[petsc-users] Reaching limit number of communicator with Spectrum MPI
Junchao Zhang junchao.zhang at gmail.com
Wed Aug 18 15:23:27 CDT 2021
On Wed, Aug 18, 2021 at 12:52 PM Feimi Yu <yuf2 at rpi.edu> wrote:
> Hi,
> I was trying to run a simulation with a PETSc-wrapped Hypre
> preconditioner, and encountered this problem:
> [dcs122:133012] Out of resources: all 4095 communicator IDs have been used.
> [19]PETSC ERROR: --------------------- Error Message
> [19]PETSC ERROR: General MPI error
> [19]PETSC ERROR: MPI error 17 MPI_ERR_INTERN: internal error
> [19]PETSC ERROR: See https://www.mcs.anl.gov/petsc/documentation/faq.html
> for trouble shooting.
> [19]PETSC ERROR: Petsc Release Version 3.15.2, unknown
> [19]PETSC ERROR: ./main on a arch-linux-c-opt named dcs122 by CFSIfmyu Wed
> Aug 11 19:51:47 2021
> [19]PETSC ERROR: [dcs122:133010] Out of resources: all 4095 communicator
> IDs have been used.
> [18]PETSC ERROR: --------------------- Error Message
> [18]PETSC ERROR: General MPI error
> [18]PETSC ERROR: MPI error 17 MPI_ERR_INTERN: internal error
> [18]PETSC ERROR: See https://www.mcs.anl.gov/petsc/documentation/faq.html
> [18]PETSC ERROR: Petsc Release Version 3.15.2, unknown
> [18]PETSC ERROR: ./main on a arch-linux-c-opt named dcs122 by CFSIfmyu Wed
> [18]PETSC ERROR: Configure options --download-scalapack --download-mumps
> --download-hypre --with-cc=mpicc --with-cxx=mpicxx --with-fc=mpif90
> --with-cudac=0 --with-debugging=0
> --with-blaslapack-dir=/gpfs/u/home/CFSI/CFSIfmyu/barn-shared/dcs-rh8/lapack-build/
> [18]PETSC ERROR: #1 <https://itssc.rpi.edu/hc/requests/1>
> MatCreate_HYPRE() at
> /gpfs/u/barn/CFSI/shared/dcs-rh8/petsc/src/mat/impls/hypre/mhypre.c:2120
> [18]PETSC ERROR: #2 <https://itssc.rpi.edu/hc/requests/2> MatSetType() at
> /gpfs/u/barn/CFSI/shared/dcs-rh8/petsc/src/mat/interface/matreg.c:91
> [18]PETSC ERROR: #3 <https://itssc.rpi.edu/hc/requests/3>
> MatConvert_AIJ_HYPRE() at
> /gpfs/u/barn/CFSI/shared/dcs-rh8/petsc/src/mat/impls/hypre/mhypre.c:392
> [18]PETSC ERROR: #4 <https://itssc.rpi.edu/hc/requests/4> MatConvert() at
> /gpfs/u/barn/CFSI/shared/dcs-rh8/petsc/src/mat/interface/matrix.c:4439
> [18]PETSC ERROR: #5 <https://itssc.rpi.edu/hc/requests/5> PCSetUp_HYPRE()
> at /gpfs/u/barn/CFSI/shared/dcs-rh8/petsc/src/ksp/pc/impls/hypre/hypre.c:240
> [18]PETSC ERROR: #6 <https://itssc.rpi.edu/hc/requests/6> PCSetUp() at
> /gpfs/u/barn/CFSI/shared/dcs-rh8/petsc/src/ksp/pc/interface/precon.c:1015
> Configure options --download-scalapack --download-mumps --download-hypre
> --with-cc=mpicc --with-cxx=mpicxx --with-fc=mpif90 --with-cudac=0
> --with-debugging=0
> [19]PETSC ERROR: #1 <https://itssc.rpi.edu/hc/requests/1>
> [19]PETSC ERROR: #2 <https://itssc.rpi.edu/hc/requests/2> MatSetType() at
> [19]PETSC ERROR: #3 <https://itssc.rpi.edu/hc/requests/3>
> [19]PETSC ERROR: #4 <https://itssc.rpi.edu/hc/requests/4> MatConvert() at
> [19]PETSC ERROR: #5 <https://itssc.rpi.edu/hc/requests/5> PCSetUp_HYPRE()
> [19]PETSC ERROR: #6 <https://itssc.rpi.edu/hc/requests/6> PCSetUp() at
> It seems that MPI_Comm_dup() at petsc/src/mat/impls/hypre/mhypre.c:2120
> caused the problem. Since mine is a time-dependent problem,
> MatCreate_HYPRE() is called every time the new system matrix is assembled.
> The above error message is reported after ~4095 calls of MatCreate_HYPRE(),
> which is around 455 time steps in my code. Here is some basic compiler
> information:
Can you destroy old matrices to free MPI communicators?  Otherwise, you run
into a limitation we knew before.
IBM Spectrum MPI 10.4.0
> GCC 8.4.1
> I've never had this problem before with OpenMPI or MPICH implementation,
> so I was wondering if this can be resolved from my end, or it's an
> implementation specific problem.
> Thanks!
> Feimi
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210818/3f53f573/attachment.html>
