has to solve a
> (non)linear system, and it looks like this is what fails. I would send it
> to the CVODE team.
> Alternatively, you can run with -ts_type bdf and we would have more
> information to help you with.
>   Thanks,
>      Matt
> [CVODE ERROR]  CVode
> [CVODE ERROR]  CVode
> [CVODE ERROR]  CVode
> [CVODE ERROR]  CVode
> [CVODE ERROR]  CVode
> [CVODE ERROR]  CVode
> [CVODE ERROR]  CVode
> [5]PETSC ERROR:
> [CVODE ERROR]  CVode
> [CVODE ERROR]  CVode
> [7]PETSC ERROR:
> [CVODE ERROR]  CVode
> [CVODE ERROR]  CVode
> [CVODE ERROR]  CVode
> [CVODE ERROR]  CVode
> [CVODE ERROR]  CVode
> [CVODE ERROR]  CVode
> [CVODE ERROR]  CVode
> [CVODE ERROR]  CVode
> [CVODE ERROR]  CVode
> [16]PETSC ERROR:
> [CVODE ERROR]  CVode
> [CVODE ERROR]  CVode
> [19]PETSC ERROR: --------------------- Error Message
> [19]PETSC ERROR: Error in external library
> [19]PETSC ERROR: CVode() fails, CV_CONV_FAILURE
> [19]PETSC ERROR: See https://www.mcs.anl.gov/petsc/documentation/faq.html
> for trouble shooting.
> [19]PETSC ERROR: Petsc Release Version 3.14.5, Mar 03, 2021
> [19]PETSC ERROR: ./ThO2_CD2_P on a arch-linux-c-debug named
> bell-a027.rcac.purdue.edu by mazumder Mon Dec  6 11:45:05 2021
> [19]PETSC ERROR: Configure options --with-cc-mpicc --with-cxx=mpicxx
> --with-fc=mpif90 --download-fblaslapack --download-sundials=yes
> --with-debugging
> [19]PETSC ERROR: #1 TSStep_Sundials() line 156 in
> /home/mazumder/petsc-3.14.5/src/ts/impls/implicit/sundials/sundials.c
> [19]PETSC ERROR: #2 TSStep() line 3759 in
> /home/mazumder/petsc-3.14.5/src/ts/interface/ts.c
> [19]PETSC ERROR: #3 TSSolve() line 4156 in
> [19]PETSC ERROR: #4 User provided function() line 0 in User file
> [0]PETSC ERROR: --------------------- Error Message
> [0]PETSC ERROR: Error in external library
> [0]PETSC ERROR: CVode() fails, CV_CONV_FAILURE
> [0]PETSC ERROR: See https://www.mcs.anl.gov/petsc/documentation/faq.html
> [0]PETSC ERROR: Petsc Release Version 3.14.5, Mar 03, 2021
> [0]PETSC ERROR: ./ThO2_CD2_P on a arch-linux-c-debug named
> [0]PETSC ERROR: Configure options --with-cc-mpicc --with-cxx=mpicxx
> --with-debugging
> [0]PETSC ERROR: #1 TSStep_Sundials() line 156 in
> [0]PETSC ERROR: #2 TSStep() line 3759 in
> [0]PETSC ERROR: #3 TSSolve() line 4156 in
> [0]PETSC ERROR: #4 User provided function() line 0 in User file
> [1]PETSC ERROR: --------------------- Error Message
> [1]PETSC ERROR: Error in external library
> [1]PETSC ERROR: CVode() fails, CV_CONV_FAILURE
> [1]PETSC ERROR: See https://www.mcs.anl.gov/petsc/documentation/faq.html
> [1]PETSC ERROR: Petsc Release Version 3.14.5, Mar 03, 2021
> [1]PETSC ERROR: ./ThO2_CD2_P on a arch-linux-c-debug named
> [1]PETSC ERROR: [2]PETSC ERROR: --------------------- Error Message
> [2]PETSC ERROR: Error in external library
> [2]PETSC ERROR: CVode() fails, CV_CONV_FAILURE
