[petsc-users] Reaching limit number of communicator with Spectrum MPI
Feimi Yu
yuf2 at rpi.edu
Wed Aug 18 15:37:10 CDT 2021
My previous message may sound misleading. This problem happens despite
the fact that the old matrices are destroyed.
Feimi
On 8/18/21 4:31 PM, Feimi Yu wrote:
> Hi Junchao,
> Thank you for the suggestion! I'm using the deal.ii wrapper
> dealii::PETScWrappers::PreconditionBase to handle the PETSc
> preconditioners, and the wrappers does the destroy when the
> preconditioner is reinitialized or gets out of scope. I just
> double-checked, this is called to make sure the old matrices are
> destroyed:
> void
> PreconditionBase::clear()
> matrix = nullptr;
> if (pc != nullptr)
> PetscErrorCode ierr = PCDestroy(&pc);
> pc = nullptr;
> AssertThrow(ierr == 0, ExcPETScError(ierr));
> Thanks!
> Feimi
> On 8/18/21 4:23 PM, Junchao Zhang wrote:
>> On Wed, Aug 18, 2021 at 12:52 PM Feimi Yu <yuf2 at rpi.edu
>> <mailto:yuf2 at rpi.edu>> wrote:
>> Hi,
>> I was trying to run a simulation with a PETSc-wrapped Hypre
>> preconditioner, and encountered this problem:
>> [dcs122:133012] Out of resources: all 4095 communicator IDs have
>> been used.
>> [19]PETSC ERROR: --------------------- Error Message
>> [19]PETSC ERROR: General MPI error
>> [19]PETSC ERROR: MPI error 17 MPI_ERR_INTERN: internal error
>> [19]PETSC ERROR: See
>> https://www.mcs.anl.gov/petsc/documentation/faq.html
>> <https://www.mcs.anl.gov/petsc/documentation/faq.html> for
>> trouble shooting.
>> [19]PETSC ERROR: Petsc Release Version 3.15.2, unknown
>> [19]PETSC ERROR: ./main on a arch-linux-c-opt named dcs122 by
>> CFSIfmyu Wed Aug 11 19:51:47 2021
>> [19]PETSC ERROR: [dcs122:133010] Out of resources: all 4095
>> communicator IDs have been used.
>> [18]PETSC ERROR: --------------------- Error Message
>> [18]PETSC ERROR: General MPI error
>> [18]PETSC ERROR: MPI error 17 MPI_ERR_INTERN: internal error
>> [18]PETSC ERROR: See
>> trouble shooting.
>> [18]PETSC ERROR: Petsc Release Version 3.15.2, unknown
>> [18]PETSC ERROR: ./main on a arch-linux-c-opt named dcs122 by
>> [18]PETSC ERROR: Configure options --download-scalapack
>> --download-mumps --download-hypre --with-cc=mpicc
>> --with-cxx=mpicxx --with-fc=mpif90 --with-cudac=0
>> --with-debugging=0
>> --with-blaslapack-dir=/gpfs/u/home/CFSI/CFSIfmyu/barn-shared/dcs-rh8/lapack-build/
>> [18]PETSC ERROR: #1 <https://itssc.rpi.edu/hc/requests/1>
>> MatCreate_HYPRE() at
>> /gpfs/u/barn/CFSI/shared/dcs-rh8/petsc/src/mat/impls/hypre/mhypre.c:2120
>> [18]PETSC ERROR: #2 <https://itssc.rpi.edu/hc/requests/2>
>> MatSetType() at
>> /gpfs/u/barn/CFSI/shared/dcs-rh8/petsc/src/mat/interface/matreg.c:91
>> [18]PETSC ERROR: #3 <https://itssc.rpi.edu/hc/requests/3>
>> MatConvert_AIJ_HYPRE() at
>> /gpfs/u/barn/CFSI/shared/dcs-rh8/petsc/src/mat/impls/hypre/mhypre.c:392
>> [18]PETSC ERROR: #4 <https://itssc.rpi.edu/hc/requests/4>
>> MatConvert() at
>> /gpfs/u/barn/CFSI/shared/dcs-rh8/petsc/src/mat/interface/matrix.c:4439
>> [18]PETSC ERROR: #5 <https://itssc.rpi.edu/hc/requests/5>
>> PCSetUp_HYPRE() at
>> /gpfs/u/barn/CFSI/shared/dcs-rh8/petsc/src/ksp/pc/impls/hypre/hypre.c:240
>> [18]PETSC ERROR: #6 <https://itssc.rpi.edu/hc/requests/6>
>> PCSetUp() at
>> /gpfs/u/barn/CFSI/shared/dcs-rh8/petsc/src/ksp/pc/interface/precon.c:1015
>> Configure options --download-scalapack --download-mumps
>> --download-hypre --with-cc=mpicc --with-cxx=mpicxx
>> --with-fc=mpif90 --with-cudac=0 --with-debugging=0
>> [19]PETSC ERROR: #1 <https://itssc.rpi.edu/hc/requests/1>
>> [19]PETSC ERROR: #2 <https://itssc.rpi.edu/hc/requests/2>
>> MatSetType() at
>> [19]PETSC ERROR: #3 <https://itssc.rpi.edu/hc/requests/3>
>> [19]PETSC ERROR: #4 <https://itssc.rpi.edu/hc/requests/4>
>> MatConvert() at
>> [19]PETSC ERROR: #5 <https://itssc.rpi.edu/hc/requests/5>
>> PCSetUp_HYPRE() at
>> [19]PETSC ERROR: #6 <https://itssc.rpi.edu/hc/requests/6>
>> PCSetUp() at
>> It seems that MPI_Comm_dup() at
>> petsc/src/mat/impls/hypre/mhypre.c:2120 caused the problem. Since
>> mine is a time-dependent problem, MatCreate_HYPRE() is called
>> every time the new system matrix is assembled. The above error
>> message is reported after ~4095 calls of MatCreate_HYPRE(), which
>> is around 455 time steps in my code. Here is some basic compiler
>> information:
>> Can you destroy old matrices to free MPI communicators? Otherwise,
>> you run into a limitation we knew before.
>> IBM Spectrum MPI 10.4.0
>> GCC 8.4.1
>> I've never had this problem before with OpenMPI or MPICH
>> implementation, so I was wondering if this can be resolved from
>> my end, or it's an implementation specific problem.
>> Thanks!
>> Feimi
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210818/92559cdc/attachment.html>
