[petsc-users] Reaching limit number of communicator with Spectrum MPI
Feimi Yu yuf2 at rpi.edu
Wed Aug 18 12:52:30 CDT 2021
I was trying to run a simulation with a PETSc-wrapped Hypre
preconditioner, and encountered this problem:
[dcs122:133012] Out of resources: all 4095 communicator IDs have been used.
[19]PETSC ERROR: --------------------- Error Message
[19]PETSC ERROR: General MPI error
[19]PETSC ERROR: MPI error 17 MPI_ERR_INTERN: internal error
[19]PETSC ERROR: See
https://www.mcs.anl.gov/petsc/documentation/faq.html
<https://www.mcs.anl.gov/petsc/documentation/faq.html> for trouble shooting.
[19]PETSC ERROR: Petsc Release Version 3.15.2, unknown
[19]PETSC ERROR: ./main on a arch-linux-c-opt named dcs122 by CFSIfmyu
Wed Aug 11 19:51:47 2021
[19]PETSC ERROR: [dcs122:133010] Out of resources: all 4095 communicator
IDs have been used.
[18]PETSC ERROR: --------------------- Error Message
[18]PETSC ERROR: General MPI error
[18]PETSC ERROR: MPI error 17 MPI_ERR_INTERN: internal error
[18]PETSC ERROR: See
[18]PETSC ERROR: Petsc Release Version 3.15.2, unknown
[18]PETSC ERROR: ./main on a arch-linux-c-opt named dcs122 by CFSIfmyu
[18]PETSC ERROR: Configure options --download-scalapack --download-mumps
--download-hypre --with-cc=mpicc --with-cxx=mpicxx --with-fc=mpif90
--with-cudac=0 --with-debugging=0
--with-blaslapack-dir=/gpfs/u/home/CFSI/CFSIfmyu/barn-shared/dcs-rh8/lapack-build/
[18]PETSC ERROR: #1 <https://itssc.rpi.edu/hc/requests/1>
MatCreate_HYPRE() at
/gpfs/u/barn/CFSI/shared/dcs-rh8/petsc/src/mat/impls/hypre/mhypre.c:2120
[18]PETSC ERROR: #2 <https://itssc.rpi.edu/hc/requests/2> MatSetType()
at /gpfs/u/barn/CFSI/shared/dcs-rh8/petsc/src/mat/interface/matreg.c:91
[18]PETSC ERROR: #3 <https://itssc.rpi.edu/hc/requests/3>
MatConvert_AIJ_HYPRE() at
/gpfs/u/barn/CFSI/shared/dcs-rh8/petsc/src/mat/impls/hypre/mhypre.c:392
[18]PETSC ERROR: #4 <https://itssc.rpi.edu/hc/requests/4> MatConvert()
at /gpfs/u/barn/CFSI/shared/dcs-rh8/petsc/src/mat/interface/matrix.c:4439
[18]PETSC ERROR: #5 <https://itssc.rpi.edu/hc/requests/5>
PCSetUp_HYPRE() at
/gpfs/u/barn/CFSI/shared/dcs-rh8/petsc/src/ksp/pc/impls/hypre/hypre.c:240
[18]PETSC ERROR: #6 <https://itssc.rpi.edu/hc/requests/6> PCSetUp() at
/gpfs/u/barn/CFSI/shared/dcs-rh8/petsc/src/ksp/pc/interface/precon.c:1015
Configure options --download-scalapack --download-mumps --download-hypre
--with-cc=mpicc --with-cxx=mpicxx --with-fc=mpif90 --with-cudac=0
--with-debugging=0
[19]PETSC ERROR: #1 <https://itssc.rpi.edu/hc/requests/1>
[19]PETSC ERROR: #2 <https://itssc.rpi.edu/hc/requests/2> MatSetType()
[19]PETSC ERROR: #3 <https://itssc.rpi.edu/hc/requests/3>
[19]PETSC ERROR: #4 <https://itssc.rpi.edu/hc/requests/4> MatConvert()
[19]PETSC ERROR: #5 <https://itssc.rpi.edu/hc/requests/5>
PCSetUp_HYPRE() at
[19]PETSC ERROR: #6 <https://itssc.rpi.edu/hc/requests/6> PCSetUp() at
It seems that MPI_Comm_dup() at petsc/src/mat/impls/hypre/mhypre.c:2120
caused the problem. Since mine is a time-dependent problem,
MatCreate_HYPRE() is called every time the new system matrix is
assembled. The above error message is reported after ~4095 calls of
MatCreate_HYPRE(), which is around 455 time steps in my code. Here is
some basic compiler information:
IBM Spectrum MPI 10.4.0
GCC 8.4.1
I've never had this problem before with OpenMPI or MPICH implementation,
so I was wondering if this can be resolved from my end, or it's an
implementation specific problem.
Thanks!
Feimi
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210818/343ce926/attachment.html>