> [2]PETSC ERROR: See https://www.mcs.anl.gov/petsc/documentation/faq.html
> [2]PETSC ERROR: Petsc Release Version 3.14.5, Mar 03, 2021
> [2]PETSC ERROR: ./ThO2_CD2_P on a arch-linux-c-debug named
> [2]PETSC ERROR: Configure options --with-cc-mpicc --with-cxx=mpicxx
> --with-debugging
> [2]PETSC ERROR: #1 TSStep_Sundials() line 156 in
> [2]PETSC ERROR: #2 TSStep() line 3759 in
> [2]PETSC ERROR: #3 TSSolve() line 4156 in
> [2]PETSC ERROR: #4 User provided function() line 0 in User file
> [3]PETSC ERROR: --------------------- Error Message
> [3]PETSC ERROR: Error in external library
> [3]PETSC ERROR: CVode() fails, CV_CONV_FAILURE
> [3]PETSC ERROR: See https://www.mcs.anl.gov/petsc/documentation/faq.html
> [3]PETSC ERROR: Petsc Release Version 3.14.5, Mar 03, 2021
> [3]PETSC ERROR: ./ThO2_CD2_P on a arch-linux-c-debug named
> [3]PETSC ERROR: Configure options --with-cc-mpicc --with-cxx=mpicxx
> --with-debugging
> [3]PETSC ERROR: #1 TSStep_Sundials() line 156 in
> [3]PETSC ERROR: #2 TSStep() line 3759 in
> [3]PETSC ERROR: #3 TSSolve() line 4156 in
> [3]PETSC ERROR: #4 User provided function() line 0 in User file
> [4]PETSC ERROR: --------------------- Error Message
> [4]PETSC ERROR: Error in external library
> [4]PETSC ERROR: CVode() fails, CV_CONV_FAILURE
> [4]PETSC ERROR: See https://www.mcs.anl.gov/petsc/documentation/faq.html
> [4]PETSC ERROR: Petsc Release Version 3.14.5, Mar 03, 2021
> [4]PETSC ERROR: ./ThO2_CD2_P on a arch-linux-c-debug named
> [4]PETSC ERROR: Configure options --with-cc-mpicc --with-cxx=mpicxx
> --with-debugging
> [4]PETSC ERROR: #1 TSStep_Sundials() line 156 in
> [5]PETSC ERROR: Error in external library
> [5]PETSC ERROR: CVode() fails, CV_CONV_FAILURE
> [5]PETSC ERROR: See https://www.mcs.anl.gov/petsc/documentation/faq.html
> [5]PETSC ERROR: Petsc Release Version 3.14.5, Mar 03, 2021
> [5]PETSC ERROR: ./ThO2_CD2_P on a arch-linux-c-debug named
> [5]PETSC ERROR: Configure options --with-cc-mpicc --with-cxx=mpicxx
> --with-debugging
> [5]PETSC ERROR: #1 TSStep_Sundials() line 156 in
> [5]PETSC ERROR: #2 TSStep() line 3759 in
> [5]PETSC ERROR: #3 TSSolve() line 4156 in
> [5]PETSC ERROR: #4 User provided function() line 0 in User file
> [7]PETSC ERROR: Error in external library
> [7]PETSC ERROR: CVode() fails, CV_CONV_FAILURE
> [7]PETSC ERROR: See https://www.mcs.anl.gov/petsc/documentation/faq.html
> [7]PETSC ERROR: Petsc Release Version 3.14.5, Mar 03, 2021
> [7]PETSC ERROR: ./ThO2_CD2_P on a arch-linux-c-debug named
> [7]PETSC ERROR: Configure options --with-cc-mpicc --with-cxx=mpicxx
> --with-debugging
> [7]PETSC ERROR: #1 TSStep_Sundials() line 156 in
> [7]PETSC ERROR: #2 TSStep() line 3759 in
> [7]PETSC ERROR: #3 TSSolve() line 4156 in
> [7]PETSC ERROR: #4 User provided function() line 0 in User file
> [8]PETSC ERROR: --------------------- Error Message
> [8]PETSC ERROR: Error in external library
