[petsc-users] Preconditioner for stokes flow with mixed boundary conditions.
Abhinav Singh
abhinavrajendra at gmail.com
Mon Apr 19 08:37:23 CDT 2021
> What does this mean? Stokes means using an incompressibility constraint,
> for which we often introduce a pressure.
Yes, what I mean is solving the momentum block, say with known pressure.
viscosity is constant however, the momentum equation has both Laplacian and
Gradient terms.
You should use a good Laplacian preconditioner, like -pc_type gamg or
> -pc_type ml.
I tried gamg and it seems to diverge as the solution is NaN. The KSP
residual message is " 0 KSP Residual norm 1.131782747169e+01 ".
When using -pc_type ml, I get Aggregate Warning and then some faulty
address which stops the code.
On Mon, 19 Apr 2021 at 12:31, Matthew Knepley <knepley at gmail.com> wrote:
> On Mon, Apr 19, 2021 at 6:18 AM Abhinav Singh <abhinavrajendra at gmail.com>
> wrote:
>> Hello all,
>> I am trying to solve for incompressible stokes flow on a particle based
>> discretization. I use a pressure correction technique along with Particle
>> strength exchange like operators.
>> I call Petsc to solve the Stokes Equation without the pressure term.
> Do you mean you are solving only the momentum block? If so, do you have a
> constant viscosity? If so, then this is just the Laplace equation.
> -pc_type ml.
> Thanks
> Matt
>> GMRES usually works great but with dirichlet boundary conditions. When I
>> use a mixed boundary condition in Y, (dirichlet on bottom and Neumann on
>> the top) with periodicity in X,Z. GMRES fails converge when the size of
>> matrix increases. For smaller size (upto 27*27*5), only GMRES works and
>> that too only with the option 'pc_type none'. I was unable to find any
>> preconditioner which worked. Eventually, it also fails for bigger size.
>> UMFPACK works but LU decomposition fails after a certain size and is very
>> slow.
>> It would be great if you could suggest a way or a preconditioner which
>> suits this problem.
>> Kind regards,
>> Abhinav
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210419/aa882e3b/attachment.html>
