[petsc-users] Improving efficiency of slepc usage
dazza simplythebest sayosale at hotmail.com
Fri Aug 20 06:55:29 CDT 2021
Dear Jose,
    Many thanks for your response, I have been investigating this issue with a few more calculations
today, hence the slightly delayed response.
The problem is actually derived from a fluid dynamics problem, so to allow an easier exploration of things
I first downsized the resolution of the underlying fluid solver while keeping all the physical parameters
 the same - i.e. I would get a smaller matrix that should be solving the same physical problem as the original
 larger matrix but to lower accuracy.
Results
Small matrix (N= 21168) - everything good!
This converged when using the -eps_largest_real approach (taking 92 iterations for nev=10,
tol= 5.0000E-06 and ncv = 300), and also when using the shift-invert approach, converging
very impressively in a single iteration ! Interestingly it did this both for a non-zero  -eps_target
 and also for a zero  -eps_target.
Large matrix (N=50400)- works for -eps_largest_real , fails for st_type sinvert
I have just double checked again that the code does run properly when we use the -eps_largest_real
option - indeed I ran it with a small nev and large tolerance (nev = 4, tol= -eps_tol 5.0e-4 , ncv = 300)
and with these parameters convergence was obtained in 164 iterations, which took 6 hours on the
machine I was running it on. Furthermore the eigenvalues seem to be ballpark correct; for this large
higher resolution case (although with lower slepc tolerance) we obtain 1789.56816314173 -4724.51319554773i
 as the eigenvalue with largest real part, while the smaller matrix (same physical problem but at lower resolution case)
found this eigenvalue to be 1831.11845726501 -4787.54519511345i , which means the agreement is in line
with expectations.
Unfortunately though the code does still crash though when I try to do shift-invert for the large matrix case ,
 whether or not I use a non-zero  -eps_target. For reference this is the command line used :
-eps_nev 10    -eps_ncv 300  -log_view -eps_view   -eps_target 0.1 -st_type sinvert -eps_monitor :monitor_output05.txt
To be precise the code crashes soon after calling EPSSolve (it successfully calls
 MatCreateVecs, EPSCreate,  EPSSetOperators, EPSSetProblemType and EPSSetFromOptions).
By crashes I mean that I do not even get any error messages from slepc/PETSC, and do not even get the
'EPS Object: 16 MPI processes' message - I simply get a  MPI/Fortran 'KILLED BY SIGNAL: 9 (Killed)' message
 as soon as EPSsolve is called.
Do you have any ideas as to why this larger matrix case should fail when using shift-invert but succeed when using
-eps_largest_real ? The fact that the program works and produces correct results
when using the -eps_largest_real  option suggests that there is probably nothing wrong with the specification
of the problem or the matrices ? It is strange how there is no error message from slepc / Petsc ... the
only idea I have at the moment is that perhaps max memory has been exceeded, which could cause such a sudden
shutdown? For your reference when running the large matrix case with the -eps_largest_real option I am using
about 36 GB of the 148GB available on this machine  - does the shift invert approach require substantially
more memory for example ?
  I would be very grateful if you have any suggestions to resolve this issue or even ways to clarify it further,
 the performance I have seen with the shift-invert for the small matrix is so impressive it would be great to
 get that working for the full-size problem.
   Many thanks and best wishes,
                                  Dan.
Sent: Thursday, August 19, 2021 7:58 AM
To: dazza simplythebest <sayosale at hotmail.com>
Cc: PETSc <petsc-users at mcs.anl.gov>
Subject: Re: [petsc-users] Improving efficiency of slepc usage
In A) convergence may be slow, especially if the wanted eigenvalues have small magnitude. I would not say 600 iterations is a lot, you probably need many more. In most cases, approach B) is better because it improves convergence of eigenvalues close to the target, but it requires prior knowledge of your spectrum distribution in order to choose an appropriate target.
In B) what do you mean that it crashes. If you get an error about factorization, it means that your A-matrix is singular, In that case, try using a nonzero target -eps_target 0.1
Jose
> El 19 ago 2021, a las 7:12, dazza simplythebest <sayosale at hotmail.com> escribió:
> Dear All,
>             I am planning on using slepc to do a large number of eigenvalue calculations
>  of a generalized eigenvalue problem, called from a program written in fortran using MPI.
>  Thus far I have successfully installed the slepc/PETSc software, both locally and on a cluster,
>  and on smaller test problems everything is working well; the matrices are efficiently and
> correctly constructed and slepc returns the correct spectrum. I am just now starting to move
> towards now solving the full-size 'production run' problems, and would appreciate some
> general advice on how to improve the solver's performance.
> In particular, I am currently trying to solve the problem Ax = lambda Bx whose matrices
> are of size 50000 (this is the smallest 'production run' problem I will be tackling), and are
> complex, non-Hermitian.  In most cases I aim to find the eigenvalues with the largest real part,
> although in other cases I will also be interested in finding the eigenvalues whose real part
> is close to zero.
> A)
> Calling slepc 's EPS solver with the following options:
> -eps_nev 10   -log_view -eps_view -eps_max_it 600 -eps_ncv 140  -eps_tol 5.0e-6  -eps_largest_real -eps_monitor :monitor_output.txt
> led to the code successfully running, but failing to find any eigenvalues within the maximum 600 iterations
> (examining the monitor output it did appear to be very slowly approaching convergence).
> B)
> On the same problem I have also tried a shift-invert transformation using the options
> -eps_nev 10    -eps_ncv 140    -eps_target 0.0+0.0i  -st_type sinvert
> -in this case the code crashed at the point it tried to call slepc, so perhaps I have incorrectly specified these options ?
> Does anyone have any suggestions as to how to improve this performance ( or find out more about the problem) ?
> In the case of A) I can see from watching the slepc   videos that increasing ncv
> may help, but I am wondering , since 600 is a large number of iterations, whether there
> maybe something else going on - e.g. perhaps some alternative preconditioner may help ?
> In the case of B), I guess there must be some mistake in these command line options?
>  Again, any advice will be greatly appreciated.
>      Best wishes,  Dan.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210820/ea7446d3/attachment-0001.html>
