[petsc-users] Reordering of entries in a DMDA
Matthew Knepley
knepley at gmail.com
Wed Apr 21 14:11:25 CDT 2021
On Wed, Apr 21, 2021 at 3:07 PM Fabian Jakub <
Fabian.Jakub at physik.uni-muenchen.de> wrote:
> Dear Petsc team,
> I would like to play with the ordering of a DMDA application.
> To be exact, I would like to change the order in which a forward
> SOR/Gauss Seidel preconditioner iterates over the domain.
> e.g. change from [x,y,z,dof] to [z, yend->ystart, xend->xstart, dof]
> As I see it, I could
> a) reorder the application, i.e. how data is stored in the DMDA
> b) apply a mat reordering (happy to have the reordering only happening
> locally)
> c) or implement a custom PC (or using a PCShell?)
> I don't like a) because it would be very laborious and intrusive and I
> don't even know if it is worth it.
> Implementing a custom PC might give the most freedom but reduces solver
> configurability that I like.
> And how bad would a SOR be if it were to jump around in memory compared
> to the performance and memory needs of a mat reordering?
> I wanted to ask if you have any other suggestions and which approach you
> would recommend.
1) I would do the reordering in serial to check that it is effective
2) If the reodering is process local, then everything is simple. You just
alter the global-to-local mapping
for the matrix. If not, things would get more complicated.
Matt
> Many thanks,
> Fabian
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210421/5c63aaac/attachment.html>
