[petsc-users] Parallel TS for ODE
Matthew Knepley
knepley at gmail.com
Tue Apr 20 09:43:45 CDT 2021
On Tue, Apr 20, 2021 at 10:41 AM Francesco Brarda <brardafrancesco at gmail.com>
wrote:
> I was trying to follow Barry's advice some time ago, but I guess that's
> not the way he meant it. How should I refer to the values contained in x?
> With Distributed Arrays?
That is how you get values from x. However, I cannot understand at all what
you are doing with "mybase".
Matt
> Thanks
> Francesco
> Even though it will not scale and will deliver slower performance it is
>> completely possible for you to solve the 3 variable problem using 3 MPI
>> ranks. Or 10 mpi ranks. You would just create vectors/matrices with 1
>> degree of freedom for the first three ranks and no degrees of freedom for
>> the later ranks. During your function evaluation (and Jacobian evaluation)
>> for TS you will need to set up the appropriate communication to get the
>> values you need on each rank to evaluate the parts of the function
>> evaluation needed by that rank. This is true for parallelizing any
>> computation.
>> Barry
> Il giorno 20 apr 2021, alle ore 15:40, Matthew Knepley <knepley at gmail.com>
> ha scritto:
> On Tue, Apr 20, 2021 at 9:36 AM Francesco Brarda <
> brardafrancesco at gmail.com> wrote:
>> Hi!
>> I tried to implement the SIR model taking into account the fact that I
>> will only use 3 MPI ranks at this moment.
>> I built vectors and matrices following the examples already available. In
>> particular, I defined the functions required similarly (RHSFunction,
>> IFunction, IJacobian), as follows:
> I don't think this makes sense. You use "mybase" to distinguish between 3
> procs, which would indicate that each procs has only
> 1 degree of freedom. However, you use x[1] on each proc, indicating it has
> at least 2 dofs.
> Thanks,
> Matt
>> static PetscErrorCode RHSFunction(TS ts,PetscReal t,Vec X,Vec F,void *ctx)
>> PetscErrorCode ierr;
>> AppCtx *appctx = (AppCtx*) ctx;
>> PetscScalar f;//, *x_localptr;
>> const PetscScalar *x;
>> PetscInt mybase;
>> PetscFunctionBeginUser;
>> ierr = VecGetOwnershipRange(X,&mybase,NULL);CHKERRQ(ierr);
>> ierr = VecGetArrayRead(X,&x);CHKERRQ(ierr);
>> if (mybase == 0) {
>> f = (PetscScalar) (-appctx->p1*x[0]*x[1]/appctx->N);
>> ierr = VecSetValues(F,1,&mybase,&f,INSERT_VALUES);
>> if (mybase == 1) {
>> f = (PetscScalar) (appctx->p1*x[0]*x[1]/appctx->N-appctx->p2*x[1]);
>> if (mybase == 2) {
>> f = (PetscScalar) (appctx->p2*x[1]);
>> ierr = VecRestoreArrayRead(X,&x);CHKERRQ(ierr);
>> ierr = VecAssemblyBegin(F);CHKERRQ(ierr);
>> ierr = VecAssemblyEnd(F);CHKERRQ(ierr);
>> PetscFunctionReturn(0);
>> Whilst for the Jacobian I did:
>> static PetscErrorCode IJacobian(TS ts,PetscReal t,Vec X,Vec
>> Xdot,PetscReal a,Mat A,Mat B,void *ctx)
>> PetscInt mybase, rowcol[] = {0,1,2};
>> ierr = MatGetOwnershipRange(B,&mybase,NULL);CHKERRQ(ierr);
>> if (mybase == 0) {
>> const PetscScalar J[] = {a + appctx->p1*x[1]/appctx->N,
>> appctx->p1*x[0]/appctx->N, 0};
>> ierr =
>> MatSetValues(B,1,&mybase,3,rowcol,J,INSERT_VALUES);CHKERRQ(ierr);
>> if (mybase == 1) {
>> const PetscScalar J[] = {- appctx->p1*x[1]/appctx->N, a -
>> appctx->p1*x[0]/appctx->N + appctx->p2, 0};
>> ierr =
>> if (mybase == 2) {
>> const PetscScalar J[] = {0, - appctx->p2, a};
>> ierr =
>> ierr = MatAssemblyBegin(A,MAT_FINAL_ASSEMBLY);CHKERRQ(ierr);
>> ierr = MatAssemblyEnd(A,MAT_FINAL_ASSEMBLY);CHKERRQ(ierr);
>> if (A != B) {
>> ierr = MatAssemblyBegin(B,MAT_FINAL_ASSEMBLY);CHKERRQ(ierr);
>> ierr = MatAssemblyEnd(B,MAT_FINAL_ASSEMBLY);CHKERRQ(ierr);
>> This code does not provide the correct result, that is, the solution is
>> the initial condition, either using implicit or explicit methods. Is the
>> way I defined these objects wrong? How can I fix it?
>> I also tried to print the Jacobian with the following commands but it
>> does not work (blank rows and error message). How should I print the
>> Jacobian?
>> ierr = TSGetIJacobian(ts,NULL,&K, NULL, NULL); CHKERRQ(ierr);
>> ierr = MatAssemblyBegin(K,MAT_FINAL_ASSEMBLY);CHKERRQ(ierr);
>> ierr = MatAssemblyEnd(K,MAT_FINAL_ASSEMBLY);CHKERRQ(ierr);
>> ierr = MatView(K,PETSC_VIEWER_STDOUT_WORLD);CHKERRQ(ierr);
>> I would very much appreciate any kind of help or advice.
>> Best,
>> Francesco
>> Il giorno 2 apr 2021, alle ore 04:45, Barry Smith <bsmith at petsc.dev> ha
>> scritto:
>> On Apr 1, 2021, at 9:17 PM, Zhang, Hong via petsc-users <
>> petsc-users at mcs.anl.gov> wrote:
>> On Mar 31, 2021, at 2:53 AM, Francesco Brarda <brardafrancesco at gmail.com>
>> wrote:
>> Hi everyone!
>> I am trying to solve a system of 3 ODEs (a basic SIR model) with TS.
>> Sequentially works pretty well, but I need to switch it into a
>> parallel version.
>> I started working with TS not very long time ago, there are few questions
>> I’d like to share with you and if you have any advices I’d be happy to hear.
>> First of all, do I need to use a DM object even if the model is only time
>> dependent? All the examples I found were using that object for the other
>> variable when solving PDEs.
>> Are you considering SIR on a spatial domain? If so, you can parallelize
>> your model in the spatial domain using DM. Splitting the three variables in
>> the ODE among processors would not scale.
>> computation.
>> Barry
>> Hong (Mr.)
>> When I preallocate the space for the Jacobian matrix, is it better to
>> decide the local or global space?
>> Best,
>> Francesco
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210420/3b119138/attachment.html>