> [8]PETSC ERROR: CVode() fails, CV_CONV_FAILURE
> [8]PETSC ERROR: See https://www.mcs.anl.gov/petsc/documentation/faq.html
> [8]PETSC ERROR: Petsc Release Version 3.14.5, Mar 03, 2021
> [8]PETSC ERROR: ./ThO2_CD2_P on a arch-linux-c-debug named
> [9]PETSC ERROR: --------------------- Error Message
> [9]PETSC ERROR: Error in external library
> [9]PETSC ERROR: CVode() fails, CV_CONV_FAILURE
> [9]PETSC ERROR: See https://www.mcs.anl.gov/petsc/documentation/faq.html
> [9]PETSC ERROR: Petsc Release Version 3.14.5, Mar 03, 2021
> [9]PETSC ERROR: ./ThO2_CD2_P on a arch-linux-c-debug named
> [9]PETSC ERROR: Configure options --with-cc-mpicc --with-cxx=mpicxx
> --with-debugging
> [9]PETSC ERROR: #1 TSStep_Sundials() line 156 in
> [9]PETSC ERROR: #2 TSStep() line 3759 in
> [9]PETSC ERROR: #3 TSSolve() line 4156 in
> [10]PETSC ERROR: --------------------- Error Message
> [10]PETSC ERROR: Error in external library
> [10]PETSC ERROR: CVode() fails, CV_CONV_FAILURE
> [10]PETSC ERROR: See https://www.mcs.anl.gov/petsc/documentation/faq.html
> [10]PETSC ERROR: Petsc Release Version 3.14.5, Mar 03, 2021
> [10]PETSC ERROR: ./ThO2_CD2_P on a arch-linux-c-debug named
> [10]PETSC ERROR: Configure options --with-cc-mpicc --with-cxx=mpicxx
> --with-debugging
> [10]PETSC ERROR: #1 TSStep_Sundials() line 156 in
> [10]PETSC ERROR: #2 TSStep() line 3759 in
> [10]PETSC ERROR: #3 TSSolve() line 4156 in
> [10]PETSC ERROR: #4 User provided function() line 0 in User file
> [11]PETSC ERROR: --------------------- Error Message
> [11]PETSC ERROR: Error in external library
> [11]PETSC ERROR: CVode() fails, CV_CONV_FAILURE
> [11]PETSC ERROR: See https://www.mcs.anl.gov/petsc/documentation/faq.html
> [11]PETSC ERROR: Petsc Release Version 3.14.5, Mar 03, 2021
> [11]PETSC ERROR: ./ThO2_CD2_P on a arch-linux-c-debug named
> [11]PETSC ERROR: Configure options --with-cc-mpicc --with-cxx=mpicxx
> --with-debugging
> [11]PETSC ERROR: #1 TSStep_Sundials() line 156 in
> [11]PETSC ERROR: #2 TSStep() line 3759 in
> [11]PETSC ERROR: #3 TSSolve() line 4156 in
> [11]PETSC ERROR: #4 User provided function() line 0 in User file
> [12]PETSC ERROR: --------------------- Error Message
> [12]PETSC ERROR: Error in external library
> [12]PETSC ERROR: CVode() fails, CV_CONV_FAILURE
> [12]PETSC ERROR: See https://www.mcs.anl.gov/petsc/documentation/faq.html
> [12]PETSC ERROR: Petsc Release Version 3.14.5, Mar 03, 2021
> [12]PETSC ERROR: ./ThO2_CD2_P on a arch-linux-c-debug named
> [12]PETSC ERROR: Configure options --with-cc-mpicc --with-cxx=mpicxx
> --with-debugging
> [12]PETSC ERROR: #1 TSStep_Sundials() line 156 in
> [12]PETSC ERROR: #2 TSStep() line 3759 in
> [12]PETSC ERROR: #3 TSSolve() line 4156 in
> [12]PETSC ERROR: #4 User provided function() line 0 in User file
> [14]PETSC ERROR: --------------------- Error Message
> [14]PETSC ERROR: Error in external library
