[petsc-users] KSPSolve with MPIAIJ with non-square 'diagonal parts'
    Stefano Zampini
    stefano.zampini at gmail.com
    Mon Aug 30 15:42:21 CDT 2021
What is the error you are getting from the KSP? Default solver in parallel in BlockJacobi+ILU which does not work for non-square matrices. You do not need to call PCSetFromOptions on the pc. Just call KSPSetFromOptions and run with -pc_type none
> On Aug 30, 2021, at 9:17 PM, Olivier Jamond <olivier.jamond at cea.fr> wrote:
> Hello,
> I am sorry because I surely miss something, but I cannot manage to solve a problem with a MPIAIJ matrix which has non-square 'diagonal parts'.
> I copy/paste at the bottom of this message a very simple piece of code which causes me troubles. I this code I try to do 'x=KSP(A)*b' (with gmres/jacobi), but this fails whereas a matrix multiplication 'b=A*x' seems to work. Is ksp with such a matrix supposed to work (I can't find anything in the documentation about that, so I guess that it is...) ?
> Many thanks,
> Olivier
> NB: this code should be launched with exactly 3 procs
> #include "petscsys.h" /* framework routines */
> #include "petscvec.h" /* vectors */
> #include "petscmat.h" /* matrices */
> #include "petscksp.h"
> #include <vector>
> #include <string>
> #include <iostream>
> #include <numeric>
> static char help[] = "Trying to solve a linear system on a sub-block of a matrix\n\n";
> int main(int argc, char **argv)
>   MPI_Init(NULL, NULL);
>   PetscErrorCode ierr;
>   ierr = PetscInitialize(&argc, &argv, NULL, help);
>   CHKERRQ(ierr);
>   // clang-format off
>   std::vector<std::vector<double>> AA = {
>       { 1,  2,  0, /**/ 0,  3, /**/ 0,  0,  4},
>       { 0,  5,  6, /**/ 7,  0, /**/ 0,  8,  0},
>       { 9,  0, 10, /**/11,  0, /**/ 0, 12,  0},
>       {13,  0, 14, /**/15, 16, /**/17,  0,  0},
>       { 0, 18,  0, /**/19, 20, /**/21,  0,  0},
>       { 0,  0,  0, /**/22, 23, /**/ 1, 24,  0},
>       {25, 26, 27, /**/ 0,  0, /**/28, 29,  0},
>       {30,  0,  0, /**/31, 32, /**/33,  0, 34},
>   std::vector<double> bb = {1.,
>                             1.,
>                             1.,
>                             1.,
>                             1.,
>                             1.,
>                             1.,
>                             1.};
>   std::vector<int> nDofsRow = {3, 3, 2};
>   std::vector<int> nDofsCol = {3, 2, 3};
>   // clang-format on
>   int NDofs = std::accumulate(nDofsRow.begin(), nDofsRow.end(), 0);
>   int pRank, nProc;
>   MPI_Comm_rank(PETSC_COMM_WORLD, &pRank);
>   MPI_Comm_size(PETSC_COMM_WORLD, &nProc);
>   if (nProc != 3) {
>     std::cerr << "THIS TEST MUST BE LAUNCHED WITH EXACTLY 3 PROCS\n";
>     abort();
>   Mat A;
>   MatCreate(PETSC_COMM_WORLD, &A);
>   MatSetType(A, MATMPIAIJ);
>   MatSetSizes(A, nDofsRow[pRank], nDofsCol[pRank], PETSC_DETERMINE, PETSC_DETERMINE);
>   MatMPIAIJSetPreallocation(A, NDofs, NULL, NDofs, NULL);
>   Vec b;
>   VecCreate(PETSC_COMM_WORLD, &b);
>   VecSetType(b, VECMPI);
>   VecSetSizes(b, nDofsRow[pRank], PETSC_DECIDE);
>   if (pRank == 0) {
>     for (int i = 0; i < NDofs; ++i) {
>       for (int j = 0; j < NDofs; ++j) {
>         if (AA[i][j] != 0.) {
>           MatSetValue(A, i, j, AA[i][j], ADD_VALUES);
>       VecSetValue(b, i, bb[i], ADD_VALUES);
>   MatAssemblyBegin(A, MAT_FINAL_ASSEMBLY);
>   MatAssemblyEnd(A, MAT_FINAL_ASSEMBLY);
>   VecAssemblyBegin(b);
>   VecAssemblyEnd(b);
>   PetscViewerPushFormat(PETSC_VIEWER_STDOUT_WORLD, PETSC_VIEWER_ASCII_DENSE);
>   MatView(A, PETSC_VIEWER_STDOUT_WORLD);
>   VecView(b, PETSC_VIEWER_STDOUT_WORLD);
>   KSP ksp;
>   KSPCreate(PETSC_COMM_WORLD, &ksp);
>   KSPSetOperators(ksp, A, A);
>   KSPSetFromOptions(ksp);
>   PC pc;
>   KSPGetPC(ksp, &pc);
>   PCSetFromOptions(pc);
>   Vec x;
>   MatCreateVecs(A, &x, NULL);
>   ierr = KSPSolve(ksp, b, x);    // this fails
>   MatMult(A, x, b);              // whereas the seems to be ok...
>   VecView(x, PETSC_VIEWER_STDOUT_WORLD);
>   MPI_Finalize();
>   return 0;
