[petsc-users] KSPSolve with MPIAIJ with non-square 'diagonal parts'
Olivier Jamond
olivier.jamond at cea.fr
Mon Aug 30 13:17:16 CDT 2021
Hello,
I am sorry because I surely miss something, but I cannot manage to solve
a problem with a MPIAIJ matrix which has non-square 'diagonal parts'.
I copy/paste at the bottom of this message a very simple piece of code
which causes me troubles. I this code I try to do 'x=KSP(A)*b' (with
gmres/jacobi), but this fails whereas a matrix multiplication 'b=A*x'
seems to work. Is ksp with such a matrix supposed to work (I can't find
anything in the documentation about that, so I guess that it is...) ?
Many thanks,
Olivier
NB: this code should be launched with exactly 3 procs
#include "petscsys.h" /* framework routines */
#include "petscvec.h" /* vectors */
#include "petscmat.h" /* matrices */
#include "petscksp.h"
#include <vector>
#include <string>
#include <iostream>
#include <numeric>
static char help[] = "Trying to solve a linear system on a sub-block of
a matrix\n\n";
int main(int argc, char **argv)
MPI_Init(NULL, NULL);
PetscErrorCode ierr;
ierr = PetscInitialize(&argc, &argv, NULL, help);
CHKERRQ(ierr);
// clang-format off
std::vector<std::vector<double>> AA = {
{ 1, 2, 0, /**/ 0, 3, /**/ 0, 0, 4},
{ 0, 5, 6, /**/ 7, 0, /**/ 0, 8, 0},
{ 9, 0, 10, /**/11, 0, /**/ 0, 12, 0},
{13, 0, 14, /**/15, 16, /**/17, 0, 0},
{ 0, 18, 0, /**/19, 20, /**/21, 0, 0},
{ 0, 0, 0, /**/22, 23, /**/ 1, 24, 0},
{25, 26, 27, /**/ 0, 0, /**/28, 29, 0},
{30, 0, 0, /**/31, 32, /**/33, 0, 34},
std::vector<double> bb = {1.,
1.,
1.,
1.,
1.,
1.,
1.,
1.};
std::vector<int> nDofsRow = {3, 3, 2};
std::vector<int> nDofsCol = {3, 2, 3};
// clang-format on
int NDofs = std::accumulate(nDofsRow.begin(), nDofsRow.end(), 0);
int pRank, nProc;
MPI_Comm_rank(PETSC_COMM_WORLD, &pRank);
MPI_Comm_size(PETSC_COMM_WORLD, &nProc);
if (nProc != 3) {
std::cerr << "THIS TEST MUST BE LAUNCHED WITH EXACTLY 3 PROCS\n";
abort();
Mat A;
MatCreate(PETSC_COMM_WORLD, &A);
MatSetType(A, MATMPIAIJ);
MatSetSizes(A, nDofsRow[pRank], nDofsCol[pRank], PETSC_DETERMINE,
PETSC_DETERMINE);
MatMPIAIJSetPreallocation(A, NDofs, NULL, NDofs, NULL);
Vec b;
VecCreate(PETSC_COMM_WORLD, &b);
VecSetType(b, VECMPI);
VecSetSizes(b, nDofsRow[pRank], PETSC_DECIDE);
if (pRank == 0) {
for (int i = 0; i < NDofs; ++i) {
for (int j = 0; j < NDofs; ++j) {
if (AA[i][j] != 0.) {
MatSetValue(A, i, j, AA[i][j], ADD_VALUES);
VecSetValue(b, i, bb[i], ADD_VALUES);
MatAssemblyBegin(A, MAT_FINAL_ASSEMBLY);
MatAssemblyEnd(A, MAT_FINAL_ASSEMBLY);
VecAssemblyBegin(b);
VecAssemblyEnd(b);
PetscViewerPushFormat(PETSC_VIEWER_STDOUT_WORLD,
PETSC_VIEWER_ASCII_DENSE);
MatView(A, PETSC_VIEWER_STDOUT_WORLD);
VecView(b, PETSC_VIEWER_STDOUT_WORLD);
KSP ksp;
KSPCreate(PETSC_COMM_WORLD, &ksp);
KSPSetOperators(ksp, A, A);
KSPSetFromOptions(ksp);
PC pc;
KSPGetPC(ksp, &pc);
PCSetFromOptions(pc);
Vec x;
MatCreateVecs(A, &x, NULL);
ierr = KSPSolve(ksp, b, x); // this fails
MatMult(A, x, b); // whereas the seems to be ok...
VecView(x, PETSC_VIEWER_STDOUT_WORLD);
MPI_Finalize();
return 0;