> [14]PETSC ERROR: CVode() fails, CV_CONV_FAILURE
> [14]PETSC ERROR: See https://www.mcs.anl.gov/petsc/documentation/faq.html
> [14]PETSC ERROR: Petsc Release Version 3.14.5, Mar 03, 2021
> [14]PETSC ERROR: ./ThO2_CD2_P on a arch-linux-c-debug named
> [14]PETSC ERROR: Configure options --with-cc-mpicc --with-cxx=mpicxx
> --with-debugging
> [14]PETSC ERROR: #1 TSStep_Sundials() line 156 in
> [15]PETSC ERROR: --------------------- Error Message
> [15]PETSC ERROR: Error in external library
> [15]PETSC ERROR: CVode() fails, CV_CONV_FAILURE
> [15]PETSC ERROR: See https://www.mcs.anl.gov/petsc/documentation/faq.html
> [15]PETSC ERROR: Petsc Release Version 3.14.5, Mar 03, 2021
> [16]PETSC ERROR: Error in external library
> [16]PETSC ERROR: CVode() fails, CV_CONV_FAILURE
> [16]PETSC ERROR: See https://www.mcs.anl.gov/petsc/documentation/faq.html
> [16]PETSC ERROR: Petsc Release Version 3.14.5, Mar 03, 2021
> [16]PETSC ERROR: ./ThO2_CD2_P on a arch-linux-c-debug named
> [16]PETSC ERROR: Configure options --with-cc-mpicc --with-cxx=mpicxx
> --with-debugging
> [16]PETSC ERROR: #1 TSStep_Sundials() line 156 in
> [16]PETSC ERROR: #2 TSStep() line 3759 in
> [16]PETSC ERROR: #3 TSSolve() line 4156 in
> [16]PETSC ERROR: #4 User provided function() line 0 in User file
> [17]PETSC ERROR: --------------------- Error Message
> [17]PETSC ERROR: Error in external library
> [17]PETSC ERROR: CVode() fails, CV_CONV_FAILURE
> [17]PETSC ERROR: See https://www.mcs.anl.gov/petsc/documentation/faq.html
> [17]PETSC ERROR: Petsc Release Version 3.14.5, Mar 03, 2021
> [17]PETSC ERROR: [18]PETSC ERROR: --------------------- Error Message
> [18]PETSC ERROR: Error in external library
> [18]PETSC ERROR: CVode() fails, CV_CONV_FAILURE
> [18]PETSC ERROR: See https://www.mcs.anl.gov/petsc/documentation/faq.html
> [18]PETSC ERROR: Petsc Release Version 3.14.5, Mar 03, 2021
> [18]PETSC ERROR: ./ThO2_CD2_P on a arch-linux-c-debug named
> [17]PETSC ERROR: Configure options --with-cc-mpicc --with-cxx=mpicxx
> --with-debugging
> [17]PETSC ERROR: #1 TSStep_Sundials() line 156 in
> [17]PETSC ERROR: #2 TSStep() line 3759 in
> [17]PETSC ERROR: #3 TSSolve() line 4156 in
> [17]PETSC ERROR: #4 User provided function() line 0 in User file
> Configure options --with-cc-mpicc --with-cxx=mpicxx --with-fc=mpif90
> --download-fblaslapack --download-sundials=yes --with-debugging
> [1]PETSC ERROR: #1 TSStep_Sundials() line 156 in
> [1]PETSC ERROR: #2 TSStep() line 3759 in
> [1]PETSC ERROR: #3 TSSolve() line 4156 in
> [1]PETSC ERROR: #4 User provided function() line 0 in User file
> [4]PETSC ERROR: #2 TSStep() line 3759 in
> [4]PETSC ERROR: #3 TSSolve() line 4156 in
> [4]PETSC ERROR: #4 User provided function() line 0 in User file
> [8]PETSC ERROR: Configure options --with-cc-mpicc --with-cxx=mpicxx
> --with-debugging
> [8]PETSC ERROR: #1 TSStep_Sundials() line 156 in
