[petsc-users] Improving efficiency of slepc usage
Matthew Knepley
knepley at gmail.com
Fri Aug 20 09:12:58 CDT 2021
On Fri, Aug 20, 2021 at 6:55 AM dazza simplythebest <sayosale at hotmail.com>
wrote:
> Dear Jose,
> Many thanks for your response, I have been investigating this issue
> with a few more calculations
> today, hence the slightly delayed response.
> The problem is actually derived from a fluid dynamics problem, so to allow
> an easier exploration of things
> I first downsized the resolution of the underlying fluid solver while
> keeping all the physical parameters
> the same - i.e. I would get a smaller matrix that should be solving the
> same physical problem as the original
> larger matrix but to lower accuracy.
> *Results*
> *Small matrix (N= 21168) - everything good!*
> This converged when using the -eps_largest_real approach (taking 92
> iterations for nev=10,
> tol= 5.0000E-06 and ncv = 300), and also when using the shift-invert
> approach, converging
> very impressively in a single iteration ! Interestingly it did this both
> for a non-zero -eps_target
> and also for a zero -eps_target.
> *Large matrix (N=50400)- works for -eps_largest_real , fails for st_type
> sinvert *
> I have just double checked again that the code does run properly when we
> use the -eps_largest_real
> option - indeed I ran it with a small nev and large tolerance (nev = 4,
> tol= -eps_tol 5.0e-4 , ncv = 300)
> and with these parameters convergence was obtained in 164 iterations,
> which took 6 hours on the
> machine I was running it on. Furthermore the eigenvalues seem to be
> ballpark correct; for this large
> higher resolution case (although with lower slepc tolerance) we obtain
> 1789.56816314173 -4724.51319554773i
> as the eigenvalue with largest real part, while the smaller matrix (same
> physical problem but at lower resolution case)
> found this eigenvalue to be 1831.11845726501 -4787.54519511345i , which
> means the agreement is in line
> with expectations.
> *Unfortunately though the code does still crash though when I try to do
> shift-invert for the large matrix case *,
> whether or not I use a non-zero -eps_target. For reference this is the
> command line used :
> -eps_nev 10 -eps_ncv 300 -log_view -eps_view -eps_target 0.1
> -st_type sinvert -eps_monitor :monitor_output05.txt
> To be precise the code crashes soon after calling EPSSolve (it
> successfully calls
> MatCreateVecs, EPSCreate, EPSSetOperators, EPSSetProblemType and
> EPSSetFromOptions).
> By crashes I mean that I do not even get any error messages from
> slepc/PETSC, and do not even get the
> 'EPS Object: 16 MPI processes' message - I simply get a MPI/Fortran
> 'KILLED BY SIGNAL: 9 (Killed)' message
> as soon as EPSsolve is called.
Hi Dan,
It would help track this error down if we had a stack trace. You can get a
stack trace from the debugger. You run with
-start_in_debugger
which should launch the debugger (usually), and then type
cont
to continue, and then
where
to get the stack trace when it crashes, or 'bt' on lldb.
Matt
> Do you have any ideas as to why this larger matrix case should fail when
> using shift-invert but succeed when using
> -eps_largest_real ? The fact that the program works and produces correct
> results
> when using the -eps_largest_real option suggests that there is probably
> nothing wrong with the specification
> of the problem or the matrices ? It is strange how there is no error
> message from slepc / Petsc ... the
> only idea I have at the moment is that perhaps max memory has been
> exceeded, which could cause such a sudden
> shutdown? For your reference when running the large matrix case with the
> -eps_largest_real option I am using
> about 36 GB of the 148GB available on this machine - does the shift
> invert approach require substantially
> more memory for example ?
> I would be very grateful if you have any suggestions to resolve this
> issue or even ways to clarify it further,
> the performance I have seen with the shift-invert for the small matrix is
> so impressive it would be great to
> get that working for the full-size problem.
> Many thanks and best wishes,
> Dan.
> *From:* Jose E. Roman <jroman at dsic.upv.es>
> *Sent:* Thursday, August 19, 2021 7:58 AM
> *To:* dazza simplythebest <sayosale at hotmail.com>
> *Cc:* PETSc <petsc-users at mcs.anl.gov>
> *Subject:* Re: [petsc-users] Improving efficiency of slepc usage
> In A) convergence may be slow, especially if the wanted eigenvalues have
> small magnitude. I would not say 600 iterations is a lot, you probably need
> many more. In most cases, approach B) is better because it improves
> convergence of eigenvalues close to the target, but it requires prior
> knowledge of your spectrum distribution in order to choose an appropriate
> target.
> In B) what do you mean that it crashes. If you get an error about
> factorization, it means that your A-matrix is singular, In that case, try
> using a nonzero target -eps_target 0.1
> Jose
> > El 19 ago 2021, a las 7:12, dazza simplythebest <sayosale at hotmail.com>
> escribió:
> > Dear All,
> > I am planning on using slepc to do a large number of
> eigenvalue calculations
> > of a generalized eigenvalue problem, called from a program written in
> fortran using MPI.
> > Thus far I have successfully installed the slepc/PETSc software, both
> locally and on a cluster,
> > and on smaller test problems everything is working well; the matrices
> are efficiently and
> > correctly constructed and slepc returns the correct spectrum. I am just
> now starting to move
> > towards now solving the full-size 'production run' problems, and would
> appreciate some
> > general advice on how to improve the solver's performance.
> > In particular, I am currently trying to solve the problem Ax = lambda Bx
> whose matrices
> > are of size 50000 (this is the smallest 'production run' problem I will
> be tackling), and are
> > complex, non-Hermitian. In most cases I aim to find the eigenvalues
> with the largest real part,
> > although in other cases I will also be interested in finding the
> eigenvalues whose real part
> > is close to zero.
> > A)
> > Calling slepc 's EPS solver with the following options:
> > -eps_nev 10 -log_view -eps_view -eps_max_it 600 -eps_ncv 140 -eps_tol
> 5.0e-6 -eps_largest_real -eps_monitor :monitor_output.txt
> > led to the code successfully running, but failing to find any
> eigenvalues within the maximum 600 iterations
> > (examining the monitor output it did appear to be very slowly
> approaching convergence).
> > B)
> > On the same problem I have also tried a shift-invert transformation
> using the options
> > -eps_nev 10 -eps_ncv 140 -eps_target 0.0+0.0i -st_type sinvert
> > -in this case the code crashed at the point it tried to call slepc, so
> perhaps I have incorrectly specified these options ?
> > Does anyone have any suggestions as to how to improve this performance (
> or find out more about the problem) ?
> > In the case of A) I can see from watching the slepc videos that
> increasing ncv
> > may help, but I am wondering , since 600 is a large number of
> iterations, whether there
> > maybe something else going on - e.g. perhaps some alternative
> preconditioner may help ?
> > In the case of B), I guess there must be some mistake in these command
> line options?
> > Again, any advice will be greatly appreciated.
> > Best wishes, Dan.
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210820/fdccdf49/attachment-0001.html>
