[petsc-users] Reaching limit number of communicator with Spectrum MPI
Satish Balay
balay at mcs.anl.gov
Wed Aug 18 15:38:26 CDT 2021
Is the communicator used to create PETSc objects MPI_COMM_WORLD?
If so - try changing it to PETSC_COMM_WORLD
Satish
On Wed, 18 Aug 2021, Feimi Yu wrote:
> Hi Junchao,
> Thank you for the suggestion! I'm using the deal.ii wrapper
> dealii::PETScWrappers::PreconditionBase to handle the PETSc preconditioners,
> and the wrappers does the destroy when the preconditioner is reinitialized or
> gets out of scope. I just double-checked, this is called to make sure the old
> matrices are destroyed:
> void
> PreconditionBase::clear()
> matrix = nullptr;
> if (pc != nullptr)
> PetscErrorCode ierr = PCDestroy(&pc);
> pc = nullptr;
> AssertThrow(ierr == 0, ExcPETScError(ierr));
> Thanks!
> Feimi
> On 8/18/21 4:23 PM, Junchao Zhang wrote:
> > On Wed, Aug 18, 2021 at 12:52 PM Feimi Yu <yuf2 at rpi.edu
> > <mailto:yuf2 at rpi.edu>> wrote:
> > Hi,
> > I was trying to run a simulation with a PETSc-wrapped Hypre
> > preconditioner, and encountered this problem:
> > [dcs122:133012] Out of resources: all 4095 communicator IDs have
> > been used.
> > [19]PETSC ERROR: --------------------- Error Message
> > [19]PETSC ERROR: General MPI error
> > [19]PETSC ERROR: MPI error 17 MPI_ERR_INTERN: internal error
> > [19]PETSC ERROR: See
> > https://www.mcs.anl.gov/petsc/documentation/faq.html
> > <https://www.mcs.anl.gov/petsc/documentation/faq.html> for trouble
> > shooting.
> > [19]PETSC ERROR: Petsc Release Version 3.15.2, unknown
> > [19]PETSC ERROR: ./main on a arch-linux-c-opt named dcs122 by
> > CFSIfmyu Wed Aug 11 19:51:47 2021
> > [19]PETSC ERROR: [dcs122:133010] Out of resources: all 4095
> > communicator IDs have been used.
> > [18]PETSC ERROR: --------------------- Error Message
> > [18]PETSC ERROR: General MPI error
> > [18]PETSC ERROR: MPI error 17 MPI_ERR_INTERN: internal error
> > [18]PETSC ERROR: See
> > shooting.
> > [18]PETSC ERROR: Petsc Release Version 3.15.2, unknown
> > [18]PETSC ERROR: ./main on a arch-linux-c-opt named dcs122 by
> > [18]PETSC ERROR: Configure options --download-scalapack
> > --download-mumps --download-hypre --with-cc=mpicc
> > --with-cxx=mpicxx --with-fc=mpif90 --with-cudac=0
> > --with-debugging=0
> > --with-blaslapack-dir=/gpfs/u/home/CFSI/CFSIfmyu/barn-shared/dcs-rh8/lapack-build/
> > [18]PETSC ERROR: #1 <https://itssc.rpi.edu/hc/requests/1>
> > MatCreate_HYPRE() at
> > /gpfs/u/barn/CFSI/shared/dcs-rh8/petsc/src/mat/impls/hypre/mhypre.c:2120
> > [18]PETSC ERROR: #2 <https://itssc.rpi.edu/hc/requests/2>
> > MatSetType() at
> > /gpfs/u/barn/CFSI/shared/dcs-rh8/petsc/src/mat/interface/matreg.c:91
> > [18]PETSC ERROR: #3 <https://itssc.rpi.edu/hc/requests/3>
> > MatConvert_AIJ_HYPRE() at
> > /gpfs/u/barn/CFSI/shared/dcs-rh8/petsc/src/mat/impls/hypre/mhypre.c:392
> > [18]PETSC ERROR: #4 <https://itssc.rpi.edu/hc/requests/4>
> > MatConvert() at
> > /gpfs/u/barn/CFSI/shared/dcs-rh8/petsc/src/mat/interface/matrix.c:4439
> > [18]PETSC ERROR: #5 <https://itssc.rpi.edu/hc/requests/5>
> > PCSetUp_HYPRE() at
> > /gpfs/u/barn/CFSI/shared/dcs-rh8/petsc/src/ksp/pc/impls/hypre/hypre.c:240
> > [18]PETSC ERROR: #6 <https://itssc.rpi.edu/hc/requests/6>
> > PCSetUp() at
> > /gpfs/u/barn/CFSI/shared/dcs-rh8/petsc/src/ksp/pc/interface/precon.c:1015
> > Configure options --download-scalapack --download-mumps
> > --download-hypre --with-cc=mpicc --with-cxx=mpicxx
> > --with-fc=mpif90 --with-cudac=0 --with-debugging=0
> > [19]PETSC ERROR: #1 <https://itssc.rpi.edu/hc/requests/1>
> > [19]PETSC ERROR: #2 <https://itssc.rpi.edu/hc/requests/2>
> > MatSetType() at
> > [19]PETSC ERROR: #3 <https://itssc.rpi.edu/hc/requests/3>
> > [19]PETSC ERROR: #4 <https://itssc.rpi.edu/hc/requests/4>
> > MatConvert() at
> > [19]PETSC ERROR: #5 <https://itssc.rpi.edu/hc/requests/5>
> > PCSetUp_HYPRE() at
> > [19]PETSC ERROR: #6 <https://itssc.rpi.edu/hc/requests/6>
> > PCSetUp() at
> > It seems that MPI_Comm_dup() at
> > petsc/src/mat/impls/hypre/mhypre.c:2120 caused the problem. Since
> > mine is a time-dependent problem, MatCreate_HYPRE() is called
> > every time the new system matrix is assembled. The above error
> > message is reported after ~4095 calls of MatCreate_HYPRE(), which
> > is around 455 time steps in my code. Here is some basic compiler
> > information:
> > Can you destroy old matrices to free MPI communicators? Otherwise, you run
> > into a limitation we knew before.
> > IBM Spectrum MPI 10.4.0
> > GCC 8.4.1
> > I've never had this problem before with OpenMPI or MPICH
> > implementation, so I was wondering if this can be resolved from my
> > end, or it's an implementation specific problem.
> > Thanks!
> > Feimi
