[petsc-users] Preconditioner for stokes flow with mixed boundary conditions.
Mon Apr 19 05:31:26 CDT 2021
On Mon, Apr 19, 2021 at 6:18 AM Abhinav Singh <abhinavrajendra at gmail.com>
wrote:
> Hello all,
> I am trying to solve for incompressible stokes flow on a particle based
> discretization. I use a pressure correction technique along with Particle
> strength exchange like operators.
> I call Petsc to solve the Stokes Equation without the pressure term.
What does this mean? Stokes means using an incompressibility constraint,
for which we often introduce a pressure.
Do you mean you are solving only the momentum block? If so, do you have a
constant viscosity? If so, then this is just the Laplace equation.
You should use a good Laplacian preconditioner, like -pc_type gamg or
-pc_type ml.
  Thanks
     Matt
> GMRES usually works great but with dirichlet boundary conditions. When I
> use a mixed boundary condition in Y, (dirichlet on bottom and Neumann on
> the top) with periodicity in X,Z. GMRES fails converge when the size of
> matrix increases. For smaller size (upto 27*27*5), only GMRES works and
> that too only with the option 'pc_type none'. I was unable to find any
> preconditioner which worked. Eventually, it also fails for bigger size.
> UMFPACK works but LU decomposition fails after a certain size and is very
> slow.
> It would be great if you could suggest a way or a preconditioner which
> suits this problem.
> Kind regards,
> Abhinav
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210419/48352896/attachment.html>