> [8]PETSC ERROR: #2 TSStep() line 3759 in
> [8]PETSC ERROR: #3 TSSolve() line 4156 in
> [8]PETSC ERROR: #4 User provided function() line 0 in User file
> [9]PETSC ERROR: #4 User provided function() line 0 in User file
> [13]PETSC ERROR: --------------------- Error Message
> [13]PETSC ERROR: Error in external library
> [13]PETSC ERROR: CVode() fails, CV_CONV_FAILURE
> [13]PETSC ERROR: See https://www.mcs.anl.gov/petsc/documentation/faq.html
> [13]PETSC ERROR: Petsc Release Version 3.14.5, Mar 03, 2021
> [13]PETSC ERROR: ./ThO2_CD2_P on a arch-linux-c-debug named
> [13]PETSC ERROR: Configure options --with-cc-mpicc --with-cxx=mpicxx
> --with-debugging
> [13]PETSC ERROR: #1 TSStep_Sundials() line 156 in
> [13]PETSC ERROR: #2 TSStep() line 3759 in
> [13]PETSC ERROR: #3 TSSolve() line 4156 in
> [13]PETSC ERROR: #4 User provided function() line 0 in User file
> [14]PETSC ERROR: #2 TSStep() line 3759 in
> [14]PETSC ERROR: #3 TSSolve() line 4156 in
> [14]PETSC ERROR: #4 User provided function() line 0 in User file
> [15]PETSC ERROR: ./ThO2_CD2_P on a arch-linux-c-debug named
> [15]PETSC ERROR: Configure options --with-cc-mpicc --with-cxx=mpicxx
> --with-debugging
> [15]PETSC ERROR: #1 TSStep_Sundials() line 156 in
> [15]PETSC ERROR: #2 TSStep() line 3759 in
> [15]PETSC ERROR: #3 TSSolve() line 4156 in
> [15]PETSC ERROR: #4 User provided function() line 0 in User file
> [18]PETSC ERROR: #1 TSStep_Sundials() line 156 in
> [18]PETSC ERROR: #2 TSStep() line 3759 in
> [18]PETSC ERROR: #3 TSSolve() line 4156 in
> [18]PETSC ERROR: #4 User provided function() line 0 in User file
> [6]PETSC ERROR: --------------------- Error Message
> [6]PETSC ERROR: Error in external library
> [6]PETSC ERROR: CVode() fails, CV_CONV_FAILURE
> [6]PETSC ERROR: See https://www.mcs.anl.gov/petsc/documentation/faq.html
> [6]PETSC ERROR: Petsc Release Version 3.14.5, Mar 03, 2021
> [6]PETSC ERROR: ./ThO2_CD2_P on a arch-linux-c-debug named
> [6]PETSC ERROR: Configure options --with-cc-mpicc --with-cxx=mpicxx
> --with-debugging
> [6]PETSC ERROR: #1 TSStep_Sundials() line 156 in
> [6]PETSC ERROR: #2 TSStep() line 3759 in
> [6]PETSC ERROR: #3 TSSolve() line 4156 in
> [6]PETSC ERROR: #4 User provided function() line 0 in User file
> MPI_ABORT was invoked on rank 0 in communicator MPI_COMM_SELF
> with errorcode 76.
> NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes.
> You may or may not see output from other processes, depending on
> exactly when Open MPI kills them.
> [bell-a027.rcac.purdue.edu:29752] 15 more processes have sent help
> message help-mpi-api.txt / mpi-abort
> [bell-a027.rcac.purdue.edu:29752] Set MCA parameter
> "orte_base_help_aggregate" to 0 to see all help / error messages
> Thanks
> With regards,
> Sanjoy
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20211206/cca1c03b/attachment-0001.html>
