[petsc-users] use of undeclared identifier PetscViewerHDF5Open - in Petsc 3.12
Armando Coco armandococo28 at gmail.com
Wed Aug 11 08:39:28 CDT 2021
Yes, it works with ./configure --download-hdf5
Thank you!!
Armando
Il giorno mar 10 ago 2021 alle ore 19:40 Barry Smith <bsmith at petsc.dev> ha
scritto:
>   Likely your install of PETSc was not configured for HDF5.  Use
> On Aug 10, 2021, at 8:23 AM, Matthew Knepley <knepley at gmail.com> wrote:
> On Tue, Aug 10, 2021 at 5:35 AM Armando Coco <armandococo28 at gmail.com>
> wrote:
>> Hello,
>> I am trying to compile a petsc program that calls PetscViewerHDF5Open.
>> I have added #include <petscviewerhdf5.h> in the header, but the
>> compilation fails with error:
>> I have asked a colleague to run the same program in a newer version 3.14
>> or 3.15 and everything seems to work properly. Does it mean that I have to
>> update my petsc version necessarily?
> I see the declaration there in version 3.12:
> https://gitlab.com/petsc/petsc/-/blob/v3.12/include/petscviewerhdf5.h#L43
> Can you send the entire error output?
>   Thanks,
>      Matt
>> Many Thanks
>> Armando
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210811/4504f766/attachment.html>
