[petsc-users] issues with mpi uni
Janne Ruuskanen (TAU) janne.ruuskanen at tuni.fi
Mon Aug 23 05:45:34 CDT 2021
Assumingly, I have an issue using petsc and openmpi together in my c++ code.
See the code there:
https://github.com/halbux/sparselizard/blob/master/src/slmpi.cpp
So when I run:
slmpi::initialize();
slmpi::count();
slmpi::finalize();
I get the following error:
*** The MPI_Comm_size() function was called before MPI_INIT was invoked.
*** This is disallowed by the MPI standard.
*** Your MPI job will now abort.
Have you experienced anything similar with people trying to link openmpi and petsc into the same executable?
Best regards,
Janne Ruuskanen
